Voicemail
This is just a query. What I wanted to know was when i send a message to a group using voicemail
Does Voiceguide recognise an answer phone and play the message.
Does Voiceguide recognise peopel answering the phone.
Like when we set a call does voiceguide try to ring an unanswered call several times etc etc or does it just try once?
does voicemail group messages get sent straight away and would this call take priority over other calls queued.
Matt
When a voicemail box is configured to forward a message to a phone number then that message is delivered like any other outgoing message.
When a phone is answered VoiceGuide will play the message (vmMsgDeliver.vgs script is used). If call is answered by an answering machine VG will wait until the welcome message finished playing and will play the message when the answering machine is recording.
VoiceGuide will try to forward the message to a phone 3 times, with 5 minute intervals between the 2nd and 3rd attempt. If a message is delivered to an answering machine that is considered a successful delivery and no more delivery attempts are made.
From v5.1.4 onwards you will be able to alter the retries/intervals etc using the following settings in the VG.INI file:
VmDeliverToPhone_Retries=2
;WaitBetweenRetries in minutes
VmDeliverToPhone_WaitBetweenRetries=5
;AnswerTimeout in seconds
VmDeliverToPhone_AnswerTimeout=60
VM forewards to phone are placed in the general queue of messages to be sent and are dealt in their own turn.
I have tried the Forward phone message feature but nothing is added to the OutDial queue even thought it appears that it has been added here.. can you help please..
Here is the trace log.
103230.90 11 linedevstate 2048 0 0
103230.90 11 callstate OFFERING 66361 0 4
103230.90 11 Answer the call at 20/11/2003 10:32:30
103230.92 11 lineAnswer(66361) => 65963
103230.92 11 callinfo CALLEDID
103230.92 11 callinfo ORIGIN
103230.92 11 ring 0
103231.47 11 callstate CONNECTED 66361,1,0
103231.47 11 WorkingModeTAPI@Connected=
103231.47 11 WorkingModeScript@Connected=
103231.51 11 Inband detection not enabled
103231.51 11 StartLoadedVgs at 20/11/2003 10:32:31
103231.51 11 tapi Reply (LineEvReply) ok 65963 0
103231.52 11 [set Sound Files] Evaluate ["C:\Program Files\VoiceGuide\System\voice_sue"]
103231.52 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_sue"))
103231.52 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_sue] stored in $RV[DIRSYSTEMVOICE]
103231.52 11 path {C:\Program Files\VoiceGuide\System\voice_sue} not found
103231.52 11 [s.Enter Pin Code] Number Input
103231.52 11 [s.Enter Pin Code] Playing (input-access-code.wav)
103231.54 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
103233.66 11 dtmf 5 (66361,53,2)
103233.66 11 LsGetNbrsPlayWelcMsg 5
103234.66 11 PlaySoundStop ok
103234.66 11 [s.Enter Pin Code] Number Input 5
103234.66 11 path {5} not found
103234.66 11 dtmf 3 (66361,51,2)
103234.66 11 LsGetNbrsRxDigits 3
103234.66 11 [s.Enter Pin Code] Number Input 53
103234.66 11 path {53} not found
103234.66 11 dtmf 9 (66361,57,2)
103234.66 11 LsGetNbrsRxDigits 9
103234.68 11 [s.Enter Pin Code] Number Input 539
103234.68 11 path {539} not found
103234.99 11 dtmf 7 (66361,55,2)
103234.99 11 LsGetNbrsRxDigits 7
103234.99 11 [s.Enter Pin Code] Number Input 5397
103234.99 11 [sound Files to orig] Evaluate ["C:\Program Files\VoiceGuide\System\voice"]
103234.99 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice"))
103234.00 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice] stored in $RV[DIRSYSTEMVOICE]
103234.00 11 path {C:\Program Files\VoiceGuide\System\voice} not found
103234.00 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgs at idx=3
103234.00 11 [VmMenuStart] Number Input
103234.00 11 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbId.wav]
103235.01 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbId.wav]
103235.01 11 [VmMenuStart] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbId.wav)
103235.09 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbId.wav]
103240.11 11 dtmf 0 (66361,48,2)
103240.11 11 LsGetNbrsPlayWelcMsg 0
103241.11 11 PlaySoundStop ok
103241.11 11 [VmMenuStart] Number Input 0
103241.11 11 path {0} not found
103241.11 11 dtmf 0 (66361,48,2)
103241.11 11 LsGetNbrsRxDigits 0
103241.11 11 [VmMenuStart] Number Input 00
103241.11 11 path {00} not found
103241.11 11 [VmMenuStart] Number Input 000
103241.13 11 path {000} not found
103241.13 11 dtmf 1 (66361,49,2)
103241.13 11 LsGetNbrsRxDigits 1
103241.13 11 [VmMenuStart] Number Input 0001
103241.13 11 path {0001} not found
103247.04 11 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
103247.04 11 path {0001} not found
103247.04 11 [VmMenuCheckEnteredVmb] Running vb script:[VmLmHangup.vgs]
103350.09 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=4
103350.09 11 tapi Reply (LineEvReply) ok 65641 0
103350.09 11 [VmLmHangup_ForwardLastMsg] Running VB Script...
103350.09 11 RVreplace start (strlen>100)
103350.16 11 Run Script waiting... (shellid=2280, process=1732)
103351.09 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
103351.09 11 task completed (shellid=2280, process=1732)
103351.09 11 No information returned from program to VG (no VGRUNRESULT_11.TXT or SHLRESLT.TXT)
103351.09 11 Hanging up call... [WaitTillFinished - next module not specified]
103351.09 11 HangupCall_Common Mode=AfterHangupRun
103351.10 11 ReinitTelephony due to IDLE start
103351.11 11 tapic lineDeallocateCall(MainCall:66361) 0
103351.27 11 lineOpen(11) => 0
103351.27 11 Waiting for a call...
103351.27 11 lineOpen(11)LineHandle=65860.
i saw i had the wrong menu type listed so tried again using the RETRIEVE MESSAGES options and fumbled through the vmail menus (loads have sound file options missing) and queued a job for a group.. the message told me the messages were sent but nothing was added to the outdial queue and no phone calls were made.. pls help
103230.92 11 ring 0
Trace shows the mesasge were added to outdial queue OK, are any of your lines enabeld for outbound dialing?
Plz post the OutDialQue.mdb file From VoiceGuide's \data\ subdirectory.
103346.18 0 DialListDB_AddCall '0034661180060', 0, 1, 2359, MoTuWeThFrSaSu, C:\Program Files\VoiceGuide\System\voice\VmbForwardAskAccept.wav, C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs|VmDelivStart, C:\Program Files\VoiceGuide\data\VmSave\0002_1120103327_1_11__.wav, [PathSysVoice]{C:\Program Files\VoiceGuide\System\voice\}[VmbId]{0002}[VmFileToPlay]{0002_1120103327_1_11__.wav}, 60, 2, 5, ESCALATION:
yes my machine sends calls everyday thisis what is so weird.. no new calls queued
Plz make a calls into the system which leaves a message in the voicemail box which is set up to forward calls, then post the OutDialQue.mdb file from VoiceGuide's \data\ subdirectory here.
Which version of VG are you using?
I use version 5.1.2304 of voiceguide
I have added the outdialqueue.mdb but nothing was added so it is blank
I cannot set up a test using that version of VGMULTI.EXE, but tests with current release work fine...
Plz uninstall the version on your system then install the current release in a new directory - or rename the old directory before installing the new version of VG.
I really hate always having to install new version as it always screws something up... Is there no way you can publish updates instead as it takes ages and causes problems to have to uninstall and reinstall and re set it all up every week or 2... It really worries me doing this as when it works it's ok then an update comes along that makes no difference and screws something up.. Could you please just tell the voiceguide users the new files to install or update instead as i really dont feel I have time to be constantly uninstalling etc then checking every single bit of the system again to make sure all my calls work.... hope you understand pls let me know what to do and what updates have been made thanks
Usually the only thing needed replacing is the VGMULTI.EXE and the TAPIWRAP.OCX and SAPIWRAP.OCX files in Windows' System32 directory...
One way to do it would be to install current version on another machine then just try copying over those 3 files and see if that resolves the DialListDB_AddCall problem.
I installed all these files but when using voicemail some vbs errors popup so i#ve decided to install the new version.. only prob is that i need the install to be placed in c drive / program files directoyr as per my last install as i have files that point to this... i uninstalled and deleted keys from registry but voiceguide now installs to c drive / win nt directory instead.. please can you tell me how to make sure that VG is installed where i want it please.
You can select what directory to install the software in during the installation itself - one of the prompts asks you to select the installation directory...
it does not ask me what directory it just asked if i want to modify, remove, update.
Please let me know
ok, great that worked I now have the new version installed...
Right back to the initial problem...
1. When I login it only gives me options 1,2,3,4 However if i press 6 to record a message it still works...
Voicemail Box Main Menu
After entering the voicemail box ID and PIN, the following keys can be used:
1 Listen to new voicemail messages
2 Listen to saved voicemail messages
3 Administer the greeting message
4 Change voicemail box PIN
5 Change the forwarding telephone number
6 Record a message
7 Administer voicemail box name
8 Exit and go to Login Menu
0 Exit the voicemail system
# Play the message counts
2\when i try forward a message to a group (9999) they are not called still by voiceguide and nothing is added to the outdial queue
3\ When I try send a message to VmBox 0002 only it does call but no sound is played - the line is dead.
This is the code for all the tests...
I login using voicemail box 0001 and pin 5397
My group id is 9999
I have included a copy of how I have the mailboxes/Groups setup
100801.80 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
100803.26 11 dtmf 9   (65672,57,2)
100803.26 11 LsGetNbrsPlayWelcMsg 9
100803.32 11 PlaySoundStop ok
100803.32 11 [S.Enter Pin Code] Number Input 9
100803.32 11 path {9} not found
100803.46 11 dtmf 9   (65672,57,2)
100803.46 11 LsGetNbrsRxDigits 9
100803.46 11 [S.Enter Pin Code] Number Input 99
100803.46 11 path {99} not found
100803.68 11 dtmf 9   (65672,57,2)
100803.69 11 LsGetNbrsRxDigits 9
100803.69 11 [S.Enter Pin Code] Number Input 999
100803.69 11 path {999} not found
100803.97 11 dtmf 8   (65672,56,2)
100803.97 11 LsGetNbrsRxDigits 8
100803.98 11 [S.Enter Pin Code] Number Input 9998
100803.98 11 [Sound Files to orig] Evaluate ["C:\Program Files\VoiceGuide\System\voice"]
100803.98 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice"))
100803.99 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice] stored in $RV[DIRSYSTEMVOICE]
100803.99 11 path {C:\Program Files\VoiceGuide\System\voice} not found
100803.99 11 voicemail used: Scripted
100803.00  0 Script Load C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs
100805.13 11 Loaded C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs into:5
100805.14 11 [VmLoginStart] Running VB Script...
100805.15 11 RVreplace start (strlen>100)
100805.19 11 Run Script waiting... (shellid=2564, process=1576)
100805.23 11 cl    Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminName]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}<<
100805.24 11 [VmLoginAskVmb] Number Input
100805.25 11 RVreplace start: [$RV[VmbLoginIntro],$RV[PathSysVoice]VmbAccessGetVmbIdRetrieve.wav]
100805.25 11 RVreplace end: [none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
100805.25 11 [VmLoginAskVmb] Playing (none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav)
100805.32 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
100808.96 11 dtmf 0   (65672,48,2)
100808.96 11 LsGetNbrsPlayWelcMsg 0
100809.03 11 PlaySoundStop ok
100809.03 11 [VmLoginAskVmb] Number Input 0
100809.03 11 path {0} not found
100809.12 11 dtmf 0   (65672,48,2)
100809.12 11 LsGetNbrsRxDigits 0
100809.13 11 [VmLoginAskVmb] Number Input 00
100809.13 11 path {00} not found
100809.35 11 dtmf 0   (65672,48,2)
100809.35 11 LsGetNbrsRxDigits 0
100809.35 11 [VmLoginAskVmb] Number Input 000
100809.36 11 path {000} not found
100809.58 11 dtmf 1   (65672,49,2)
100809.58 11 LsGetNbrsRxDigits 1
100809.58 11 [VmLoginAskVmb] Number Input 0001
100809.59 11 path {0001} not found
100810.06 11 dtmf #   (65672,35,2)
100810.06 11 LsGetNbrsRxDigits #
100810.06 11 path {0001} not found
100810.06 11 [VmLoginAskPin] Number Input
100810.07 11 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbPin.wav]
100810.07 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
100810.07 11 [VmLoginAskPin] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav)
100810.13 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
100813.60 11 dtmf 5   (65672,53,2)
100813.61 11 LsGetNbrsPlayWelcMsg 5
100813.66 11 PlaySoundStop ok
100813.66 11 [VmLoginAskPin] Number Input 5
100813.66 11 path {5} not found
100813.78 11 dtmf 3   (65672,51,2)
100813.79 11 LsGetNbrsRxDigits 3
100813.79 11 [VmLoginAskPin] Number Input 53
100813.79 11 path {53} not found
100814.18 11 dtmf 9   (65672,57,2)
100814.18 11 LsGetNbrsRxDigits 9
100814.18 11 [VmLoginAskPin] Number Input 539
100814.19 11 path {539} not found
100814.49 11 dtmf 7   (65672,55,2)
100814.49 11 LsGetNbrsRxDigits 7
100814.50 11 [VmLoginAskPin] Number Input 5397
100814.50 11 path {5397} not found
100814.89 11 dtmf #   (65672,35,2)
100814.89 11 LsGetNbrsRxDigits #
100814.89 11 path {5397} not found
100814.89 11 [VmLoginCheckPin] Running VB Script...
100814.89 11 RVreplace start (strlen>100)
100814.95 11 Run Script waiting... (shellid=3008, process=1572)
100814.98  0 cl    Vm_VmbConfig_Get 0001, Pin
100814.99 11 cl    Script_Goto 11, , VmMmMsgCountsCalc, [VmbId]{0001}
100814.99 11 [VmMmMsgCountsCalc] Running VB Script...
