After Hangup Script not running
I still have problems with script witch no run script after call is finished.
connection
212233.032 6 4 2 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL)
should follow to termination script
but doesn't terminate with
after hangup script: [C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_temination_pro_15.vgp]
as other connections.
I don't see any error message to find reason why script don't follow to termination script.
212233.032 6 4 2 qScr add evScriptEvent 0 OTHER_LEG_Disconnected
212233.032 6 2 1 LineEvCallState LINECALLSTATE_DISCONNECTED begin
212233.032 6 2 1 ignore callstate LINECALLSTATE_DISCONNECTED event as current linestate is Disconnected
212233.032 6 4 2 qScr run evScriptEvent sCode=[OTHER_LEG_Disconnected] iActionID=0, crn=0[16384|0|64|0|0][|||||]
212233.032 6 4 2 scriptevent OTHER_LEG_Disconnected 16384|0|64 ||
212233.032 6 4 2 LsXfer_9_WaitEndCall_OutLeg : 0(), [OTHER_LEG_Disconnected], 16384,0,64,,,
212233.032 6 4 2 hanging up 2nd leg of call (other leg cause)
212233.032 6 4 2 HangupCall, source=xfer_9_leg2 remote, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0
212233.032 6 4 2 moduleTitle=[connection_time_sql]
212233.032 6 4 2 ScriptWorkingMode set Stopping, (called from HangupCall)
212233.032 6 4 2 state Hanging up... [xfer_9_leg2 remote]
212233.032 6 4 2 rv add [Hangup Source]{xfer_9_leg2 remote}
212233.032 6 d added Hangup Source | xfer_9_leg2 remote | ( 48 61 6e 67 75 70 20 53 6f 75 72 63 65 | 78 66 65 72 5f 39 5f 6c 65 67 32 20 72 65 6d 6f 74 65 | 4) id=4
212233.032 6 d added Hangup Source | xfer_9_leg2 remote | ( 48 61 6e 67 75 70 20 53 6f 75 72 63 65 | 78 66 65 72 5f 39 5f 6c 65 67 32 20 72 65 6d 6f 74 65 | 13) id=4
212233.032 6 4 2 GoOnHoook_IssueDropCall start (hCall_crn=28002b5, yLineStateAppPov=Disconnect_Pending)
212233.032 6 4 2 logs not written as LogEntryWritten=1
212233.032 6 4 2 t timer set 10 sec : EV_TIMEOUT_WAITFORIDLEAFTERDropCall
212233.032 6 4 2 qTel add cmd_DropCall [0,0,0,0,0][||||]
212233.032 6 4 2 GoOnHoook_IssueDropCall end
212233.032 7 4 2 qTel run cmd_DropCall
212233.048 18 2 1 ev CallState GCEV_DROPCALL, crn=28002b4, iEvent=2 ,1,0,32,,,]. vgEngine v7.2.4160.36381 (2011-05-23 19:12:42.09)
212233.048 18 2 1 qScr add evCallState 2 GCEV_DROPCALL
212233.048 6 2 1 qScr run evCallState sCode=[GCEV_DROPCALL] iActionID=0, crn=28002b4[1|0|32|0|0][|||||]
212233.048 6 2 1 LineEvCallState crn=28002b4 event=2|GCEV_DROPCALL iCallState=1calldirection=0 gcCallState=32 [||]
