No Welcome Message In Voicemail Boxes
I am just setting up a voicemail system using a Dialogic D/4pci on win2000 pro.
It hooks to 2 analog ports of our NEC Electra Pro.
When the Vm answer script is run it plays a list of names and numbers 11,12,etc
the get number gets the correct mailbox
on {18} goto [Voicemail box 18]
When selected it just says "Please record your message after the beep"
The mailbox identity or welcome is never played. The message is recorded in the correct mail box.
What am I doing wrong.
Script available on request.
Ver 5.1.3001
Is there a file called 18.wav in VoiceGuide's \data\VmWelc\ subdirectory? That's the file that should be played as mailbox 18's welcoming message.
You should be able to record this file by using the Voicemail Manager's "Record Welcoming Message" rec button.
Here is the event trace log.
Note: Checking the box to save the log indicates that the file will be stored as:
C:\VoiceGuideLogMMDD.txt
it is actually stored as:
c:\program files\voiceguide\log\MMDDvgm.txt
Note:It appears that you must check the save box before you run the test or the info is not saved when you close the trace log.
204501.57 6 linedevstate 2048 0 0
204501.57 6 callstate OFFERING 65877 0 4
204501.59 6 callinfo CALLEDID
204501.59 6 callinfo ORIGIN
204501.59 6 ring 0
204507.61 6 ring 2
204513.63 6 ring 3
204519.67 6 ring 4
204525.70 6 ring 5
204525.70 6 Answer the call at 11/29/2003 8:45:25 PM
204525.70 6 lineAnswer(65877) => 65860
204526.25 6 callstate CONNECTED 65877,1,0
204526.25 6 WorkingModeTAPI@Connected=
204526.25 6 WorkingModeScript@Connected=
204526.29 6 Inband detection not enabled
204526.29 6 StartLoadedVgs at 11/29/2003 8:45:26 PM
204526.29 6 tapi Reply (LineEvReply) ok 65860 0
204526.30 6 [Day of Week] Evaluate [($RV_DAY = 7)]
204526.30 6 RVreplace start: [($RV_DAY = 7)]
204526.30 6 RVreplace end: [(6 = 7)]
204526.30 6 .Eval((6 = 7))
204526.30 6 Eval Expr result:[False]
204526.30 6 [Mon-Sat Open Hours] Evaluate [(($RV_HOUR >= 7) and ($RV_HOUR <= 19))]
204526.30 6 RVreplace start: [(($RV_HOUR >= 7) and ($RV_HOUR <= 19))]
204526.30 6 RVreplace end: [((20 >= 7) and (20 <= 19))]
204526.30 6 .Eval(((20 >= 7) and (20 <= 19)))
204526.30 6 [store Closed] Playing
204526.30 6 [store Closed] Playing (STRNITE.wav)
204526.33 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Strasser\STRNITE.wav]
204526.33 6 RunModule PLAY end
204534.61 6 dtmf # (65877,35,2)
204534.62 6 LsPlayMsg #
204534.66 6 PlaySoundStop ok
204534.00 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
204534.00 6 [VoiceExt 200] Blind Transfer to 200 (Generate)
204535.01 6 tapic lineGenerateDigits(65877,!,0) => 0
204535.69 6 generate LINEGENERATETERM_DONE
204536.61 6 LsXferStart EV_TAPI_GENERATE
204537.61 6 LsXferPlayVts EV_HOOKFLASHFINISHED
204537.63 6 tapic lineGenerateDigits(65877,200,0) => 0
204538.06 6 generate LINEGENERATETERM_DONE
204539.02 6 LsXferPlayVts EV_TAPI_GENERATE
The inital Autoattendat script transfers the call to a second line where the voicemail is handled there by freeing up the first line for another call. This is where the voicemail script starts.
204539.80 5 linedevstate 2048 0 0
204539.81 5 callstate OFFERING 65792 0 4
204539.83 5 callinfo CALLEDID
204539.83 5 callinfo ORIGIN
204539.83 5 ring 0
204539.83 5 Answer the call at 11/29/2003 8:45:39 PM
204539.83 5 lineAnswer(65792) => 65791
204540.02 6 LsXferPlayVts EV_TIMEOUT_HANGUP
204540.02 6 Hanging up call...