100814.99 11 RVreplace start (strlen>100)
100815.05 11 Run Script waiting... (shellid=2900, process=1592)
100815.11 11 cl    Run_ResultReturn >>[VmMsgCount_New]{0}[VmMsgCount_Saved]{0}<<
100815.11 11 RVreplace start: [$RV[VmMsgCount_New]]
100815.11 11 RVreplace end: [0]
100815.13 11 [VmMmMsgCountsPlayNew] Say numbers: 0 as Number
100815.13 11 fn    PlaySoundStartNumbers $RV[PathSysVoice]VmbAccessYouHave.wav, $RV[PathSysVoice]VmbAccessNewMessagesAnd.wav, 0, Number
100815.13 11 RVreplace start: [$RV[PathSysVoice]VmbAccessYouHave.wav]
100815.13 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav]
100815.14 11 RVreplace start: [$RV[PathSysVoice]VmbAccessNewMessagesAnd.wav]
100815.14 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav]
100815.14 11 sVbsFunctionToUse=Number
100815.25 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
100815.30 11 cl    Play_Start C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav,0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav
100815.39 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav,C:\Program Files\VoiceGuide\System\voice\0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav]
100818.98 11 wb(37397502)
100819.03 11 Play End line[11] (id=373975)
100819.03 11 LsSayNbrPlay EV_PLAY_FINISHED
100819.03 11 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
100819.04 11 RVreplace start: [$RV[VmMsgCount_Saved]]
100819.04 11 RVreplace end: [0]
100819.04 11 [VmMmMsgCountsPlaySaved] Say numbers: 0 as Number
100819.04 11 fn    PlaySoundStartNumbers none, $RV[PathSysVoice]VmbAccessSavedMessages.wav, 0, Number
100819.05 11 RVreplace start: [$RV[PathSysVoice]VmbAccessSavedMessages.wav]
100819.05 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessSavedMessages.wav]
100819.05 11 sVbsFunctionToUse=Number
100819.14 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
100819.17 11 cl    Play_Start 0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessSavedMessages.wav
100819.22 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessSavedMessages.wav]
100821.63 11 Play End line[11] (id=377841)
100821.63 11 LsSayNbrPlay EV_PLAY_FINISHED
100821.63 11 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
100821.63 11 [VmMmMenuPlay] Playing
100821.63 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
100821.63 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
100821.63 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav)
100821.66 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
100821.68 11 RunModule PLAY end
100824.48 11 dtmf 6   (65672,54,2)
100824.49 11 LsPlayMsg 6
100824.54 11 PlaySoundStop ok
100824.54 11 [VmMmMenu] Running VB Script...
100824.54 11 RVreplace start (strlen>100)
100824.62 11 Run Script waiting... (shellid=1860, process=1476)
100824.66 11 cl    Script_Gosub vmSendMsg.vgs, VmSendRecPrompt, , VmMmMenuPlay
100824.67  0 Script Load C:\Program Files\VoiceGuide\system\vm\vmSendMsg.vgs
100824.80 11 Loaded C:\Program Files\VoiceGuide\system\vm\vmSendMsg.vgs into:6
100824.80 11 [VmSendRecPrompt] Playing
100824.80 11 RVreplace start: [$RV[PathSysVoice]VmSendRecPrompt.wav]
100824.80 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav]
100824.81 11 [VmSendRecPrompt] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav)
100824.85 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav]
100824.85 11 RunModule PLAY end
100831.55 11 wb(38347900)
100831.61 11 Play End line[11] (id=383479)
100831.61 11 LsPlayMsg EV_PLAY_FINISHED
100831.61 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
100831.62 11 [VmSendRec] Recording
100831.65 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\beep1.wav]
100831.86 11 wb(39028900)
100831.91 11 Play End line[11] (id=390289)
100831.91 11 LsRecPlayBeep EV_PLAY_FINISHED
100831.93 11 RecSoundStart file[C:\Program Files\VoiceGuide\system\vm\1127100831_11_.wav] ok
100831.93 11 RecFile[C:\Program Files\VoiceGuide\system\vm\1127100831_11_.wav]
100838.12 11 dtmf #   (65672,35,2)
100838.13 11 LsRecRecording #
100838.18 11 RecSoundStopTruncBytes ok
100838.18 11 rec length RV: VmSendRec_RecLen100ms = 61
100838.19 11 [VmSendMainMenu] Running VB Script...
100838.19 11 RVreplace start (strlen>100)
100838.25 11 Run Script waiting... (shellid=3196, process=1584)
100838.31 11 cl    Script_Goto 11, , VmSendPlayMainMenu,
100838.32 11 [VmSendPlayMainMenu] Playing
100838.32 11 RVreplace start: [$RV[PathSysVoice]VmSendMainMenu.wav]
100838.32 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
100838.32 11 [VmSendPlayMainMenu] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav)
100838.38 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
100838.38 11 RunModule PLAY end
100842.84 11 dtmf 1   (65672,49,2)
100842.84 11 LsPlayMsg 1
100842.89 11 PlaySoundStop ok
100842.89 11 [VmSendMainMenu] Running VB Script...
100842.89 11 RVreplace start (strlen>100)
100842.95 11 Run Script waiting... (shellid=2388, process=1624)
100843.00 11 cl    Script_Goto 11, , VmSendPlayRecMsg,
100843.00 11 [VmSendPlayRecMsg] Playing
100843.00 11 RVreplace start: [$RV[VmSendRec]]
100843.02 11 RVreplace end: [C:\Program Files\VoiceGuide\system\vm\1127100831_11_.wav]
100843.02 11 [VmSendPlayRecMsg] Playing (C:\Program Files\VoiceGuide\system\vm\1127100831_11_.wav)
100843.04 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\vm\1127100831_11_.wav]
100843.04 11 RunModule PLAY end
100848.90 11 wb(40168500)
100848.95 11 Play End line[11] (id=401685)
100848.95 11 LsPlayMsg EV_PLAY_FINISHED
100848.96 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
100848.96 11 [VmSendPlayMainMenu] Playing
100848.96 11 RVreplace start: [$RV[PathSysVoice]VmSendMainMenu.wav]
100848.97 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
100848.97 11 [VmSendPlayMainMenu] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav)
100848.99 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
100848.99 11 RunModule PLAY end
100854.78 11 dtmf 2   (65672,50,2)
100854.78 11 LsPlayMsg 2
100854.84 11 PlaySoundStop ok
100854.84 11 [VmSendMainMenu] Running VB Script...
100854.85 11 RVreplace start (strlen>100)
100854.93 11 Run Script waiting... (shellid=2496, process=1616)
100855.05 11 cl    Script_Goto 11, , VmSendRec,
100855.06 11 [VmSendRec] Recording
100855.28 11 wb(41373200)
100855.33 11 Play End line[11] (id=413732)
100855.34 11 LsRecPlayBeep EV_PLAY_FINISHED
100855.35 11 RecSoundStart file[C:\Program Files\VoiceGuide\system\vm\1127100855_11_.wav] ok
100855.35 11 RecFile[C:\Program Files\VoiceGuide\system\vm\1127100855_11_.wav]
100902.90 11 dtmf #   (65672,35,2)
100902.90 11 LsRecRecording #
100902.95 11 RecSoundStopTruncBytes ok
100902.95 11 rec length RV: VmSendRec_RecLen100ms = 75
100902.96 11 [VmSendMainMenu] Running VB Script...
100902.97 11 RVreplace start (strlen>100)
100903.02 11 Run Script waiting... (shellid=3064, process=1632)
100903.07 11 cl    Script_Goto 11, , VmSendPlayMainMenu,
100903.07 11 [VmSendPlayMainMenu] Playing
100903.07 11 RVreplace start: [$RV[PathSysVoice]VmSendMainMenu.wav]
100903.09 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
100903.09 11 [VmSendPlayMainMenu] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav)
100903.11 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
100903.11 11 RunModule PLAY end
100905.22 11 dtmf 1   (65672,49,2)
100905.23 11 LsPlayMsg 1
100905.28 11 PlaySoundStop ok
100905.28 11 [VmSendMainMenu] Running VB Script...
100905.28 11 RVreplace start (strlen>100)
100905.34 11 Run Script waiting... (shellid=2372, process=1636)
100905.38 11 cl    Script_Goto 11, , VmSendPlayRecMsg,
100905.39 11 [VmSendPlayRecMsg] Playing
100905.40 11 RVreplace start: [$RV[VmSendRec]]
100905.40 11 RVreplace end: [C:\Program Files\VoiceGuide\system\vm\1127100855_11_.wav]
100905.40 11 [VmSendPlayRecMsg] Playing (C:\Program Files\VoiceGuide\system\vm\1127100855_11_.wav)
100905.43 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\vm\1127100855_11_.wav]
100905.43 11 RunModule PLAY end
100912.61 11 wb(42406700)
100912.66 11 Play End line[11] (id=424067)
100912.67 11 LsPlayMsg EV_PLAY_FINISHED
100912.67 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
100912.67 11 [VmSendPlayMainMenu] Playing
100912.67 11 RVreplace start: [$RV[PathSysVoice]VmSendMainMenu.wav]
100912.68 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
100912.68 11 [VmSendPlayMainMenu] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav)
100912.70 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
100912.70 11 RunModule PLAY end
100919.93 11 dtmf 3   (65672,51,2)
100919.93 11 LsPlayMsg 3
100919.98 11 PlaySoundStop ok
100919.99 11 [VmSendMainMenu] Running VB Script...
100919.99 11 RVreplace start (strlen>100)
100920.05 11 Run Script waiting... (shellid=392, process=1612)
100920.09 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{}
100920.09 11 [VmSendGetDest] Number Input
100920.09 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
100920.10 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
100920.10 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav)
100920.14 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
100923.76 11 dtmf 9   (65672,57,2)
100923.77 11 LsGetNbrsPlayWelcMsg 9
100923.82 11 PlaySoundStop ok
100923.82 11 [VmSendGetDest] Number Input 9
100923.82 11 path {9} not found
100924.00 11 dtmf 9   (65672,57,2)
100924.00 11 LsGetNbrsRxDigits 9
100924.02 11 [VmSendGetDest] Number Input 99
100924.02 11 path {99} not found
100924.27 11 dtmf 9   (65672,57,2)
100924.27 11 LsGetNbrsRxDigits 9
100924.27 11 [VmSendGetDest] Number Input 999
100924.27 11 path {999} not found
100925.43 11 dtmf 9   (65672,57,2)
100925.43 11 LsGetNbrsRxDigits 9
100925.43 11 [VmSendGetDest] Number Input 9999
100925.43 11 path {9999} not found
100925.77 11 dtmf #   (65672,35,2)
100925.78 11 LsGetNbrsRxDigits #
100925.78 11 path {9999} not found
100925.78 11 [VmSendGetDestAndSend] Running VB Script...
100925.78 11 RVreplace start (strlen>100)
100925.87 11 Run Script waiting... (shellid=1416, process=1620)
100925.93 11 cl    RvSet VmSendDestNameWav,
100925.94 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{9999}[VmSendGetDest]{}
100925.94 11 [VmSendGetDest] Number Input
100925.94 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
100925.95 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
100925.95 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav)
100925.97 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
100933.62 11 wb(44461700)
100933.67 11 Play End line[11] (id=444617)
100933.67 11 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
100934.11 11 dtmf #   (65672,35,2)
100934.11 11 LsGetNbrsRxDigits #
100934.11 11 [VmSendGetDestAndSend] Running VB Script...
100934.12 11 RVreplace start (strlen>100)
100934.18 11 Run Script waiting... (shellid=2400, process=1648)
100934.23 11 cl    RvSet VmSendDestNameWav,
100934.24  0 cl    Vm_DistListConfig_Get 9999, DistList
100934.24 11 vms   copy vm to:C:\Program Files\VoiceGuide\data\VmSave\9999_1127100934_1_11__0001.wav
100934.25 11 cl    Vm_ForwardMsg 11, 9999, C:\Program Files\VoiceGuide\data\VmSave\9999_1127100934_1_11__0001.wav
100934.27 11 vm    frwrd vmb    << unknown vmb
100934.32 11 cl    Script_Goto 11, , VmSendPlaySuccess, [VmSendRec]{}
100934.33 11 [VmSendPlaySuccess] Playing
100934.33 11 RVreplace start: [$RV[PathSysVoice]VmSendSuccess.wav]
100934.33 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav]
100934.33 11 [VmSendPlaySuccess] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav)
100934.38 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav]
100934.38 11 RunModule PLAY end
100936.00 11 wb(45300900)
100936.05 11 Play End line[11] (id=453009)
100936.05 11 LsPlayMsg EV_PLAY_FINISHED
100936.06 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
100936.07  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=5
100936.08 11 [VmMmMenuPlay] Playing
100936.08 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
100936.08 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
100936.09 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav)
100936.11 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
100936.11 11 RunModule PLAY end
100941.07 11 callstate DISCONNECTED 65672,0,0
100941.07 11 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
100941.08 11 Hanging up call...
100941.08 11 RecSoundStop ok
100941.13 11 PlaySoundStop ok
100941.14 11 fnHangupCall end
100941.18 11 linedevstate 2048 0 0
100941.18 11 callstate IDLE 65672 0 0
100941.18 11 WorkingMode@Idle=
100941.21 11 tapi  Reply (LineEvReply) ok 65638 0
100942.14 11 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
100942.14 11 ReinitTelephony due to IDLE start
100942.15 11 tapic lineDeallocateCall(MainCall:65672) 0
100942.32 11 lineOpen(11) => 0
100942.32 11 Waiting for a call...
100942.32 11 lineOpen(11)LineHandle=65621
VmBoxList.zip
OK, looks like there was a bug in the Voicemail system scripts.
Please update the scripts in VoiceGuide's \system\vm\ subdirectory with the ones attached and try again.
As a workaround, you could also just create a voicemail box with 9999 and in the 'copy to' field of that new VMB specify the list of Voicemail boxes to which to copy the message to (0001, 0002 etc)
Please provide a log trace for this problem.
vmSendMsg.zip
Ok, I installed the new update and tried to login as 0001 and send a message to 0002.... The menu options given are still only 1,2,3,4 but I pressed 6 anyway and it worked..
I got as far as recording the message and saying where to send it but then nothing... it gave me an error message so needless to say it still does not work.