212233.048 6 2 1 LineEvCallState eLineStateThisEvent=Idle_NotYetReleased
212233.048 6 2 1 LineEvCallState ScriptState=LS_ENDINGCALL
212233.048 6 2 1 ls set Idle_NotYetReleased (scriptstate=LS_ENDINGCALL)
212233.048 6 2 1 yLineStateAppPov: Idle_NotYetReleased crn=28002b4,ev=2,GCEV_DROPCALL,0, sParam1=
212233.048 6 4 2 qScr add evScriptEvent 0 OTHER_LEG_Idle_NotYetReleased
212233.048 6 2 1 LineEvCallState LINECALLSTATE_IDLE begin
212233.048 6 2 1 t timer clear (force=True)
212233.048 6 2 1 CallData.dateCallStartTime=2012-01-21 21:21:33
212233.048 6 2 1 rv add [CallHangupTime]{2012-01-21 21:22:33}
212233.048 6 d added CallHangupTime | 2012-01-21 21:22:33 | ( 43 61 6c 6c 48 61 6e 67 75 70 54 69 6d 65 | 32 30 31 32 2d 30 31 2d 32 31 20 32 31 3a 32 32 3a 33 33 | 131) id=2
212233.048 6 d added CallHangupTime | 2012-01-21 21:22:33 | ( 43 61 6c 6c 48 61 6e 67 75 70 54 69 6d 65 | 32 30 31 32 2d 30 31 2d 32 31 20 32 31 3a 32 32 3a 33 33 | 175) id=2
212233.048 6 2 1 WriteCDRlogs: begin (campaign=, CallData.iLineId=0)
212233.048 6 2 1 writing CDR logs
212233.048 6 2 1 vg.ini/Log/CDR_LastData_SaveRv=0 - RVs XML will NOT be saved in LastApplicationData CDR field.
212233.048 6 2 1 rv replace start [$RV[CDR_amaflags]]
212233.048 6 rv dbg rv_retrieve did not find [CDR_amaflags] ( 43 44 52 5f 61 6d 61 66 6c 61 67 73)
212233.048 6 2 1 rv replace end []
212233.048 6 2 1 rv replace start [$RV[CDR_user]]
212233.048 6 2 1 rv replace end [12012121213352]
212233.048 6 2 1 $RV[CDR_amaflags]=[], $RV[CDR_user]=[12012121213352]
212233.048 6 2 1 CDR (in) : "222054603","502131658","","","","","","C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_2011_10_14.vgp","","'2012-01-21 21:21:33'","'2012-01-21 21:21:33'","'2012-01-21 21:22:33'",59,59,"ANSWERED","","12012121213352" => C:\Program Files\VoiceGuide723\cdr\CDR_20120121_in.txt , C:\Program Files\VoiceGuide723\cdr\CDR_20120121_in_ANSWERED.txt
212233.048 6 2 1 CDR SQL: INSERT INTO cdrin (Account, Src, Dst, Dcontext, Clid, Channel, Dstchannel, Lastapp, Lastdata, dtStart, dtAnswer, dtHangup, Duration, Billsec, Disposition, Amaflags, Usr) VALUES ('222054603','502131658','','','','','','C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_2011_10_14.vgp','','2012-01-21 21:21:33','2012-01-21 21:21:33','2012-01-21 21:22:33',59,59,'ANSWERED','','12012121213352')
212233.048 6 2 1 sIni_CDRLOG_ODBC_ConnectString (secondary CDR DB) not set.