204540.02 6 RecSoundStop ok
204540.02 6 PlaySoundStop ok
204540.02 6 fnHangupCall end
204540.08 6 linedevstate 2048 0 0
204540.08 6 callstate IDLE 65877 0 0
204540.08 6 WorkingMode@Idle=
204540.08 6 tapi Reply (LineEvReply) ok 65774 0
204540.38 5 callstate CONNECTED 65792,1,0
204540.38 5 WorkingModeTAPI@Connected=
204540.38 5 WorkingModeScript@Connected=
204540.41 5 Inband detection not enabled
204540.41 5 StartLoadedVgs at 11/29/2003 8:45:40 PM
204540.41 5 tapi Reply (LineEvReply) ok 65791 0
204540.41 5 [VoiceMail] Number Input
204540.41 5 [VoiceMail] Playing (STRVOICEMAIL.wav)
204540.43 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Strasser\STRVOICEMAIL.wav]
204541.04 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
204541.04 6 ReinitTelephony due to IDLE start
204541.04 6 tapic lineDeallocateCall(MainCall:65877) 0
204541.41 6 lineOpen(6) => 0
204541.41 6 Waiting for a call...
204541.41 6 lineOpen(6)LineHandle=65757
204547.23 5 dtmf 1 (65792,49,2)
204547.23 5 LsGetNbrsPlayWelcMsg 1
204547.27 5 PlaySoundStop ok
204547.28 5 [VoiceMail] Number Input 1
204547.28 5 path {1} not found
204548.85 5 dtmf 8 (65792,56,2)
204548.85 5 LsGetNbrsRxDigits 8
204548.85 5 [VoiceMail] Number Input 18
This is where I selected voicemail box 18
204548.85 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgp at idx=3
204548.85 5 [VmLmStart] Running vb script:[VmLmHangup.vgs]
204601.01 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=4
204601.01 5 [VmLmHangup_ForwardLastMsg] Running VB Script...
204601.01 5 RVreplace start (strlen>100)
204601.02 5 Run Script waiting... (shellid=680, process=1524)
204601.02 5 tapi Reply (LineEvReply) ok 65723 0
204601.06 0 cl Vm_VmbConfig_Get 19, MsgLenMin
204601.06 0 COM interface not supported in this version.
204601.06 5 cl Vm_ForwardMsg 5, 19, C:\Program Files\VoiceGuide\data\VmSave\19_1129204551_1_5__.wav
204601.06 5 vm frwrd vmb 19
204601.08 5 RVreplace start: [Voicemail received from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_NN on $RV_DATE $RV_MONTHNAME]
204601.08 5 RVreplace end: [Voicemail received from , at 20:46 on 29 November]
204601.08 5 RVreplace start (strlen>100)
204601.08 5 vm frwrd vmb 19 email to strhdw@strasser-hardware.com
204601.08 5 vm frwrd vmb 19 end
204601.95 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
204601.95 5 task completed (shellid=680, process=1524)
204601.95 5 No information returned from program to VG (no VGRUNRESULT_5.TXT or SHLRESLT.TXT)
204601.95 5 Hanging up call... [WaitTillFinished - next module not specified]
204601.95 5 HangupCall_Common Mode=AfterHangupRun
204601.95 5 ReinitTelephony due to IDLE start
204601.97 5 tapic lineDeallocateCall(MainCall:65792) 0
204602.29 5 lineOpen(5) => 0
204602.29 5 Waiting for a call...
204602.29 5 lineOpen(5)LineHandle=65706
After the start recording beep occured I hungup the phone.
Re: your question the 18.wav is in the \data\VmWelc\ subdirectory.
I suspect that this bug has been fixed in current (v5.1.3) release of VG already.
Please unzip the attached files in VoiceGuide's \system\vm\ subdirectory, and make another call.
If that fixes your problem I'd recommend to just update your install to v5.1.3 - this is where the attached Voicemail scripts came from...
vmLm.zip