(not tested group send yet either but will wait until this works)
C:program files/voiceguide/data/vbs_11_8.vbs
Line 68
Char 7
Code Subscript out of range
072929.23  0 sys   cleanup Start
072929.23  0 sys   cleanup End
073007.62 11 linedevstate 2048 0 0
073007.62 11 callstate OFFERING 65697 0 4
073007.62 11 Answer the call at 28/11/2003 07:30:07
073007.64 11 lineAnswer(65697) => 65613
073007.64 11 callinfo CALLEDID
073007.64 11 callinfo ORIGIN
073007.64 11 ring 0
073008.18 11 callstate CONNECTED 65697,1,0
073008.19 11 WorkingModeTAPI@Connected=
073008.19 11 WorkingModeScript@Connected=
073008.22 11 Inband detection not enabled
073008.23 11 StartLoadedVgs at 28/11/2003 07:30:08
073008.23 11 tapi  Reply (LineEvReply) ok 65613 0
073008.23 11 [Set Sound Files] Evaluate ["C:\Program Files\VoiceGuide\System\voice_sue"]
073008.23 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_sue"))
073008.23 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_sue] stored in $RV[DIRSYSTEMVOICE]
073008.23 11 path {C:\Program Files\VoiceGuide\System\voice_sue} not found
073008.24 11 [S.Enter Pin Code] Number Input
073008.24 11 [S.Enter Pin Code] Playing (input-access-code.wav)
073008.27 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
073011.80 11 dtmf 0   (65697,48,2)
073011.80 11 LsGetNbrsPlayWelcMsg 0
073011.86 11 PlaySoundStop ok
073011.86 11 [S.Enter Pin Code] Number Input 0
073011.86 11 path {0} not found
073014.33 11 dtmf *   (65697,42,2)
073014.33 11 LsGetNbrsRxDigits *
073014.33 11 path {*} not found
073014.34 11 fn    PlaySoundStartNumbers record-number-youhaveenteredthefollowingEXTnumber.wav, record-number-press1ifcorrect.wav, 0, Digits
073014.34 11 sVbsFunctionToUse=Digits
073014.44 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
073014.49 11 cl    Play_Start C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\record-number-youhaveenteredthefollowingEXTnumber.wav,0.wav,C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\record-number-press1ifcorrect.wav
073014.52 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\record-number-youhaveenteredthefollowingEXTnumber.wav,C:\Program Files\VoiceGuide\System\voice_sue\0.wav,C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\record-number-press1ifcorrect.wav]
073023.17 11 dtmf 2   (65697,50,2)
073023.18 11 LsGetNbrsPlayConfirm 2
073023.23 11 PlaySoundStop ok
073023.23 11 [S.Enter Pin Code] Number Input
073023.23 11 [S.Enter Pin Code] Playing (input-access-code.wav)
073023.25 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
073025.70 11 dtmf 9   (65697,57,2)
073025.70 11 LsGetNbrsPlayWelcMsg 9
073025.76 11 PlaySoundStop ok
073025.76 11 [S.Enter Pin Code] Number Input 9
073025.76 11 path {9} not found
073025.89 11 dtmf 9   (65697,57,2)
073025.89 11 LsGetNbrsRxDigits 9
073025.89 11 [S.Enter Pin Code] Number Input 99
073025.89 11 path {99} not found
073026.11 11 dtmf 9   (65697,57,2)
073026.11 11 LsGetNbrsRxDigits 9
073026.11 11 [S.Enter Pin Code] Number Input 999
073026.11 11 path {999} not found
073026.62 11 dtmf 8   (65697,56,2)
073026.62 11 LsGetNbrsRxDigits 8
073026.62 11 [S.Enter Pin Code] Number Input 9998
073026.63 11 [Sound Files to orig] Evaluate ["C:\Program Files\VoiceGuide\System\voice"]
073026.63 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice"))
073026.63 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice] stored in $RV[DIRSYSTEMVOICE]
073026.63 11 path {C:\Program Files\VoiceGuide\System\voice} not found
073026.63 11 voicemail used: Scripted
073026.64  0 Script Load C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs
073027.76 11 Loaded C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs into:3
073027.78 11 [VmLoginStart] Running VB Script...
073027.78 11 RVreplace start (strlen>100)
073027.84 11 Run Script waiting... (shellid=3240, process=1580)
073027.88 11 cl    Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminName]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}<<
073027.89 11 [VmLoginAskVmb] Number Input
073027.89 11 RVreplace start: [$RV[VmbLoginIntro],$RV[PathSysVoice]VmbAccessGetVmbIdRetrieve.wav]
073027.89 11 RVreplace end: [none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
073027.90 11 [VmLoginAskVmb] Playing (none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav)
073027.94 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
073029.64 11 dtmf 0   (65697,48,2)
073029.64 11 LsGetNbrsPlayWelcMsg 0
073029.70 11 PlaySoundStop ok
073029.70 11 [VmLoginAskVmb] Number Input 0
073029.70 11 path {0} not found
073029.77 11 dtmf 0   (65697,48,2)
073029.77 11 LsGetNbrsRxDigits 0
073029.78 11 [VmLoginAskVmb] Number Input 00
073029.78 11 path {00} not found
073029.99 11 dtmf 0   (65697,48,2)
073029.99 11 LsGetNbrsRxDigits 0
073029.99 11 [VmLoginAskVmb] Number Input 000
073029.99 11 path {000} not found
073030.60 11 dtmf 1   (65697,49,2)
073030.60 11 LsGetNbrsRxDigits 1
073030.60 11 [VmLoginAskVmb] Number Input 0001
073030.60 11 path {0001} not found
073031.33 11 dtmf #   (65697,35,2)
073031.33 11 LsGetNbrsRxDigits #
073031.33 11 path {0001} not found
073031.33 11 [VmLoginAskPin] Number Input
073031.34 11 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbPin.wav]
073031.34 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
073031.34 11 [VmLoginAskPin] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav)
073031.39 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
073033.98 11 dtmf 5   (65697,53,2)
073033.98 11 LsGetNbrsPlayWelcMsg 5
073034.03 11 PlaySoundStop ok
073034.03 11 [VmLoginAskPin] Number Input 5
073034.04 11 path {5} not found
073034.17 11 dtmf 3   (65697,51,2)
073034.17 11 LsGetNbrsRxDigits 3
073034.17 11 [VmLoginAskPin] Number Input 53
073034.17 11 path {53} not found
073034.68 11 dtmf 9   (65697,57,2)
073034.68 11 LsGetNbrsRxDigits 9
073034.69 11 [VmLoginAskPin] Number Input 539
073034.69 11 path {539} not found
073035.20 11 dtmf 7   (65697,55,2)
073035.20 11 LsGetNbrsRxDigits 7
073035.20 11 [VmLoginAskPin] Number Input 5397
073035.20 11 path {5397} not found
073035.63 11 dtmf #   (65697,35,2)
073035.63 11 LsGetNbrsRxDigits #
073035.63 11 path {5397} not found
073035.63 11 [VmLoginCheckPin] Running VB Script...
073035.64 11 RVreplace start (strlen>100)
073035.69 11 Run Script waiting... (shellid=2988, process=1552)
073035.72  0 cl    Vm_VmbConfig_Get 0001, Pin
073035.73 11 cl    Script_Goto 11, , VmMmMsgCountsCalc, [VmbId]{0001}
073035.73 11 [VmMmMsgCountsCalc] Running VB Script...
073035.73 11 RVreplace start (strlen>100)
073035.79 11 Run Script waiting... (shellid=1040, process=1560)
073035.91 11 cl    Run_ResultReturn >>[VmMsgCount_New]{0}[VmMsgCount_Saved]{0}<<
073035.92 11 RVreplace start: [$RV[VmMsgCount_New]]
073035.92 11 RVreplace end: [0]
073035.92 11 [VmMmMsgCountsPlayNew] Say numbers: 0 as Number
073035.92 11 fn    PlaySoundStartNumbers $RV[PathSysVoice]VmbAccessYouHave.wav, $RV[PathSysVoice]VmbAccessNewMessagesAnd.wav, 0, Number
073035.92 11 RVreplace start: [$RV[PathSysVoice]VmbAccessYouHave.wav]
073035.93 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav]
073035.93 11 RVreplace start: [$RV[PathSysVoice]VmbAccessNewMessagesAnd.wav]
073035.93 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav]
073035.93 11 sVbsFunctionToUse=Number
073036.03 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
073036.07 11 cl    Play_Start C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav,0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav
073036.14 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav,C:\Program Files\VoiceGuide\System\voice\0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav]
073039.75 11 wb(31474002)
073039.80 11 Play End line[11] (id=314740)
073039.81 11 LsSayNbrPlay EV_PLAY_FINISHED
073039.81 11 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
073039.81 11 RVreplace start: [$RV[VmMsgCount_Saved]]
073039.81 11 RVreplace end: [0]
073039.82 11 [VmMmMsgCountsPlaySaved] Say numbers: 0 as Number
073039.82 11 fn    PlaySoundStartNumbers none, $RV[PathSysVoice]VmbAccessSavedMessages.wav, 0, Number
073039.82 11 RVreplace start: [$RV[PathSysVoice]VmbAccessSavedMessages.wav]
073039.82 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessSavedMessages.wav]
073039.83 11 sVbsFunctionToUse=Number
073039.91 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
073039.96 11 cl    Play_Start 0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessSavedMessages.wav
073039.00 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessSavedMessages.wav]
073042.34 11 wb(31863601)
073042.39 11 Play End line[11] (id=318636)
073042.39 11 LsSayNbrPlay EV_PLAY_FINISHED
073042.40 11 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
073042.40 11 [VmMmMenuPlay] Playing
073042.40 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
073042.40 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
073042.40 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav)
073042.44 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
073042.45 11 RunModule PLAY end
073053.30 11 Play End line[11] (id=321069)
073053.30 11 LsPlayMsg EV_PLAY_FINISHED
073055.27 11 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
073055.27 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
073055.27 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
073055.27 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav)
073055.28 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
073055.38 11 dtmf 6   (65697,54,2)
073055.38 11 LsPlayMsg 6
073055.44 11 PlaySoundStop ok
073055.44 11 [VmMmMenu] Running VB Script...
073055.44 11 RVreplace start (strlen>100)
073055.53 11 Run Script waiting... (shellid=2068, process=1564)
073055.58 11 cl    Script_Gosub vmSendMsg.vgs, VmSendRecPrompt, , VmMmMenuPlay
073055.58  0 Script Load C:\Program Files\VoiceGuide\system\vm\vmSendMsg.vgs
073055.66 11 Loaded C:\Program Files\VoiceGuide\system\vm\vmSendMsg.vgs into:4
073055.66 11 [VmSendRecPrompt] Playing
073055.67 11 RVreplace start: [$RV[PathSysVoice]VmSendRecPrompt.wav]
073055.67 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav]
073055.67 11 [VmSendRecPrompt] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav)
073055.72 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav]
073055.72 11 RunModule PLAY end
073102.44 11 wb(33433800)
073102.50 11 Play End line[11] (id=334338)
073102.50 11 LsPlayMsg EV_PLAY_FINISHED
073102.50 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
073102.50 11 [VmSendRec] Recording
073102.54 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\beep1.wav]
073102.74 11 wb(34116800)
073102.79 11 Play End line[11] (id=341168)
073102.79 11 LsRecPlayBeep EV_PLAY_FINISHED
073102.81 11 RecSoundStart file[C:\Program Files\VoiceGuide\system\vm\1128073102_11_.wav] ok
073102.81 11 RecFile[C:\Program Files\VoiceGuide\system\vm\1128073102_11_.wav]
073107.97 11 dtmf #   (65697,35,2)
073107.97 11 LsRecRecording #
073108.03 11 RecSoundStopTruncBytes ok
073108.03 11 rec length RV: VmSendRec_RecLen100ms = 51
073108.04 11 [VmSendMainMenu] Running VB Script...
073108.04 11 RVreplace start (strlen>100)
073108.10 11 Run Script waiting... (shellid=2972, process=1588)
073108.15 11 cl    Script_Goto 11, , VmSendPlayMainMenu,
073108.16 11 [VmSendPlayMainMenu] Playing
073108.16 11 RVreplace start: [$RV[PathSysVoice]VmSendMainMenu.wav]
073108.16 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
073108.16 11 [VmSendPlayMainMenu] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav)
073108.21 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
073108.21 11 RunModule PLAY end
073116.92 11 dtmf 3   (65697,51,2)
073116.92 11 LsPlayMsg 3
073116.98 11 PlaySoundStop ok
073116.98 11 [VmSendMainMenu] Running VB Script...
073116.98 11 RVreplace start (strlen>100)
073117.04 11 Run Script waiting... (shellid=3520, process=1608)
073117.08 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{}
073117.08 11 [VmSendGetDest] Number Input
073117.09 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
073117.09 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
073117.09 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav)
073117.13 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
073121.20 11 dtmf 0   (65697,48,2)
073121.20 11 LsGetNbrsPlayWelcMsg 0
073121.24 11 PlaySoundStop ok
073121.24 11 [VmSendGetDest] Number Input 0
073121.26 11 path {0} not found
073121.34 11 dtmf 0   (65697,48,2)
073121.34 11 LsGetNbrsRxDigits 0
073121.34 11 [VmSendGetDest] Number Input 00
073121.34 11 path {00} not found
073121.56 11 dtmf 0   (65697,48,2)
073121.56 11 LsGetNbrsRxDigits 0
073121.56 11 [VmSendGetDest] Number Input 000
073121.56 11 path {000} not found
073122.17 11 dtmf 2   (65697,50,2)
073122.17 11 LsGetNbrsRxDigits 2
073122.17 11 [VmSendGetDest] Number Input 0002
073122.17 11 path {0002} not found
073123.29 11 dtmf #   (65697,35,2)
073123.29 11 LsGetNbrsRxDigits #
073123.30 11 path {0002} not found
073123.30 11 [VmSendGetDestAndSend] Running VB Script...
073123.30 11 RVreplace start (strlen>100)
073123.38 11 Run Script waiting... (shellid=2244, process=1612)
073123.46 11 cl    RvSet VmSendDestNameWav,
073123.46 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{0002}[VmSendGetDest]{}
073123.47 11 [VmSendGetDest] Number Input
073123.47 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
073123.47 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
073123.47 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav)
073123.49 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
073131.14 11 wb(36214800)
073131.19 11 Play End line[11] (id=362148)
073131.19 11 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
073131.61 11 dtmf #   (65697,35,2)
073131.61 11 LsGetNbrsRxDigits #
073131.61 11 [VmSendGetDestAndSend] Running VB Script...