212233.048 12 db PerformWork_RunCoreSql assign sql
212233.048 6 2 1 after hangup script: [C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_temination_pro_15.vgp]
212233.048 12 db PerformWork_RunCoreSql ExecuteNonQuery call: INSERT INTO cdrin (Account, Src, Dst, Dcontext, Clid, Channel, Dstchannel, Lastapp, Lastdata, dtStart, dtAnswer, dtHangup, Duration, Billsec, Disposition, Amaflags, Usr) VALUES ('222054603','502131658','','','','','','C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_2011_10_14.vgp','','2012-01-21 21:21:33','2012-01-21 21:21:33','2012-01-21 21:22:33',59,59,'ANSWERED','','12012121213352')
212233.048 6 2 1 FindFullPathToScript_VgsOrVgp start [C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_temination_pro_15.vgp]
212233.048 6 LoadedVgs_Find C:\Documents and Settings\user\Moje dokumenty\VG\Scripts\Maciej\prepaid_temination_pro_15.vgp at idx=5
212233.048 6 2 1 After Hangup script started (from LineEvCallState() LINECALLSTATE_IDLE handler)
212233.048 6 2 1 ScriptWorkingMode set Running_AfterHangup, (called from StartAfterHangupScriptIfDefined)
212233.048 6 2 1 t timer clear (force=False)
212233.048 6 2 1 RunModule start Evaluate, [call_end], iModuleIdx=309, previous: vgm=87, vgs=5:4
212233.048 6 2 1 state [call_end] Evaluate [now()]
212233.048 6 2 1 eval[now()]
212233.048 6 2 1 CreateInstance ScriptControl objSC is: [system.__ComObject]
212233.048 6 d added call_end_Input | now() | ( 63 61 6c 6c 5f 65 6e 64 5f 49 6e 70 75 74 | 6e 6f 77 28 29 | 176) id=2
212233.048 6 d added call_end | 2012-01-21 21:22:33 | ( 63 61 6c 6c 5f 65 6e 64 | 32 30 31 32 2d 30 31 2d 32 31 20 32 31 3a 32 32 3a 33 33 | 177) id=2
212233.048 6 d updtd call_end | 2012-01-21 21:22:33 | ( 63 61 6c 6c 5f 65 6e 64 | 32 30 31 32 2d 30 31 2d 32 31 20 32 31 3a 32 32 3a 33 33 | 2) id=0
212233.048 6 d updtd call_end | 2012-01-21 21:22:33 | ( 63 61 6c 6c 5f 65 6e 64 | 32 30 31 32 2d 30 31 2d 32 31 20 32 31 3a 32 32 3a 33 33 | 177) id=2
212233.048 6 2 1 Eval Expr result:[2012-01-21 21:22:33] stored in RV[call_end]
212233.048 6 2 1 path {2012-01-21 21:22:33} not found
212233.048 6 2 1 matching path not found [2012-01-21 21:22:33], try boolean paths.
212233.048 6 2 1 ex: ScriptIo.VGMTYPE_EVALEXPR [2012-01-21 21:22:33] could not be converted to boolean. Take Success path as string non-empty.
212233.048 6 2 1 FindNextVgmTitleInPathList: next module title is=[update finish call timestamp]
212233.048 6 2 1 matching path found (Boolean True)
212233.048 6 2 1 RunModule start Database Query, [update finish call timestamp], iModuleIdx=308, previous: vgm=309, vgs=5:5
212233.048 6 2 1 state [update finish call timestamp] DB Query
212233.048 6 2 1 rv replace start [uPDATE vg_billing SET call_end='$RV[call_end]', called_number=$RV_DNIS WHERE session_id=$RV[session_id]]
212233.048 6 2 1 rv replace end [uPDATE vg_billing SET call_end='2012-01-21 21:22:33', called_number=222054603 WHERE session_id=12012121213352]
212233.048 6 2 1 db strDatabaseName=[invoso] strDbConnectString=[ODBC; Driver=PostgreSQL Unicode; Server=IP;Database=database;UID=user;PWD=pwd;] sAdoNetFactoriesAvailable=[|System.Data.Odbc|System.Data.OleDb|System.Data.OracleClient|System.Data.SqlClient|VistaDB.NET20|System.Data.SQLite|]
212233.048 6 2 1 db using ado.net ODBC data provider : OdbcConnection/OdbcCommand/etc
212233.048 6 2 1 t timer set 30 sec : EV_TIMEOUT_HANGUP
212233.048 6 2 1 db odbc RunQuery_Odbc [update finish call timestamp], db=[invoso], connect=[ Driver=PostgreSQL Unicode; Server=IP;Database=database;UID=user;PWD=pwd;], sql=[uPDATE vg_billing SET call_end='2012-01-21 21:22:33', called_number=222054603 WHERE session_id=12012121213352]
212233.048 6 2 1 db odbc thread init (threadpool)
212233.048 3 2 1 db odbc connection create call.
