Vbs Module Failure
Please see the last phone call in the attached logs.zip
It seems that the call ended prematurely because of a VB Script module which either failed or timed-out.
We are trying to debug this as it has happened many times.
From the logs, we were unable to determine if...
1-The module timed out because the 5 second limit was exceeded.
2-The module failed because vg.Run_ResultReturn($RV_LINEID, "fail") was called.
3-The module failed because of some other reason.
Please advise how I find the cause of this error.
logs.zip
Trace shows that VoiceGuide detected that VBScript task in module [scriptOnLoad] has completed/exited, but, as no result has been returned by the script, VoiceGuide takes the fail/false path.
To better track how the script progresses we would recommend adding more tracing comments in the script.
Please see: http://www.voiceguide.com/vghelp/source/html/com_admin_tracelogadd.htm
081211.792 6 3 2 Process.HasExited is true (System.Diagnostics.Process (wscript))
081211.792 6 3 2 task completed. vgm=59, iRunWait=2, iRunWait_ExeResult_NextVgm=0=[]
081211.792 6 3 2 ExeResult_NextVgm has not been set. check for Result file.
081211.792 6 3 2 no result file returned from program (VGRUNRESULT_3.TXT).
081211.792 6 3 2 FindNextVgmTitleInPathList: next module title is=[Fatal Error]
081211.792 6 3 2 q tel add cmd_PlayStop [0,0,0,0,0][||||]
081211.792 7 3 2 q tel run cmd_PlayStop 2|00:00:00.7656250
081211.792 6 3 2 play PlaySoundStop ok
081211.792 6 3 2 task completed LsRunWaitChooseNext iNextVgm=56
081211.792 6 3 2 t timer clear (force=False)
081211.792 6 3 2 RunModule start Play, [Fatal Error], iModuleIdx=56, previous: vgm=59, vgs=2:2