073131.61 11 RVreplace start (strlen>100)
073131.68 11 Run Script waiting... (shellid=2584, process=1640)
073131.73 11 cl    RvSet VmSendDestNameWav,
073131.73  0 cl    Vm_DistListConfig_Get 0002, list
073132.61 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073132.64 11 task still running (shellid=2584, process=1640)
073133.65 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073133.65 11 task still running (shellid=2584, process=1640)
073134.65 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073134.65 11 task still running (shellid=2584, process=1640)
073135.66 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073135.66 11 task still running (shellid=2584, process=1640)
073136.66 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073136.66 11 task still running (shellid=2584, process=1640)
073137.66 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073137.66 11 task still running (shellid=2584, process=1640)
073138.66 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073138.66 11 task still running (shellid=2584, process=1640)
073139.66 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073139.66 11 task still running (shellid=2584, process=1640)
073140.66 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073140.66 11 task still running (shellid=2584, process=1640)
073141.66 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073141.66 11 task still running (shellid=2584, process=1640)
073142.67 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073142.67 11 task still running (shellid=2584, process=1640)
073143.67 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073143.67 11 task still running (shellid=2584, process=1640)
073144.67 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073144.67 11 task still running (shellid=2584, process=1640)
073145.43 11 dtmf #   (65697,35,2)
073145.43 11 LsRunWaitTillFinished #
073145.43 11 path {#} not found
073145.67 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073145.67 11 task still running (shellid=2584, process=1640)
073146.67 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073146.67 11 task still running (shellid=2584, process=1640)
073147.67 11 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
073147.67 11 task still running (shellid=2584, process=1640)
073148.42 11 callstate DISCONNECTED 65697,0,0
073148.43 11 LsRunWaitTillFinished EV_REMOTEPARTY_DISCONNECT
073148.43 11 Hanging up call...
073148.43 11 RecSoundStop ok
073148.43 11 PlaySoundStop ok
073148.43 11 fnHangupCall end
073148.47 11 linedevstate 2048 0 0
073148.47 11 callstate IDLE 65697 0 0
073148.48 11 WorkingMode@Idle=
073148.66 11 tapi  Reply (LineEvReply) ok 66193 0
073149.57 11 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
073149.57 11 ReinitTelephony due to IDLE start
073149.58 11 tapic lineDeallocateCall(MainCall:65697) 0
073149.75 11 lineOpen(11) => 0
073149.75 11 Waiting for a call...
073149.75 11 lineOpen(11)LineHandle=65835
The voice prompt lists only the most common selections, actual other options available are as listed in Help file.
Please update your v5.1.3 installation with attached VGMULTI.EXE, the new .exe was tested by us and it resolved the problem you have encountered.
VgMulti.zip
Still does not send the phone message
Heres the log
083137.28 11 linedevstate 2048 0 0
083137.31 11 callstate OFFERING 65697 0 4
083137.31 11 Could not obtain handle to kill process. (new call) 3268, 1628
083137.35 11 Answer the call at 29/11/2003 08:31:37
083137.39 11 lineAnswer(65697) => 65680
083137.39 11 callinfo CALLEDID
083137.40 11 callinfo ORIGIN
083137.40 11 ring 0
083137.94 11 callstate CONNECTED 65697,1,0
083137.94 11 WorkingModeTAPI@Connected=
083137.95 11 WorkingModeScript@Connected=
083137.98 11 Inband detection not enabled
083137.98 11 StartLoadedVgs at 29/11/2003 08:31:37
083137.98 11 tapi  Reply (LineEvReply) ok 65680 0
083137.99 11 [Set Sound Files] Evaluate ["C:\Program Files\VoiceGuide\System\voice_sue"]
083137.99 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_sue"))
083137.99 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_sue] stored in $RV[DIRSYSTEMVOICE]
083137.99 11 path {C:\Program Files\VoiceGuide\System\voice_sue} not found
083138.00 11 [S.Enter Pin Code] Number Input
083138.00 11 [S.Enter Pin Code] Playing (input-access-code.wav)
083138.18 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
083140.20 11 dtmf 9   (65697,57,2)
083140.20 11 LsGetNbrsPlayWelcMsg 9
083140.25 11 PlaySoundStop ok
083140.25 11 [S.Enter Pin Code] Number Input 9
083140.25 11 path {9} not found
083140.37 11 dtmf 9   (65697,57,2)
083140.38 11 LsGetNbrsRxDigits 9
083140.38 11 [S.Enter Pin Code] Number Input 99
083140.38 11 path {99} not found
083140.60 11 dtmf 9   (65697,57,2)
083140.60 11 LsGetNbrsRxDigits 9
083140.61 11 [S.Enter Pin Code] Number Input 999
083140.61 11 path {999} not found
083141.07 11 dtmf 8   (65697,56,2)
083141.07 11 LsGetNbrsRxDigits 8
083141.07 11 [S.Enter Pin Code] Number Input 9998
083141.08 11 [Sound Files to orig] Evaluate ["C:\Program Files\VoiceGuide\System\voice"]
083141.08 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice"))
083141.08 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice] stored in $RV[DIRSYSTEMVOICE]
083141.08 11 path {C:\Program Files\VoiceGuide\System\voice} not found
083141.08 11 voicemail used: Scripted
083141.08  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=3
083141.09 11 [VmLoginStart] Running VB Script...
083141.09 11 RVreplace start (strlen>100)
083142.07 11 Run Script waiting... (shellid=2484, process=1608)
083142.58 11 cl    Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminName]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}<<
083142.59 11 [VmLoginAskVmb] Number Input
083142.59 11 RVreplace start: [$RV[VmbLoginIntro],$RV[PathSysVoice]VmbAccessGetVmbIdRetrieve.wav]
083142.60 11 RVreplace end: [none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
083142.60 11 [VmLoginAskVmb] Playing (none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav)
083142.71 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
083143.96 11 dtmf 0   (65697,48,2)
083143.96 11 LsGetNbrsPlayWelcMsg 0
083144.01 11 PlaySoundStop ok
083144.01 11 [VmLoginAskVmb] Number Input 0
083144.01 11 path {0} not found
083144.12 11 dtmf 0   (65697,48,2)
083144.13 11 LsGetNbrsRxDigits 0
083144.13 11 [VmLoginAskVmb] Number Input 00
083144.13 11 path {00} not found
083144.42 11 dtmf 0   (65697,48,2)
083144.43 11 LsGetNbrsRxDigits 0
083144.43 11 [VmLoginAskVmb] Number Input 000
083144.43 11 path {000} not found
083144.96 11 dtmf 1   (65697,49,2)
083144.96 11 LsGetNbrsRxDigits 1
083144.97 11 [VmLoginAskVmb] Number Input 0001
083144.97 11 path {0001} not found
083145.84 11 dtmf #   (65697,35,2)
083145.84 11 LsGetNbrsRxDigits #
083145.84 11 path {0001} not found
083145.84 11 [VmLoginAskPin] Number Input
083145.84 11 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbPin.wav]
083145.84 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
083145.85 11 [VmLoginAskPin] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav)
083145.88 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
083146.13 11 dtmf #   (65697,35,2)
083146.13 11 LsGetNbrsPlayWelcMsg #
083146.20 11 PlaySoundStop ok
083146.21 11 [VmLoginAskPin] Number Input
083146.21 11 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbPin.wav]
083146.21 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
083146.21 11 [VmLoginAskPin] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav)
083146.23 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
083146.39 11 callstate DISCONNECTED 65697,0,0
083146.39 11 LsGetNbrsPlayWelcMsg EV_REMOTEPARTY_DISCONNECT
083146.39 11 Hanging up call...
083146.39 11 RecSoundStop ok
083146.44 11 PlaySoundStop ok
083146.45 11 fnHangupCall end
083146.50 11 linedevstate 2048 0 0
083146.50 11 callstate IDLE 65697 0 0
083146.50 11 WorkingMode@Idle=
083146.00 11 tapi  Reply (LineEvReply) ok 65833 0
083147.90 11 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
083147.90 11 ReinitTelephony due to IDLE start
083147.91 11 tapic lineDeallocateCall(MainCall:65697) 0
083148.08 11 lineOpen(11) => 0
083148.08 11 Waiting for a call...
083148.08 11 lineOpen(11)LineHandle=65661
083200.07 11 linedevstate 2048 0 0
083200.07 11 callstate OFFERING 65560 0 4
083200.07 11 Could not obtain handle to kill process. (new call) 2484, 1608
083200.07 11 Answer the call at 29/11/2003 08:32:00
083200.10 11 lineAnswer(65560) => 66157
083200.10 11 callinfo CALLEDID
083200.11 11 callinfo ORIGIN
083200.11 11 ring 0
083200.63 11 callstate CONNECTED 65560,1,0
083200.64 11 WorkingModeTAPI@Connected=
083200.64 11 WorkingModeScript@Connected=
083200.68 11 Inband detection not enabled
083200.68 11 StartLoadedVgs at 29/11/2003 08:32:00
083200.68 11 tapi  Reply (LineEvReply) ok 66157 0
083200.68 11 [Set Sound Files] Evaluate ["C:\Program Files\VoiceGuide\System\voice_sue"]
083200.68 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_sue"))
083200.69 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_sue] stored in $RV[DIRSYSTEMVOICE]
083200.69 11 path {C:\Program Files\VoiceGuide\System\voice_sue} not found
083200.69 11 [S.Enter Pin Code] Number Input
083200.69 11 [S.Enter Pin Code] Playing (input-access-code.wav)
083200.71 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
083201.88 11 dtmf 9   (65560,57,2)
083201.88 11 LsGetNbrsPlayWelcMsg 9
083201.93 11 PlaySoundStop ok
083201.93 11 [S.Enter Pin Code] Number Input 9
083201.93 11 path {9} not found
083202.10 11 dtmf 9   (65560,57,2)
083202.11 11 LsGetNbrsRxDigits 9
083202.11 11 [S.Enter Pin Code] Number Input 99
083202.11 11 path {99} not found
083202.33 11 dtmf 9   (65560,57,2)
083202.33 11 LsGetNbrsRxDigits 9
083202.33 11 [S.Enter Pin Code] Number Input 999
083202.34 11 path {999} not found
083202.68 11 dtmf 8   (65560,56,2)
083202.68 11 LsGetNbrsRxDigits 8
083202.68 11 [S.Enter Pin Code] Number Input 9998
083202.68 11 [Sound Files to orig] Evaluate ["C:\Program Files\VoiceGuide\System\voice"]
083202.69 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice"))
083202.69 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice] stored in $RV[DIRSYSTEMVOICE]
083202.69 11 path {C:\Program Files\VoiceGuide\System\voice} not found
083202.69 11 voicemail used: Scripted
083202.69  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=3
083202.70 11 [VmLoginStart] Running VB Script...
083202.70 11 RVreplace start (strlen>100)
083202.76 11 Run Script waiting... (shellid=2536, process=1584)
083202.80 11 cl    Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminName]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}<<
083202.81 11 [VmLoginAskVmb] Number Input
083202.81 11 RVreplace start: [$RV[VmbLoginIntro],$RV[PathSysVoice]VmbAccessGetVmbIdRetrieve.wav]
083202.82 11 RVreplace end: [none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
083202.82 11 [VmLoginAskVmb] Playing (none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav)
083202.87 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
083204.89 11 dtmf 0   (65560,48,2)
083204.89 11 LsGetNbrsPlayWelcMsg 0
083204.94 11 PlaySoundStop ok
083204.94 11 [VmLoginAskVmb] Number Input 0
083204.95 11 path {0} not found
083205.11 11 dtmf 0   (65560,48,2)
083205.11 11 LsGetNbrsRxDigits 0
083205.11 11 [VmLoginAskVmb] Number Input 00
083205.12 11 path {00} not found
083205.33 11 dtmf 0   (65560,48,2)
083205.33 11 LsGetNbrsRxDigits 0
083205.33 11 [VmLoginAskVmb] Number Input 000
083205.33 11 path {000} not found
083206.19 11 dtmf 1   (65560,49,2)
083206.19 11 LsGetNbrsRxDigits 1
083206.19 11 [VmLoginAskVmb] Number Input 0001
083206.19 11 path {0001} not found
083206.79 11 dtmf #   (65560,35,2)
083206.79 11 LsGetNbrsRxDigits #
083206.79 11 path {0001} not found
083206.79 11 [VmLoginAskPin] Number Input
083206.79 11 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbPin.wav]
083206.79 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
083206.79 11 [VmLoginAskPin] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav)
083206.81 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
083208.34 11 dtmf 5   (65560,53,2)
083208.34 11 LsGetNbrsPlayWelcMsg 5
083208.39 11 PlaySoundStop ok
083208.39 11 [VmLoginAskPin] Number Input 5
083208.39 11 path {5} not found
083208.69 11 dtmf 3   (65560,51,2)
083208.69 11 LsGetNbrsRxDigits 3
083208.70 11 [VmLoginAskPin] Number Input 53
083208.70 11 path {53} not found
083209.23 11 dtmf 9   (65560,57,2)
083209.23 11 LsGetNbrsRxDigits 9
083209.24 11 [VmLoginAskPin] Number Input 539
083209.24 11 path {539} not found
083209.65 11 dtmf 7   (65560,55,2)
083209.65 11 LsGetNbrsRxDigits 7
083209.65 11 [VmLoginAskPin] Number Input 5397
083209.66 11 path {5397} not found
083209.96 11 dtmf #   (65560,35,2)
083209.96 11 LsGetNbrsRxDigits #
083209.97 11 path {5397} not found
083209.97 11 [VmLoginCheckPin] Running VB Script...
083209.97 11 RVreplace start (strlen>100)
083210.05 11 Run Script waiting... (shellid=2540, process=1616)
083210.11  0 cl    Vm_VmbConfig_Get 0001, Pin
083210.17 11 cl    Script_Goto 11, , VmMmMsgCountsCalc, [VmbId]{0001}
083210.17 11 [VmMmMsgCountsCalc] Running VB Script...
083210.17 11 RVreplace start (strlen>100)
083210.27 11 Run Script waiting... (shellid=3080, process=1656)
083210.81 11 cl    Run_ResultReturn >>[VmMsgCount_New]{0}[VmMsgCount_Saved]{0}<<
083210.81 11 RVreplace start: [$RV[VmMsgCount_New]]
083210.82 11 RVreplace end: [0]
083210.82 11 [VmMmMsgCountsPlayNew] Say numbers: 0 as Number
083210.82 11 fn    PlaySoundStartNumbers $RV[PathSysVoice]VmbAccessYouHave.wav, $RV[PathSysVoice]VmbAccessNewMessagesAnd.wav, 0, Number
083210.82 11 RVreplace start: [$RV[PathSysVoice]VmbAccessYouHave.wav]
083210.82 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav]
083210.82 11 RVreplace start: [$RV[PathSysVoice]VmbAccessNewMessagesAnd.wav]
083210.83 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav]
083210.87 11 sVbsFunctionToUse=Number
083211.01 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
083211.09 11 cl    Play_Start C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav,0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav
083211.34 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav,C:\Program Files\VoiceGuide\System\voice\0.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav]
083213.34 11 dtmf 6   (65560,54,2)
083213.34 11 LsSayNbrPlay 6
083213.39 11 PlaySoundStop ok
083213.39 11 [VmMmMenu] Running VB Script...