212233.048 3 2 1 db odbc connection open call.
212233.048 6 2 1 db odbc thread started (threadpool)
212233.048 6 4 2 qScr run evScriptEvent sCode=[OTHER_LEG_Idle_NotYetReleased] iActionID=0, crn=0[1|0|32|0|0][|||||]
212233.048 6 4 2 scriptevent OTHER_LEG_Idle_NotYetReleased 1|0|32 ||
212233.048 6 4 2 LsEndingCall OTHER_LEG_Idle_NotYetReleased 1
212233.095 18 4 2 ev CallState GCEV_DROPCALL, crn=28002b5, iEvent=2 ,1,0,32,,,]. vgEngine v7.2.4160.36381 (2011-05-23 19:12:42.09)
212233.095 18 4 2 qScr add evCallState 2 GCEV_DROPCALL
212233.095 6 4 2 qScr run evCallState sCode=[GCEV_DROPCALL] iActionID=0, crn=28002b5[1|0|32|0|0][|||||]
212233.095 6 4 2 LineEvCallState crn=28002b5 event=2|GCEV_DROPCALL iCallState=1calldirection=0 gcCallState=32 [||]
212233.095 6 4 2 LineEvCallState eLineStateThisEvent=Idle_NotYetReleased
212233.095 6 4 2 LineEvCallState ScriptState=LS_ENDINGCALL
212233.095 6 4 2 ls set Idle_NotYetReleased (scriptstate=LS_ENDINGCALL)
212233.095 6 4 2 yLineStateAppPov: Idle_NotYetReleased crn=28002b5,ev=2,GCEV_DROPCALL,0, sParam1=
212233.095 6 4 2 LineEvCallState LINECALLSTATE_IDLE begin
212233.095 6 4 2 t timer clear (force=True)
212233.095 6 4 2 CallData.dateCallStartTime=2012-01-21 21:22:22
212233.095 6 4 2 rv add [CallHangupTime]{2012-01-21 21:22:33}
212233.095 6 d added CallHangupTime | 2012-01-21 21:22:33 | ( 43 61 6c 6c 48 61 6e 67 75 70 54 69 6d 65 | 32 30 31 32 2d 30 31 2d 32 31 20 32 31 3a 32 32 3a 33 33 | 5) id=4
212233.095 6 d added CallHangupTime | 2012-01-21 21:22:33 | ( 43 61 6c 6c 48 61 6e 67 75 70 54 69 6d 65 | 32 30 31 32 2d 30 31 2d 32 31 20 32 31 3a 32 32 3a 33 33 | 14) id=4
212233.095 6 4 2 WriteCDRlogs: begin (campaign=, CallData.iLineId=4)
212233.095 6 4 2 writing CDR logs
212233.095 6 4 2 cdr.sDisposition=ANSWERED
212233.095 6 4 2 NOTE strDialoutTelNbr=502131638, strCallerIdNbr=
212233.095 6 4 2 vg.ini/Log/CDR_LastData_SaveRv=0 - RVs XML will NOT be saved in LastApplicationData CDR field.
