Vbs Module
How do I create an array with RvSet, just as the results returned by the database query module.($RV[ModuleTitle_ColumnIndex_RowIndex])
I have a VBS module with a query that returns multiple data. I want to build a type RVSet like $RV[Name_ColumnIndex_RowIndex)
Look at mi example:
set cn = CreateObject("ADODB.Connection")
cn.Open "$RV[ConnStr]"
if cn.State <> 1 then
vg.Admin_TraceLogAdd iLineId, 5, "login LeadingAd connection to database could not be made"
vg.Run_ResultReturn iLineId, "fail"
WScript.Quit
end if
set rs.ActiveConnection = cn
sSQL = "SELECT CurrentBal, NumCard from TBLBalanceMast WHERE SocioNum = " & $RV[GetCustId]
rs.Open sSQL, cn, 3
if rs.RecordCount <= 0 then
rs.Close
vg.Admin_TraceLogAdd iLineId, 5, "no records retrieved"
else
Balance = rs.Fields("CurrentBal").Value
Number = rs.Fields("NumCard").Value
' vg.RvSet $RV_LINEID, "Balances",Balance
' vg.RvSet $RV_LINEID, "Numeros",Number
rs.Close
end if
cn.Close
set rs = Nothing
set cn = Nothing
set vg = Nothing
WScript.Quit
The query works fine, but do not know how I RvSet to assemble several variables indexed like database query module.
Thanks, Diego Bellini
change:
 rs.Close
else
 rs.Close
end if
to:
 rs.Close
else
 recordcount = rs.RecordCount
 rs.MoveFirst
 for i = 1 to recordcount
   vg.RvSet $RV_LINEID, "MyDatasetName_1_" & i, Balance
   vg.RvSet $RV_LINEID, "MyDatasetName_2_" & i", Number
   if i < recordcount then
     rs.MoveNext
   end if
 next
 rs.Close
end if
This way the RVs are created in the $RV[Name_ColumnIndex_RowIndex] format.