083213.39 11 RVreplace start (strlen>100)
083213.59 11 Run Script waiting... (shellid=1988, process=1424)
083213.69 11 cl    Script_Gosub vmSendMsg.vgs, VmSendRecPrompt, , VmMmMenuPlay
083213.69  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\vmSendMsg.vgs at idx=4
083213.69 11 [VmSendRecPrompt] Playing
083213.70 11 RVreplace start: [$RV[PathSysVoice]VmSendRecPrompt.wav]
083213.70 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav]
083213.70 11 [VmSendRecPrompt] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav)
083213.79 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav]
083213.80 11 RunModule PLAY end
083220.53 11 wb(83939500)
083220.57 11 Play End line[11] (id=839395)
083220.57 11 LsPlayMsg EV_PLAY_FINISHED
083220.59 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
083220.59 11 [VmSendRec] Recording
083220.65 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\beep1.wav]
083220.86 11 wb(84627500)
083220.90 11 Play End line[11] (id=846275)
083220.90 11 LsRecPlayBeep EV_PLAY_FINISHED
083220.93 11 RecSoundStart file[C:\Program Files\VoiceGuide\system\vm\1129083220_11_.wav] ok
083220.93 11 RecFile[C:\Program Files\VoiceGuide\system\vm\1129083220_11_.wav]
083223.39 11 dtmf #   (65560,35,2)
083223.39 11 LsRecRecording #
083223.44 11 RecSoundStopTruncBytes ok
083223.44 11 rec length RV: VmSendRec_RecLen100ms = 24
083223.45 11 [VmSendMainMenu] Running VB Script...
083223.45 11 RVreplace start (strlen>100)
083223.56 11 Run Script waiting... (shellid=3736, process=1644)
083223.62 11 cl    Script_Goto 11, , VmSendPlayMainMenu,
083223.62 11 [VmSendPlayMainMenu] Playing
083223.62 11 RVreplace start: [$RV[PathSysVoice]VmSendMainMenu.wav]
083223.62 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
083223.62 11 [VmSendPlayMainMenu] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav)
083223.71 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
083223.71 11 RunModule PLAY end
083230.65 11 dtmf 3   (65560,51,2)
083230.65 11 LsPlayMsg 3
083230.71 11 PlaySoundStop ok
083230.71 11 [VmSendMainMenu] Running VB Script...
083230.71 11 RVreplace start (strlen>100)
083230.80 11 Run Script waiting... (shellid=2932, process=1452)
083230.86 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{}
083230.86 11 [VmSendGetDest] Number Input
083230.87 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
083230.87 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
083230.87 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav)
083230.97 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
083238.65 11 Play End line[11] (id=856560)
083238.65 11 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
083239.36 11 dtmf 0   (65560,48,2)
083239.36 11 LsGetNbrsRxDigits 0
083239.36 11 [VmSendGetDest] Number Input 0
083239.36 11 path {0} not found
083239.71 11 dtmf 0   (65560,48,2)
083239.71 11 LsGetNbrsRxDigits 0
083239.71 11 [VmSendGetDest] Number Input 00
083239.71 11 path {00} not found
083240.10 11 dtmf 0   (65560,48,2)
083240.10 11 LsGetNbrsRxDigits 0
083240.10 11 [VmSendGetDest] Number Input 000
083240.11 11 path {000} not found
083240.64 11 dtmf 2   (65560,50,2)
083240.64 11 LsGetNbrsRxDigits 2
083240.64 11 [VmSendGetDest] Number Input 0002
083240.65 11 path {0002} not found
083241.69 11 dtmf #   (65560,35,2)
083241.69 11 LsGetNbrsRxDigits #
083241.70 11 path {0002} not found
083241.70 11 [VmSendGetDestAndSend] Running VB Script...
083241.70 11 RVreplace start (strlen>100)
083241.82 11 Run Script waiting... (shellid=3424, process=1440)
083241.94 11 cl    RvSet VmSendDestNameWav,
083241.95 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{0002}[VmSendGetDest]{}
083241.95 11 [VmSendGetDest] Number Input
083241.96 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
083241.96 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
083241.96 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav)
083241.97 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
083249.65 11 wb(86764600)
083249.71 11 Play End line[11] (id=867646)
083249.71 11 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
083250.16 11 dtmf #   (65560,35,2)
083250.16 11 LsGetNbrsRxDigits #
083250.17 11 [VmSendGetDestAndSend] Running VB Script...
083250.17 11 RVreplace start (strlen>100)
083250.28 11 Run Script waiting... (shellid=2172, process=164)
083250.36 11 cl    RvSet VmSendDestNameWav,
083250.36  0 cl    Vm_DistListConfig_Get 0002, list
083250.36 11 vms   dist list [0002] not found
083250.37 11 vms   copy vm to:C:\Program Files\VoiceGuide\data\VmSave\0002_1129083250_1_11__0001.wav
083250.41 11 cl    Vm_ForwardMsg 11, 0002, C:\Program Files\VoiceGuide\data\VmSave\0002_1129083250_1_11__0001.wav
083250.41 11 vm    frwrd vmb 0002
083250.41 11 vm    frwrd phone: 0034661180060 (scripted system)
083250.42  0 DialListDB_AddCall '0034661180060', 0, 1, 2359, MoTuWeThFrSaSu, C:\Program Files\VoiceGuide\System\voice\VmbForwardAskAccept.wav, C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs|VmDelivStart, C:\Program Files\VoiceGuide\data\VmSave\0002_1129083250_1_11__0001.wav, [PathSysVoice]{C:\Program Files\VoiceGuide\System\voice\}[VmbId]{0002}[VmFileToPlay]{0002_1129083250_1_11__0001.wav}, 60, 2, 5,  ESCALATION:
083250.42 11 RVreplace start: [Voicemail received from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_NN on $RV_DATE $RV_MONTHNAME]
083250.43 11 RVreplace end: [Voicemail received from ,  at 8:32 on 29 November]
083250.43 11 RVreplace start (strlen>100)
083250.43 11 RVreplace end: [Voicemail received from: ,
on 29 November at 08:32:50
Voicemail box: 0001
083250.46 11 vm    frwrd vmb 0002 email to 0002@health4us.co.uk (wav attached)
083250.46 11 vm    frwrd vmb 0002 end
083250.95 11 cl    Script_Goto 11, , VmSendPlaySuccess, [VmSendRec]{}
083250.96 11 [VmSendPlaySuccess] Playing
083250.96 11 RVreplace start: [$RV[PathSysVoice]VmSendSuccess.wav]
083250.96 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav]
083250.96 11 [VmSendPlaySuccess] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav)
083251.01 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav]
083251.01 11 RunModule PLAY end
083253.74 11 wb(87664900)
083253.74 11 Play End line[11] (id=876649)
083253.74 11 LsPlayMsg EV_PLAY_FINISHED
083253.75 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
083254.03  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=3
083254.03 11 [VmMmMenuPlay] Playing
083254.04 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
083254.04 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
083254.04 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav)
083254.09 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
083254.10 11 RunModule PLAY end
083259.48 11 callstate DISCONNECTED 65560,0,0
083259.49 11 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
083259.49 11 Hanging up call...
083259.49 11 RecSoundStop ok
083259.54 11 PlaySoundStop ok
083259.55 11 fnHangupCall end
083259.60 11 linedevstate 2048 0 0
083259.61 11 callstate IDLE 65560 0 0
083259.61 11 WorkingMode@Idle=
083259.65 11 tapi  Reply (LineEvReply) ok 66019 0
083300.55 11 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
083300.55 11 ReinitTelephony due to IDLE start
083300.55 11 tapic lineDeallocateCall(MainCall:65560) 0
083300.73 11 lineOpen(11) => 0
083300.73 11 Waiting for a call...
083300.73 11 lineOpen(11)LineHandle=66432
Looks like for some reason the "DialListDB_AddCall" function does not work on your system...
The trace should look like this (notice the dial callque statements after the DialListDB_AddCall command):
115641.20  6 vm    frwrd vmb 0002
115641.20  6 vm    frwrd phone: 19 (scripted system)
115641.20  0 DialListDB_AddCall '19', 0, 1, 2359, MoTuWeThFrSaSu, C:\ProjectsBak\vg32 5.1.3\system\voice\VmbForwardAskAccept.wav, C:\ProjectsBak\vg32 5.1.3\system\vm\vmMsgDeliver.vgs|VmDelivStart, C:\ProjectsBak\vg32 5.1.3\system\vm\vmMsgDeliver.vgs|VmDelivAMStart, [PathSysVoice]{C:\ProjectsBak\vg32 5.1.3\system\voice\}[VmbId]{0002}[VmFileToPlay]{0002_1130115641_1_6__0001.wav}, 60, 2, 5,  ESCALATION:
115641.34  6 vm    frwrd vmb 0002 end
115641.36  0 dial  callque update id=4 next call time 0311301201
115641.36  0 dial  callque DB update returned
115641.36  7 dial  found entry: tel[19] ann[C:\ProjectsBak\vg32 5.1.3\system\voice\VmbForwardAskAccept.wav] vgs[C:\ProjectsBak\vg32 5.1.3\system\vm\vmMsgDeliver.vgs|VmDelivStart] am[C:\ProjectsBak\vg32 5.1.3\system\vm\vmMsgDeliver.vgs|VmDelivAMStart]
115641.42  7 Calling  MakeCallEx(19)
115641.42  7 Dialing: 19
The trace above was taken using the same VGMULTI.EXE that was attached in previous post...
Please delete the file OutDialQue.mdb in VoiceGuide's \data\ subdirectory and then please update your v5.1.3 installation with attached VGMULTI.EXE.
This new .exe has more tracing messages around the area of code which inserts data into the OutDialQue.mdb queue... from previous posts I see that you mention that this database never has any entries added into it on your system - so it looks like that is the area where the problem lies...
VgMulti.zip
Thanks for this... now the outbound call is made but no sound is played when the call is answered.. There is an error message saying that vbs_12_2.vbs - path not found Line
074403.03 11 linedevstate 2048 0 0
074403.03 11 callstate OFFERING 65666 0 4
074403.03 11 Answer the call at 01/12/2003 07:44:03
074403.05 11 lineAnswer(65666) => 66094
074403.05 11 callinfo CALLEDID
074403.05 11 callinfo ORIGIN
074403.05 11 ring 0
074403.58 11 callstate CONNECTED 65666,1,0
074403.58 11 WorkingModeTAPI@Connected=
074403.59 11 WorkingModeScript@Connected=
074403.62 11 Inband detection not enabled
074403.63 11 StartLoadedVgs at 01/12/2003 07:44:03
074403.63 11 tapi  Reply (LineEvReply) ok 66094 0
074403.63 11 [Set Sound Files] Evaluate ["C:\Program Files\VoiceGuide\System\voice_sue"]
074403.63 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_sue"))
074403.63 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_sue] stored in $RV[DIRSYSTEMVOICE]
074403.63 11 path {C:\Program Files\VoiceGuide\System\voice_sue} not found
074403.63 11 [S.Enter Pin Code] Number Input
074403.63 11 [S.Enter Pin Code] Playing (input-access-code.wav)
074403.66 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
074405.02 11 dtmf 9   (65666,57,2)
074405.02 11 LsGetNbrsPlayWelcMsg 9
074405.07 11 PlaySoundStop ok
074405.07 11 [S.Enter Pin Code] Number Input 9
074405.07 11 path {9} not found
074405.16 11 dtmf 9   (65666,57,2)
074405.16 11 LsGetNbrsRxDigits 9
074405.16 11 [S.Enter Pin Code] Number Input 99
074405.16 11 path {99} not found
074405.38 11 dtmf 9   (65666,57,2)
074405.38 11 LsGetNbrsRxDigits 9
074405.39 11 [S.Enter Pin Code] Number Input 999
074405.39 11 path {999} not found
074405.71 11 dtmf 8   (65666,56,2)
074405.71 11 LsGetNbrsRxDigits 8
074405.71 11 [S.Enter Pin Code] Number Input 9998
074405.71 11 [Sound Files to orig] Evaluate ["C:\Program Files\VoiceGuide\System\voice"]
074405.71 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice"))
074405.71 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice] stored in $RV[DIRSYSTEMVOICE]
074405.72 11 path {C:\Program Files\VoiceGuide\System\voice} not found
074405.72 11 voicemail used: Scripted
074405.72  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=3
074405.72 11 [VmLoginStart] Running VB Script...
074405.72 11 RVreplace start (strlen>100)
074405.78 11 Run Script waiting... (shellid=3456, process=160)
074405.82 11 cl    Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminName]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}<<
074405.83 11 [VmLoginAskVmb] Number Input
074405.83 11 RVreplace start: [$RV[VmbLoginIntro],$RV[PathSysVoice]VmbAccessGetVmbIdRetrieve.wav]
074405.83 11 RVreplace end: [none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
074405.84 11 [VmLoginAskVmb] Playing (none,C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav)
074405.86 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbIdRetrieve.wav]
074409.40 11 dtmf 0   (65666,48,2)
074409.40 11 LsGetNbrsPlayWelcMsg 0
074409.45 11 PlaySoundStop ok
074409.45 11 [VmLoginAskVmb] Number Input 0
074409.46 11 path {0} not found
074409.58 11 dtmf 0   (65666,48,2)
074409.58 11 LsGetNbrsRxDigits 0
074409.58 11 [VmLoginAskVmb] Number Input 00
074409.58 11 path {00} not found
074409.83 11 dtmf 0   (65666,48,2)
074409.83 11 LsGetNbrsRxDigits 0
074409.83 11 [VmLoginAskVmb] Number Input 000
074409.83 11 path {000} not found
074410.19 11 dtmf 1   (65666,49,2)
074410.19 11 LsGetNbrsRxDigits 1
074410.19 11 [VmLoginAskVmb] Number Input 0001
074410.19 11 path {0001} not found
074415.57 11 dtmf #   (65666,35,2)
074415.57 11 LsGetNbrsRxDigits #
074415.57 11 path {0001} not found
074415.57 11 [VmLoginAskPin] Number Input
074415.57 11 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbPin.wav]
074415.57 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
074415.58 11 [VmLoginAskPin] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav)
074415.60 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessGetVmbPin.wav]
074416.74 11 dtmf 5   (65666,53,2)
074416.74 11 LsGetNbrsPlayWelcMsg 5
074416.80 11 PlaySoundStop ok
074416.80 11 [VmLoginAskPin] Number Input 5
074416.80 11 path {5} not found
074416.97 11 dtmf 3   (65666,51,2)
074416.97 11 LsGetNbrsRxDigits 3
074416.97 11 [VmLoginAskPin] Number Input 53
074416.97 11 path {53} not found
074417.42 11 dtmf 9   (65666,57,2)
074417.42 11 LsGetNbrsRxDigits 9
074417.43 11 [VmLoginAskPin] Number Input 539
074417.43 11 path {539} not found
074417.78 11 dtmf 7   (65666,55,2)
074417.78 11 LsGetNbrsRxDigits 7
074417.79 11 [VmLoginAskPin] Number Input 5397
074417.79 11 path {5397} not found
074418.13 11 dtmf #   (65666,35,2)
074418.13 11 LsGetNbrsRxDigits #
074418.13 11 path {5397} not found
074418.13 11 [VmLoginCheckPin] Running VB Script...