212233.095 6 4 2 rv replace start [$RV[CDR_amaflags]]
212233.095 6 rv dbg rv_retrieve did not find [CDR_amaflags] ( 43 44 52 5f 61 6d 61 66 6c 61 67 73)
212233.095 6 4 2 rv replace end []
212233.095 6 4 2 rv replace start [$RV[CDR_user]]
212233.095 6 rv dbg rv_retrieve did not find [CDR_user] ( 43 44 52 5f 75 73 65 72)
212233.095 6 4 2 rv replace start [$RV[CDR_usr]]
212233.095 6 rv dbg rv_retrieve did not find [CDR_usr] ( 43 44 52 5f 75 73 72)
212233.095 6 4 2 $RV[CDR_amaflags]=[], $RV[CDR_user]=[]
212233.095 6 4 2 CDR (out) : "","502131638","","","","","","","","'2012-01-21 21:22:22'","'2012-01-21 21:22:28'","'2012-01-21 21:22:33'",11,4,"ANSWERED","","" => C:\Program Files\VoiceGuide723\cdr\CDR_20120121_out.txt , C:\Program Files\VoiceGuide723\cdr\CDR_20120121_out_ANSWERED.txt
212233.095 6 4 2 CDR SQL: INSERT INTO cdrout (Account, Src, Dst, Dcontext, Clid, Channel, Dstchannel, Lastapp, Lastdata, dtStart, dtAnswer, dtHangup, Duration, Billsec, Disposition, Amaflags, Usr) VALUES ('','502131638','','','','','','','','2012-01-21 21:22:22','2012-01-21 21:22:28','2012-01-21 21:22:33',11,4,'ANSWERED','','')
212233.095 6 4 2 sIni_CDRLOG_ODBC_ConnectString (secondary CDR DB) not set.
212233.095 6 4 2 no script running on this line. AfterHangup script will not be ran.
212233.095 6 4 2 AllScritpsCompleted_Cleanup start crn=28002b5
212233.095 6 4 2 ScriptWorkingMode set Idle_WaitingForNextCall, (called from AllScritpsCompleted_Cleanup)
212233.095 6 4 2 logs not written as LogEntryWritten=1
212233.095 6 4 2 LineState_Reinit_AndReleaseCall: crn=28002b5
212233.095 6 4 2 LineState_Reinit_CleanLineState : begin
212233.095 6 4 2 ls set Null_InGuardTimeAfterEndOfCall (scriptstate=LS_ENDINGCALL)
212233.095 6 4 2 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_CleanLineState)
212233.095 6 4 2 strThisCallIsInboundOrOutbound clear. (LineState_Reinit_CleanLineState)
212233.095 6 4 2 qTel add cmd_ReleaseCall [0,0,0,0,0][||||]
212233.095 6 4 2 t timer set 3 sec : EV_TIMEOUT_AFTERIDLE_ALLOWOUT
212233.095 7 4 2 qTel run cmd_ReleaseCall
212233.095 6 4 2 state Waiting for a call...
212233.095 6 4 2 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_AndReleaseCall)
212233.095 18 4 2 ev CallState GCEV_RELEASECALL, crn=28002b5, iEvent=2137 ,0,0,0,GCST_NULL,,]. vgEngine v7.2.4160.36381 (2011-05-23 19:12:42.09)
212233.095 18 4 2 qScr add evCallState 2137 GCEV_RELEASECALL
212233.095 6 4 2 qScr run evCallState sCode=[GCEV_RELEASECALL] iActionID=0, crn=28002b5[0|0|0|0|0][GCST_NULL|||||]
212233.095 6 4 2 LineEvCallState crn=28002b5 event=2137|GCEV_RELEASECALL iCallState=0calldirection=0 gcCallState=0 [GCST_NULL||]
212233.095 6 4 2 LineEvCallState_GCEV_RELEASECALL begin
212233.095 6 4 2 ls set Null_InGuardTimeAfterEndOfCall (scriptstate=LS_NULL_AWAITINGCALLS)
212233.095 6 4 2 ScriptWorkingMode set Idle_WaitingForNextCall, (called from gcev_releasecall)
212233.095 6 4 2 callstate: left as is (Null_InGuardTimeAfterEndOfCall) as sEvent==GCEV_RELEASECALL. crn=28002b5,ev=2137,GCEV_RELEASECALL,0, sParam1=GCST_NULL
Trace shows that the "On Hangup" script was started:
and we can see in the trace attached the first two modules of that script being ran:
module "call_end":
and module "update finish call timestamp":
The trace is too short to see what happens, after the module "update finish call timestamp" does the SQL UPDATE (or whether the database update completed OK).
