Playing message on hold while new modules are ran
One more case.
I set
VBS module:
vg.Play_Start $RV_LINEID, "IpOnHold_Long.wav"
set vg = Nothing
and next is another VBS module.
VG starting play MoH declared in first module in next VGS module playing MoH declared in second module.
After deleting MoH in second module on hold is silence.
I want to play MoH during all elements I use until I declare stop MoH or next module have own MoH or module play own prompt (like PLAY, GET NUMBERS, SAY NUMBERS)
If is not declared other prompt to play MoH should be played continuously.
And one more functionality: we need loop or multifile option for MoH.
Can we declare few prompt files in chain in MoH form or VBS like: vg.Play_Start $RV_LINEID, "IpOnHold_Long.wav, IpOnHold_Long.wav, IpOnHold_Long.wav" ?
I found that MoH used in VBS
vg.Play_Start $RV_LINEID, "moh.wav"
set vg = Nothing
blocking voice prompt in GET NUMBERS MODULE.
Please post the script (or excerpt of) demonstrating the problem and the vgEngine and ktTel traces which capture the system executing the script (or excerpt of).
Yes. That multiple sound files can be specified.
Are you setting Result variable DoNotStopMOH (ie: $RV[DoNotStopMOH] ) to 1 before starting the VBScript module?
Are you setting it back to 0 after last module through which you want the Message On Hold (MoH) to play?
To stop playing you can also issue the Play_Stop API command. This will stop the playing even when $RV[DoNotStopMOH] is set to 1.
I solved problem adding VBS module included
vg.Play_Stop $RV_LINEID
set vg = Nothing
but it isn't satisfied solution.
I think that any module with own prompt should include "vg.Play_Stop"
I attached example of script.
MOH case.vgs