074418.14 11 RVreplace start (strlen>100)
074418.19 11 Run Script waiting... (shellid=2424, process=1628)
074418.24  0 cl    Vm_VmbConfig_Get 0001, Pin
074418.24 11 cl    Script_Goto 11, , VmMmMsgCountsCalc, [VmbId]{0001}
074418.24 11 [VmMmMsgCountsCalc] Running VB Script...
074418.24 11 RVreplace start (strlen>100)
074418.31 11 Run Script waiting... (shellid=3928, process=156)
074418.41 11 cl    Run_ResultReturn >>[VmMsgCount_New]{1}[VmMsgCount_Saved]{0}<<
074418.41 11 RVreplace start: [$RV[VmMsgCount_New]]
074418.41 11 RVreplace end: [1]
074418.43 11 [VmMmMsgCountsPlayNew] Say numbers: 1 as Number
074418.43 11 fn    PlaySoundStartNumbers $RV[PathSysVoice]VmbAccessYouHave.wav, $RV[PathSysVoice]VmbAccessNewMessagesAnd.wav, 1, Number
074418.43 11 RVreplace start: [$RV[PathSysVoice]VmbAccessYouHave.wav]
074418.43 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav]
074418.43 11 RVreplace start: [$RV[PathSysVoice]VmbAccessNewMessagesAnd.wav]
074418.44 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav]
074418.44 11 sVbsFunctionToUse=Number
074418.53 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
074418.56 11 cl    Play_Start C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav,1.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav
074418.59 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessYouHave.wav,C:\Program Files\VoiceGuide\System\voice\1.wav,C:\Program Files\VoiceGuide\System\voice\VmbAccessNewMessagesAnd.wav]
074420.43 11 dtmf 6   (65666,54,2)
074420.43 11 LsSayNbrPlay 6
074420.49 11 PlaySoundStop ok
074420.49 11 [VmMmMenu] Running VB Script...
074420.49 11 RVreplace start (strlen>100)
074420.59 11 Run Script waiting... (shellid=4708, process=1744)
074420.64 11 cl    Script_Gosub vmSendMsg.vgs, VmSendRecPrompt, , VmMmMenuPlay
074420.64  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\vmSendMsg.vgs at idx=4
074420.65 11 [VmSendRecPrompt] Playing
074420.65 11 RVreplace start: [$RV[PathSysVoice]VmSendRecPrompt.wav]
074420.65 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav]
074420.65 11 [VmSendRecPrompt] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav)
074420.67 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendRecPrompt.wav]
074420.67 11 RunModule PLAY end
074427.42 11 wb(76632700)
074427.47 11 Play End line[11] (id=766327)
074427.47 11 LsPlayMsg EV_PLAY_FINISHED
074427.47 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
074427.47 11 [VmSendRec] Recording
074427.49 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\beep1.wav]
074427.70 11 wb(77314700)
074427.75 11 Play End line[11] (id=773147)
074427.75 11 LsRecPlayBeep EV_PLAY_FINISHED
074427.76 11 RecSoundStart file[C:\Program Files\VoiceGuide\system\vm\1201074427_11_.wav] ok
074427.76 11 RecFile[C:\Program Files\VoiceGuide\system\vm\1201074427_11_.wav]
074430.16 11 dtmf #   (65666,35,2)
074430.16 11 LsRecRecording #
074430.21 11 RecSoundStopTruncBytes ok
074430.21 11 rec length RV: VmSendRec_RecLen100ms = 23
074430.22 11 [VmSendMainMenu] Running VB Script...
074430.22 11 RVreplace start (strlen>100)
074430.29 11 Run Script waiting... (shellid=3704, process=1652)
074430.34 11 cl    Script_Goto 11, , VmSendPlayMainMenu,
074430.34 11 [VmSendPlayMainMenu] Playing
074430.34 11 RVreplace start: [$RV[PathSysVoice]VmSendMainMenu.wav]
074430.34 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
074430.35 11 [VmSendPlayMainMenu] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav)
074430.37 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendMainMenu.wav]
074430.37 11 RunModule PLAY end
074433.95 11 dtmf 3   (65666,51,2)
074433.95 11 LsPlayMsg 3
074434.01 11 PlaySoundStop ok
074434.01 11 [VmSendMainMenu] Running VB Script...
074434.01 11 RVreplace start (strlen>100)
074434.07 11 Run Script waiting... (shellid=3184, process=1728)
074434.12 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{}
074434.13 11 [VmSendGetDest] Number Input
074434.13 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
074434.13 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
074434.13 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav)
074434.15 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
074441.83 11 Play End line[11] (id=779816)
074441.83 11 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
074442.59 11 dtmf 9   (65666,57,2)
074442.59 11 LsGetNbrsRxDigits 9
074442.59 11 [VmSendGetDest] Number Input 9
074442.59 11 path {9} not found
074443.21 11 dtmf 9   (65666,57,2)
074443.21 11 LsGetNbrsRxDigits 9
074443.22 11 [VmSendGetDest] Number Input 99
074443.22 11 path {99} not found
074443.97 11 dtmf 9   (65666,57,2)
074443.97 11 LsGetNbrsRxDigits 9
074443.97 11 [VmSendGetDest] Number Input 999
074443.97 11 path {999} not found
074444.67 11 dtmf 9   (65666,57,2)
074444.68 11 LsGetNbrsRxDigits 9
074444.68 11 [VmSendGetDest] Number Input 9999
074444.68 11 path {9999} not found
074445.56 11 dtmf #   (65666,35,2)
074445.56 11 LsGetNbrsRxDigits #
074445.56 11 path {9999} not found
074445.57 11 [VmSendGetDestAndSend] Running VB Script...
074445.57 11 RVreplace start (strlen>100)
074445.64 11 Run Script waiting... (shellid=4172, process=1748)
074445.70 11 cl    RvSet VmSendDestNameWav,
074445.70 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{9999}[VmSendGetDest]{}
074445.71 11 [VmSendGetDest] Number Input
074445.71 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
074445.71 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
074445.71 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav)
074445.73 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendGetNextDest.wav]
074451.89 11 dtmf #   (65666,35,2)
074451.89 11 LsGetNbrsPlayWelcMsg #
074451.94 11 PlaySoundStop ok
074451.94 11 [VmSendGetDestAndSend] Running VB Script...
074451.94 11 RVreplace start (strlen>100)
074452.01 11 Run Script waiting... (shellid=3080, process=1792)
074452.07 11 cl    RvSet VmSendDestNameWav,
074452.07  0 cl    Vm_DistListConfig_Get 9999, list
074452.07 11 vms   dist list [9999] => [0001,0002]
074452.08 11 vms   copy vm to:C:\Program Files\VoiceGuide\data\VmSave\0001_1201074452_1_11__0001.wav
074452.09 11 cl    Vm_ForwardMsg 11, 0001, C:\Program Files\VoiceGuide\data\VmSave\0001_1201074452_1_11__0001.wav
074452.09 11 vm    frwrd vmb 0001
074452.10 11 vm    frwrd phone: 323156 (scripted system)
074452.10  0 dial  DialListDB_AddCall '323156', 0, 1, 2359, MoTuWeThFrSaSu, C:\Program Files\VoiceGuide\System\voice\VmbForwardAskAccept.wav, C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs|VmDelivStart, C:\Program Files\VoiceGuide\data\VmSave\0001_1201074452_1_11__0001.wav, [PathSysVoice]{C:\Program Files\VoiceGuide\System\voice\}[VmbId]{0001}[VmFileToPlay]{0001_1201074452_1_11__0001.wav}, 60, 2, 5,  ESCALATION:
074452.10 11 dial  DialListDB_AddCall insert ok
074452.11 11 RVreplace start: [Voicemail received from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_NN on $RV_DATE $RV_MONTHNAME]
074452.11 11 RVreplace end: [Voicemail received from ,  at 7:44 on 1 December]
074452.11 11 RVreplace start (strlen>100)
074452.11 11 RVreplace end: [Voicemail received from: ,
on 1 December at 07:44:52
Voicemail box: 0001
074452.12 11 vm    frwrd vmb 0001 email to 0001@health4us.co.uk (wav attached)
074452.12 11 vm    frwrd vmb 0001 end
074452.12 11 vms   copy vm to:C:\Program Files\VoiceGuide\data\VmSave\0002_1201074452_1_11__0001.wav
074452.13 11 cl    Vm_ForwardMsg 11, 0002, C:\Program Files\VoiceGuide\data\VmSave\0002_1201074452_1_11__0001.wav
074452.14 11 vm    frwrd vmb 0002
074452.14 11 vm    frwrd phone: 0034661180060 (scripted system)
074452.14  0 dial  DialListDB_AddCall '0034661180060', 0, 1, 2359, MoTuWeThFrSaSu, C:\Program Files\VoiceGuide\System\voice\VmbForwardAskAccept.wav, C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs|VmDelivStart, C:\Program Files\VoiceGuide\data\VmSave\0002_1201074452_1_11__0001.wav, [PathSysVoice]{C:\Program Files\VoiceGuide\System\voice\}[VmbId]{0002}[VmFileToPlay]{0002_1201074452_1_11__0001.wav}, 60, 2, 5,  ESCALATION:
074452.15 11 dial  DialListDB_AddCall insert ok
074452.15 11 RVreplace start: [Voicemail received from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_NN on $RV_DATE $RV_MONTHNAME]
074452.15 11 RVreplace end: [Voicemail received from ,  at 7:44 on 1 December]
074452.15 11 RVreplace start (strlen>100)
074452.16 11 RVreplace end: [Voicemail received from: ,
Voicemail box: 0001
074452.16 11 vm    frwrd vmb 0002 email to 0002@health4us.co.uk (wav attached)
074452.17 11 vm    frwrd vmb 0002 end
074452.22 11 cl    Script_Goto 11, , VmSendPlaySuccess, [VmSendRec]{}
074452.22 11 [VmSendPlaySuccess] Playing
074452.22 11 RVreplace start: [$RV[PathSysVoice]VmSendSuccess.wav]
074452.22 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav]
074452.23 11 [VmSendPlaySuccess] Playing (C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav)
074452.25 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmSendSuccess.wav]
074452.25 11 RunModule PLAY end
074452.41  0 dial  callque update id=6 next call time 0312010749
074452.42  0 dial  callque DB update returned
074452.42 12 dial  found entry: tel[0034661180060] ann[C:\Program Files\VoiceGuide\System\voice\VmbForwardAskAccept.wav] vgs[C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs|VmDelivStart] am[C:\Program Files\VoiceGuide\data\VmSave\0002_1201074452_1_11__0001.wav]
074452.43 12 Calling  MakeCallEx(0034661180060)
074452.43 12 Dialing: 0034661180060
074452.43 12 MakeCall => 65567
074452.43 12 TapiCbTrigSet 65567 7002
074453.29 12 tapi  Reply (LineEvReply) ok 65567 0
074453.29 12 TapiCbTrigClear
074453.29 12 linedevstate 2048 0 0
074453.29 12 callstate DIALTONE 65938 0 0
074453.30 12 callstate DIALING 65938 0 0
074453.30 12 callstate PROCEEDING 65938 0 0
074453.30 12 callinfo CALLEDID
074453.30 12 callinfo REASON
074453.30 12 Lev_CallerID [2,]
074453.31 12 callinfo ORIGIN
074453.45  0 dial  callque update id=5 next call time 0312010749
074453.45  0 dial  callque DB update returned
074453.45 13 dial  found entry: tel[323156] ann[C:\Program Files\VoiceGuide\System\voice\VmbForwardAskAccept.wav] vgs[C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs|VmDelivStart] am[C:\Program Files\VoiceGuide\data\VmSave\0001_1201074452_1_11__0001.wav]
074453.46 13 Calling  MakeCallEx(323156)
074453.46 13 Dialing: 323156
074453.46 13 MakeCall => 65753
074453.46 13 TapiCbTrigSet 65753 7002
074453.89 11 Play End line[11] (id=797912)
074453.89 11 LsPlayMsg EV_PLAY_FINISHED
074453.90 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
074453.93  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=3
074453.93 11 [VmMmMenuPlay] Playing
074453.93 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
074453.93 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
074453.93 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav)
074453.94 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice\VmbAccessMenu.wav]
074453.95 11 RunModule PLAY end
074454.28 13 tapi  Reply (LineEvReply) ok 65753 0
074454.28 13 TapiCbTrigClear
074454.28 13 linedevstate 2048 0 0
074454.28 13 callstate DIALTONE 65720 0 0
074454.29 13 callstate DIALING 65720 0 0
074454.29 13 callstate PROCEEDING 65720 0 0
074454.29 13 callinfo CALLEDID
074454.29 13 callinfo REASON
074454.29 13 Lev_CallerID [3,]
074454.30 13 callinfo ORIGIN
074456.39 11 callstate DISCONNECTED 65666,0,0
074456.39 11 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
074456.39 11 Hanging up call...
074456.39 11 RecSoundStop ok
074456.45 11 PlaySoundStop ok
074456.45 11 fnHangupCall end
074456.49 11 linedevstate 2048 0 0
074456.49 11 callstate IDLE 65666 0 0
074456.50 11 WorkingMode@Idle=
074456.53 11 tapi  Reply (LineEvReply) ok 65771 0
074457.45 11 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
074457.45 11 ReinitTelephony due to IDLE start
074457.45 11 tapic lineDeallocateCall(MainCall:65666) 0
074457.67 11 lineOpen(11) => 0
074457.67 11 Waiting for a call...
074457.67 11 lineOpen(11)LineHandle=66335
074459.11 13 callstate BUSY 65720 4 0
074459.11  0 dial  callque update id=5 next call time 0312010749
074459.11  0 dial  callque DB update returned
074459.12 13 Hanging up call... [Busy]
074459.12 13 RecSoundStop ok
074459.12 13 PlaySoundStop ok
074459.12 13 Waiting for a call...
074459.13 13 fnHangupCall end
074459.17 13 linedevstate 2048 0 0
074459.17 13 callstate IDLE 65720 0 0
074459.17 13 WorkingMode@Idle=
074459.17 13 LineState(iLineId).iVgsIdx = 0
074459.17 13 tapi  Reply (LineEvReply) ok 66506 0
074500.09 13 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
074500.09 13 ReinitTelephony due to IDLE start
074500.10 13 tapic lineDeallocateCall(MainCall:65720) 0
074500.29 13 lineOpen(13) => 0
074500.29 13 Waiting for a call...
074500.29 13 lineOpen(13)LineHandle=65986
074511.97 12 callstate CONNECTED 65938,1,0
074511.97 12 WorkingModeTAPI@Connected=
074511.98 12 WorkingModeScript@Connected=
074512.00  0 dial  callque delete id=6
074512.01 12 Live person answered, starting C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs|VmDelivStart
074512.01  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs at idx=6
074512.01 12 [VmDelivStart] Running VB Script...
074512.02 12 RVreplace start (strlen>100)
074512.07 12 Run Script waiting... (shellid=4412, process=1824)
074512.12 12 cl    Script_Goto 12, VmLogin.vgs, VmMmMsgCountsCalc, [VmMsgCurr_Filename]{0002_1201074452_1_11__0001.wav}[VmMsgList_NewOrSaved]{1}[VmMsgCurr_Index]{1}[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminName]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[VmbLoginIntro]{none}
074512.13  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=3
074512.14 12 [VmMmMsgCountsCalc] Running VB Script...
074512.14 12 RVreplace start (strlen>100)
074512.20 12 Run Script waiting... (shellid=4744, process=1756)
074513.11 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074513.11 12 task still running (shellid=4744, process=1756)
074514.12 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074514.12 12 task still running (shellid=4744, process=1756)
074515.12 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074515.12 12 task still running (shellid=4744, process=1756)
074516.12 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074516.12 12 task still running (shellid=4744, process=1756)
074517.12 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074517.12 12 task still running (shellid=4744, process=1756)
074518.12 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074518.12 12 task still running (shellid=4744, process=1756)
074519.12 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074519.12 12 task still running (shellid=4744, process=1756)
074520.12 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074520.12 12 task still running (shellid=4744, process=1756)
074521.13 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074521.13 12 task still running (shellid=4744, process=1756)
074522.13 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074522.13 12 task still running (shellid=4744, process=1756)
074523.13 12 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
074523.13 12 task still running (shellid=4744, process=1756)
074523.34 12 callstate DISCONNECTED 65938,0,0
074523.34 12 LsRunWaitTillFinished EV_REMOTEPARTY_DISCONNECT
074523.34 12 Hanging up call...
074523.35 12 RecSoundStop ok
074523.35 12 PlaySoundStop ok
074523.35 12 fnHangupCall end
074523.40 12 linedevstate 2048 0 0
074523.40 12 callstate IDLE 65938 0 0
074523.40 12 WorkingMode@Idle=
074523.42 12 tapi  Reply (LineEvReply) ok 66471 0
074524.33 12 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
074524.33 12 ReinitTelephony due to IDLE start
074524.33 12 tapic lineDeallocateCall(MainCall:65938) 0
074524.53 12 lineOpen(12) => 0
074524.53 12 Waiting for a call...
074524.53 12 lineOpen(12)LineHandle=66455
074900.06  0 dial  callque update id=5 next call time 0312010754
074900.06  0 dial  callque DB update returned
074900.06 12 dial  found entry: tel[323156] ann[C:\Program Files\VoiceGuide\System\voice\VmbForwardAskAccept.wav] vgs[C:\Program Files\VoiceGuide\system\vm\vmMsgDeliver.vgs|VmDelivStart] am[C:\Program Files\VoiceGuide\data\VmSave\0001_1201074452_1_11__0001.wav]
074900.07 12 Calling  MakeCallEx(323156)
074900.07 12 Dialing: 323156
074900.08 12 MakeCall => 65599
074900.08 12 TapiCbTrigSet 65599 7002
074900.87 12 tapi  Reply (LineEvReply) ok 65599 0
074900.87 12 TapiCbTrigClear
074900.88 12 linedevstate 2048 0 0
074900.88 12 callstate DIALTONE 65703 0 0
074900.88 12 callstate DIALING 65703 0 0
074900.88 12 callstate PROCEEDING 65703 0 0
074900.89 12 callinfo CALLEDID
074900.89 12 callinfo REASON
074900.89 12 Lev_CallerID [2,]
074900.90 12 callinfo ORIGIN
074906.49 11 linedevstate 2048 0 0
074906.49 11 callstate OFFERING 66061 0 4
074906.49 11 Could not obtain handle to kill process. (new call) 3080, 1792
074906.50 11 Answer the call at 01/12/2003 07:49:06
074906.51 11 lineAnswer(66061) => 65801
074906.52 11 callinfo CALLEDID
074906.52 11 callinfo ORIGIN
074906.52 11 ring 0
074907.06 11 callstate CONNECTED 66061,1,0
074907.06 11 WorkingModeTAPI@Connected=
074907.07 11 WorkingModeScript@Connected=
074907.10 11 Inband detection not enabled
074907.10 11 StartLoadedVgs at 01/12/2003 07:49:07
074907.11 11 tapi  Reply (LineEvReply) ok 65801 0
074907.11 11 [Set Sound Files] Evaluate ["C:\Program Files\VoiceGuide\System\voice_sue"]
074907.11 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_sue"))
074907.12 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_sue] stored in $RV[DIRSYSTEMVOICE]
074907.12 11 path {C:\Program Files\VoiceGuide\System\voice_sue} not found
074907.12 11 [S.Enter Pin Code] Number Input
074907.12 11 [S.Enter Pin Code] Playing (input-access-code.wav)
074907.14 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
074910.48 12 callstate DISCONNECTED 65703,16,0
074910.48 12 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
074910.48  0 dial  callque delete id=5
074910.51 12 AM - wait for end of welcome message...
074910.51 12 dial  awaiting end of answering machine message (lvl:10 for 20)
074910.53 12 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_12.wav] ok
074914.19 11 wb(5280900)
074914.24 11 Play End line[11] (id=52809)
074914.24 11 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
074916.60 12 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
074916.65 12 RecSoundStop ok
074916.66 12 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
074916.66 12 Play Answer Machine message [C:\Program Files\VoiceGuide\data\VmSave\0001_1201074452_1_11__0001.wav]
074916.68 12 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\VmSave\0001_1201074452_1_11__0001.wav]
074918.69 12 wb(6234300)
074918.74 12 Play End line[12] (id=62343)
074918.74 12 LsDialoutPlayOnAnswerMachine EV_PLAY_FINISHED
074918.75 12 Hanging up call... [LsDialoutPlayOnAnswerMachine 2 ]
074918.75 12 RecSoundStop ok
074918.75 12 PlaySoundStop ok
074918.75 12 Waiting for a call...
074918.76 12 fnHangupCall end
074918.80 12 linedevstate 2048 0 0
074918.80 12 callstate IDLE 65703 0 0
074918.81 12 WorkingMode@Idle=
074918.81 12 LineState(iLineId).iVgsIdx = 0
074918.81 12 tapi  Reply (LineEvReply) ok 66388 0
074919.09 11 callstate DISCONNECTED 66061,0,0
074919.09 11 LsGetNbrsRxDigits EV_REMOTEPARTY_DISCONNECT
074919.09 11 Hanging up call...
074919.10 11 RecSoundStop ok
In the previous problem did deleting the database fix the problem, or just replacing the .exe fixed the problem?
Regarding the message playing bug:
Please update your v5.1.3 installation with attached VGMULTI.EXE and try making the call again..
VgMulti.zip
It worked thanks.. we got there in the end.
to answer your question I needed to delete the database file to make it work and also replace the VG file...
Can you let me know one thing.. Do outdial dialing times apply to voicemail type messages or are these sent whatever time of day the message is recorded by the person who wants to send the message?
I replied to your questions above then remebered to post this last question also..
I want to send the recorded voicemail file by email..
This works great except I would like to change the name of the file is this poss?
I saved the file to a new directory using the RUN command and would like to if poss take the file from that directory instead of the standard C:'prog files/ voiceguide/system/vm etc etc as the name of the new directory is more relevant.. is this poss pls??
If so how??
You can edit the Voicemail system's scripts to copy the recorded sound file to another name and then forward that file instead... I'd recommend looking through the voicemail system scripts - in particular the vmLm.vgs script.
Alternatively, VoiceGuide's COM function Vm_ForwardMsg forwards a specified sound file according to the rules created for a particular voicemail box - you can just use that function to perform the forwarding of your new file...
PS. all the fixes which were supplied as part of this thread are now available as part of VoiceGuide v5.1.4 onwards.
So would this work if it was the RUN command of the voicemail box?
I copy the message then forward usiing VM_forward Msg>??
cmd.exe /c copy "$RV[VoicemailMessageXXXX]" "S:\NewMessage.wav" set vg = CreateObject("VoiceGuide.CommandLink")vg.Vm_ForwardMsg iLineId, "0001", "S:\NewMessage.wav" set vg = Nothing
p.s. what other new features are on the new version of VG?
So weird.. one min the voicemail system send messages perfectly next time it does not... Basically when i try forward to a group it tells me there is no group to be found...
163430.57 11 linedevstate 2048 0 0
163430.57 11 callstate OFFERING 66289 0 4
163430.58 11 Answer the call at 03/12/2003 16:34:30
163430.59 11 lineAnswer(66289) => 65616
163430.60 11 callinfo CALLEDID
163430.60 11 callinfo ORIGIN
163430.60 11 ring 0
163431.13 11 callstate CONNECTED 66289,1,0
163431.14 11 WorkingModeTAPI@Connected=
163431.14 11 WorkingModeScript@Connected=
163431.18 11 Inband detection not enabled
163431.18 11 StartLoadedVgs at 03/12/2003 16:34:31
163431.18 11 tapi  Reply (LineEvReply) ok 65616 0
163431.18 11 [Set Sound Files] Evaluate ["C:\Program Files\VoiceGuide\System\voice_sue"]
163431.20 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_sue"))
163431.20 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_sue] stored in $RV[DIRSYSTEMVOICE]
163431.20 11 path {C:\Program Files\VoiceGuide\System\voice_sue} not found
163431.20 11 [S.Enter Pin Code] Number Input
163431.20 11 [S.Enter Pin Code] Playing (input-access-code.wav)
163431.22 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\input-access-code.wav]
163433.80 11 dtmf 9   (66289,57,2)
163433.80 11 LsGetNbrsPlayWelcMsg 9
163433.85 11 PlaySoundStop ok
163433.85 11 [S.Enter Pin Code] Number Input 9
163433.85 11 path {9} not found
163433.99 11 dtmf 9   (66289,57,2)
163433.99 11 LsGetNbrsRxDigits 9
163433.99 11 [S.Enter Pin Code] Number Input 99
163433.99 11 path {99} not found
163434.20 11 dtmf 9   (66289,57,2)
163434.20 11 LsGetNbrsRxDigits 9
163434.20 11 [S.Enter Pin Code] Number Input 999
163434.20 11 path {999} not found
163434.92 11 dtmf 8   (66289,56,2)
163434.92 11 LsGetNbrsRxDigits 8
163434.92 11 [S.Enter Pin Code] Number Input 9998
163434.92 11 voicemail used: Scripted
163434.93  0 Script Load C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs
163436.12 11 Loaded C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs into:3
163436.13 11 [VmLoginStart] Running VB Script...
163436.13 11 RVreplace start (strlen>100)
163436.19 11 Run Script waiting... (shellid=5616, process=1448)
163436.23 11 cl    Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMmAdminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminName]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key_VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[Key_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPlayMessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdminWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsgSaveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndPlay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_VmSendMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_StopRecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}<<
163436.24 11 [VmLoginAskVmb] Number Input
163436.24 11 RVreplace start: [$RV[VmbLoginIntro],$RV[PathSysVoice]VmbAccessGetVmbIdRetrieve.wav]
163436.25 11 RVreplace end: [none,C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessGetVmbIdRetrieve.wav]
163436.25 11 [VmLoginAskVmb] Playing (none,C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessGetVmbIdRetrieve.wav)
163436.27 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessGetVmbIdRetrieve.wav]
163437.93 11 dtmf 0   (66289,48,2)
163437.93 11 LsGetNbrsPlayWelcMsg 0
163437.98 11 PlaySoundStop ok
163437.98 11 [VmLoginAskVmb] Number Input 0
163437.99 11 path {0} not found
163438.07 11 dtmf 0   (66289,48,2)
163438.07 11 LsGetNbrsRxDigits 0
163438.07 11 [VmLoginAskVmb] Number Input 00
163438.08 11 path {00} not found
163438.29 11 dtmf 0   (66289,48,2)
163438.29 11 LsGetNbrsRxDigits 0
163438.29 11 [VmLoginAskVmb] Number Input 000
163438.29 11 path {000} not found
163438.00 11 dtmf 1   (66289,49,2)
163439.00 11 LsGetNbrsRxDigits 1
163439.00 11 [VmLoginAskVmb] Number Input 0001
163439.00 11 path {0001} not found
163439.43 11 dtmf #   (66289,35,2)
163439.43 11 LsGetNbrsRxDigits #
163439.43 11 path {0001} not found
163439.43 11 [VmLoginAskPin] Number Input
163439.43 11 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbPin.wav]
163439.43 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessGetVmbPin.wav]
163439.43 11 [VmLoginAskPin] Playing (C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessGetVmbPin.wav)
163439.45 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessGetVmbPin.wav]
163442.47 11 dtmf 5   (66289,53,2)
163442.47 11 LsGetNbrsPlayWelcMsg 5
163442.52 11 PlaySoundStop ok
163442.53 11 [VmLoginAskPin] Number Input 5
163442.53 11 path {5} not found
163442.96 11 dtmf 3   (66289,51,2)
163442.96 11 LsGetNbrsRxDigits 3
163442.96 11 [VmLoginAskPin] Number Input 53
163442.96 11 path {53} not found
163443.38 11 dtmf 9   (66289,57,2)
163443.38 11 LsGetNbrsRxDigits 9
163443.38 11 [VmLoginAskPin] Number Input 539
163443.38 11 path {539} not found
163443.89 11 dtmf 7   (66289,55,2)
163443.89 11 LsGetNbrsRxDigits 7
163443.90 11 [VmLoginAskPin] Number Input 5397
163443.90 11 path {5397} not found
163444.32 11 dtmf #   (66289,35,2)
163444.33 11 LsGetNbrsRxDigits #
163444.33 11 path {5397} not found
163444.33 11 [VmLoginCheckPin] Running VB Script...
163444.33 11 RVreplace start (strlen>100)
163444.38 11 Run Script waiting... (shellid=2424, process=1580)
163444.42  0 cl    Vm_VmbConfig_Get 0001, Pin
163444.42 11 cl    Script_Goto 11, , VmMmMsgCountsCalc, [VmbId]{0001}
163444.42 11 [VmMmMsgCountsCalc] Running VB Script...
163444.42 11 RVreplace start (strlen>100)
163444.49 11 Run Script waiting... (shellid=5664, process=1564)
163444.65 11 cl    Run_ResultReturn >>[VmMsgCount_New]{0}[VmMsgCount_Saved]{4}<<
163444.65 11 RVreplace start: [$RV[VmMsgCount_New]]
163444.65 11 RVreplace end: [0]
163444.66 11 [VmMmMsgCountsPlayNew] Say numbers: 0 as Number
163444.66 11 fn    PlaySoundStartNumbers $RV[PathSysVoice]VmbAccessYouHave.wav, $RV[PathSysVoice]VmbAccessNewMessagesAnd.wav, 0, Number
163444.66 11 RVreplace start: [$RV[PathSysVoice]VmbAccessYouHave.wav]
163444.66 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessYouHave.wav]
163444.66 11 RVreplace start: [$RV[PathSysVoice]VmbAccessNewMessagesAnd.wav]
163444.66 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessNewMessagesAnd.wav]
163444.67 11 sVbsFunctionToUse=Number
163444.76 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
163444.81 11 cl    Play_Start C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessYouHave.wav,0.wav,C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessNewMessagesAnd.wav
163444.84 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessYouHave.wav,C:\Program Files\VoiceGuide\System\voice_sue\0.wav,C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessNewMessagesAnd.wav]
163448.60 11 wb(39049102)
163448.66 11 Play End line[11] (id=390491)
163448.66 11 LsSayNbrPlay EV_PLAY_FINISHED
163448.66 11 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
163448.66 11 RVreplace start: [$RV[VmMsgCount_Saved]]
163448.66 11 RVreplace end: [4]
163448.66 11 [VmMmMsgCountsPlaySaved] Say numbers: 4 as Number
163448.67 11 fn    PlaySoundStartNumbers none, $RV[PathSysVoice]VmbAccessSavedMessages.wav, 4, Number
163448.67 11 RVreplace start: [$RV[PathSysVoice]VmbAccessSavedMessages.wav]
163448.67 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessSavedMessages.wav]
163448.67 11 sVbsFunctionToUse=Number
163448.76 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
163448.81 11 cl    Play_Start 4.wav,C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessSavedMessages.wav
163448.83 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\4.wav,C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessSavedMessages.wav]
163451.64 11 wb(39448701)
163451.70 11 Play End line[11] (id=394487)
163451.70 11 LsSayNbrPlay EV_PLAY_FINISHED
163451.70 11 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
163451.70 11 [VmMmMenuPlay] Playing
163451.70 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
163451.70 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav]
163451.71 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav)
163451.73 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav]
163451.73 11 RunModule PLAY end
163452.27 11 dtmf 6   (66289,54,2)
163452.27 11 LsPlayMsg 6
163452.32 11 PlaySoundStop ok
163452.34 11 [VmMmMenu] Running VB Script...
163452.34 11 RVreplace start (strlen>100)
163452.41 11 Run Script waiting... (shellid=4176, process=1600)
163452.45 11 cl    Script_Gosub vmSendMsg.vgs, VmSendRecPrompt, , VmMmMenuPlay
163452.46  0 Script Load C:\Program Files\VoiceGuide\system\vm\vmSendMsg.vgs
163452.54 11 Loaded C:\Program Files\VoiceGuide\system\vm\vmSendMsg.vgs into:4
163452.54 11 [VmSendRecPrompt] Playing
163452.54 11 RVreplace start: [$RV[PathSysVoice]VmSendRecPrompt.wav]
163452.54 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmSendRecPrompt.wav]
163452.55 11 [VmSendRecPrompt] Playing (C:\Program Files\VoiceGuide\System\voice_sue\VmSendRecPrompt.wav)
163452.56 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmSendRecPrompt.wav]
163452.57 11 RunModule PLAY end
163458.21  0 sys   cleanup Start
163458.21  0 sys   cleanup End
163459.29 11 wb(39823200)
163459.34 11 Play End line[11] (id=398232)
163459.34 11 LsPlayMsg EV_PLAY_FINISHED
163459.34 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
163459.34 11 [VmSendRec] Recording
163459.38 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\beep1.wav]
163459.59 11 wb(40503200)
163459.64 11 Play End line[11] (id=405032)
163459.64 11 LsRecPlayBeep EV_PLAY_FINISHED
163459.66 11 RecSoundStart file[C:\Program Files\VoiceGuide\system\vm\1203163459_11_.wav] ok
163459.66 11 RecFile[C:\Program Files\VoiceGuide\system\vm\1203163459_11_.wav]
163503.37 11 dtmf #   (66289,35,2)
163503.37 11 LsRecRecording #
163503.42 11 RecSoundStopTruncBytes ok
163503.43 11 rec length RV: VmSendRec_RecLen100ms = 36
163503.43 11 [VmSendMainMenu] Running VB Script...
163503.43 11 RVreplace start (strlen>100)
163503.49 11 Run Script waiting... (shellid=5740, process=1592)
163503.54 11 cl    Script_Goto 11, , VmSendPlayMainMenu,
163503.54 11 [VmSendPlayMainMenu] Playing
163503.56 11 RVreplace start: [$RV[PathSysVoice]VmSendMainMenu.wav]
163503.56 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmSendMainMenu.wav]
163503.56 11 [VmSendPlayMainMenu] Playing (C:\Program Files\VoiceGuide\System\voice_sue\VmSendMainMenu.wav)
163503.58 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmSendMainMenu.wav]
163503.59 11 RunModule PLAY end
163508.55 11 dtmf 3   (66289,51,2)
163508.55 11 LsPlayMsg 3
163508.62 11 PlaySoundStop ok
163508.62 11 [VmSendMainMenu] Running VB Script...
163508.62 11 RVreplace start (strlen>100)
163508.82 11 Run Script waiting... (shellid=4120, process=1612)
163508.88 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{}
163508.88 11 [VmSendGetDest] Number Input
163508.88 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
163508.88 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice_sue\VmSendGetNextDest.wav]
163508.88 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice_sue\VmSendGetNextDest.wav)
163508.91 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmSendGetNextDest.wav]
163516.33 11 dtmf 9   (66289,57,2)
163516.33 11 LsGetNbrsPlayWelcMsg 9
163516.39 11 PlaySoundStop ok
163516.39 11 [VmSendGetDest] Number Input 9
163516.39 11 path {9} not found
163517.12 11 dtmf 9   (66289,57,2)
163517.12 11 LsGetNbrsRxDigits 9
163517.12 11 [VmSendGetDest] Number Input 99
163517.13 11 path {99} not found
163517.94 11 dtmf 9   (66289,57,2)
163517.94 11 LsGetNbrsRxDigits 9
163517.94 11 [VmSendGetDest] Number Input 999
163517.94 11 path {999} not found
163518.75 11 dtmf 9   (66289,57,2)
163518.75 11 LsGetNbrsRxDigits 9
163518.75 11 [VmSendGetDest] Number Input 9999
163518.76 11 path {9999} not found
163519.68 11 dtmf #   (66289,35,2)
163519.69 11 LsGetNbrsRxDigits #
163519.69 11 path {9999} not found
163519.69 11 [VmSendGetDestAndSend] Running VB Script...
163519.69 11 RVreplace start (strlen>100)
163519.77 11 Run Script waiting... (shellid=5828, process=1616)
163519.83 11 cl    RvSet VmSendDestNameWav,
163519.83 11 cl    Script_Goto 11, , VmSendGetDest, [VmSendDestListSoFar]{9999}[VmSendGetDest]{}
163519.84 11 [VmSendGetDest] Number Input
163519.84 11 RVreplace start: [$RV[VmSendDestNameWav],$RV[PathSysVoice]VmSendGetNextDest.wav]
163519.84 11 RVreplace end: [,C:\Program Files\VoiceGuide\System\voice_sue\VmSendGetNextDest.wav]
163519.84 11 [VmSendGetDest] Playing (,C:\Program Files\VoiceGuide\System\voice_sue\VmSendGetNextDest.wav)
163519.86 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmSendGetNextDest.wav]
163522.50 11 dtmf #   (66289,35,2)
163522.50 11 LsGetNbrsPlayWelcMsg #
163522.56 11 PlaySoundStop ok
163522.56 11 [VmSendGetDestAndSend] Running VB Script...
163522.57 11 RVreplace start (strlen>100)
163522.63 11 Run Script waiting... (shellid=2980, process=1620)
163522.68 11 cl    RvSet VmSendDestNameWav,
163522.68  0 cl    Vm_DistListConfig_Get 9999, DistList
163522.69 11 vms   copy vm to:C:\Program Files\VoiceGuide\data\VmSave\9999_1203163522_1_11__0001.wav
163522.70 11 cl    Vm_ForwardMsg 11, 9999, C:\Program Files\VoiceGuide\data\VmSave\9999_1203163522_1_11__0001.wav
163522.70 11 vm    frwrd vmb 9999 << unknown vmb
163522.76 11 cl    Script_Goto 11, , VmSendPlaySuccess, [VmSendRec]{}
163522.76 11 [VmSendPlaySuccess] Playing
163522.76 11 RVreplace start: [$RV[PathSysVoice]VmSendSuccess.wav]
163522.76 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmSendSuccess.wav]
163522.77 11 [VmSendPlaySuccess] Playing (C:\Program Files\VoiceGuide\System\voice_sue\VmSendSuccess.wav)
163522.79 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmSendSuccess.wav]
163522.79 11 RunModule PLAY end
163524.39 11 wb(42844600)
163524.44 11 Play End line[11] (id=428446)
163524.45 11 LsPlayMsg EV_PLAY_FINISHED
163524.45 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
163524.47  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLogin.vgs at idx=3
163524.48 11 [VmMmMenuPlay] Playing
163524.48 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
163524.48 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav]
163524.48 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav)
163524.51 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav]
163524.51 11 RunModule PLAY end
163526.95 11 dtmf 1   (66289,49,2)
163526.95 11 LsPlayMsg 1
163527.00 11 PlaySoundStop ok
163527.02 11 [VmMmMenu] Running VB Script...
163527.02 11 RVreplace start (strlen>100)
163527.11 11 Run Script waiting... (shellid=2476, process=1604)
163527.16 11 VmMmMenu VmMsgList_Create(0001, 1, 1) sMsgMatch=[C:\Program Files\VoiceGuide\data\VmSave\0001_??????????_1_*.wav]
163527.21 11 cl    Script_Goto 11, , VmMmNoNewMsgs,
163527.21 11 [VmMmNoNewMsgs] Playing
163527.22 11 RVreplace start: [$RV[PathSysVoice]VmbAccessNoNewMessages.wav]
163527.22 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessNoNewMessages.wav]
163527.22 11 [VmMmNoNewMsgs] Playing (C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessNoNewMessages.wav)
163527.24 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessNoNewMessages.wav]
163527.24 11 RunModule PLAY end
163528.53 11 wb(43290200)
163528.59 11 Play End line[11] (id=432902)
163528.59 11 LsPlayMsg EV_PLAY_FINISHED
163528.59 11 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
163528.60 11 [VmMmMenuPlay] Playing
163528.60 11 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
163528.60 11 RVreplace end: [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav]
163528.60 11 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav)
163528.63 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\System\voice_sue\VmbAccessMenu.wav]
163528.63 11 RunModule PLAY end
163531.59 11 callstate DISCONNECTED 66289,0,0
163531.59 11 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
163531.60 11 Hanging up call...
163531.60 11 RecSoundStop ok
163531.65 11 PlaySoundStop ok
163531.65 11 fnHangupCall end
163531.70 11 linedevstate 2048 0 0
163531.70 11 callstate IDLE 66289 0 0
163531.70 11 WorkingMode@Idle=
163531.74 11 tapi  Reply (LineEvReply) ok 65841 0
163532.66 11 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
163532.66 11 ReinitTelephony due to IDLE start
163532.67 11 tapic lineDeallocateCall(MainCall:66289) 0
163532.84 11 lineOpen(11) => 0
163532.84 11 Waiting for a call...
163532.84 11 lineOpen(11)LineHandle=66390
The trace shows that old scripts are being used.... the new scripts that were supplied a few messages back in this thread have tracing which uses "vms dist list" tags... and we do not see these tags listed in the trace...
Also the trace above shows:
That's a command issued by the old voicemail scripts - not the new one...
Here is a snippet from the new scripts, which shows the type of tracing we would expect to see if the new scripts are used...:
    VG.Admin_TraceLogAdd iLineId, 3, "vms   dist list [" & sDestList & "] ubound=" & aDestList_Ubound
    for iDestListCount = 0 to aDestList_Ubound
      'see if there is a distribution list like with this ID
      'DistList : returns comma delimited list of VMBs/Lists
      'sDistList = VG.Vm_DistListConfig_Get(aDestList(iDestListCount), "DistList")
      sDistList = VG.Vm_DistListConfig_Get(aDestList(iDestListCount), "list")
      if (sDistList = "") then
        VG.Admin_TraceLogAdd iLineId, 3, "vms   dist list [" & aDestList(iDestListCount) & "] not found"
      else
        VG.Admin_TraceLogAdd iLineId, 3, "vms   dist list [" & aDestList(iDestListCount) & "] => [" & sDistList & "]"
        aDestList(iDestListCount) = sDistList
      end if
    next
The new scripts are included as part of the v5.1.4 distribution...
Regarding copying/forwarding - the copying can be done from a Run Program module, but the forwarding part is a VB script command which must be ran from a VB Script module... probably silmplest to just copy file as well from a VB Script module...
so as far as me forwarding the sound file to my list what are you saying is the instructions to do this as i dont really understand..
i want to record the file as normal using voicemail.
copy the file and send the new version.
Please let me know how to do this as maybe you have already but did not really understan your reply... sorry...
some example code would really help..... thanks
i want to record the file as normal using voicemail. copy the file and send the new version.
Name of last recorded voicemail file can be accessed using $RV[VoicemailMessage], and you can use that in the Run Program module to copy to file to another name - and you can then run a VB Script which uses the Vm_ForwardMsg COM function to forward the new file...
It may be just as easy to modify the VoiceGuide Voicemail script files to do this...
You will need knowledge of VB scripting to do this.
