Caller Id Capability
Hello Support team,
I am almost sure, but wanted to confirm with you regarding Caller ID capability for a Dialogic card.
One customer group we will install our VoiceGuide application has the following board: "Dialogic D/120JCT-LS Media Board"
They want to make sure this card supports caller ID through analog lines.
Would you please confirm the capability of the card?
Thanks a lot for your time.
Those cards do support decoding of the Caller ID information sent.
From D/120JCT data sheet ( http://www.dialogic.com/~/media/products/docs/media/media-processing/6046_D120JCTLS_ds.pdf ) :
Analog Caller Identification
Applicable standards:
Telecordia TR-TSY-000030
Telecordia TR-TSY-000031
TAS T5 PSTN1 ACLIP: 1994 (Singapore)
Modem standard:
Bell 202 or V.23, serial 1200 bits/sec (simplex FSK signaling)
Receive sensitivity –48 dBm (–50 dBv) to –1 dBm
Noise tolerance Minimum 18 dB SNR over 0 to –48 dBm dynamic range for error-free performance
Data formats Single Data Message (SDM) and Multiple Data Message (MDM) formats via API calls and
commands
Line impedance AC coupled 600 Ohm (@ 1.8 kHz) termination during Caller ID on-hook detection interval
Message formats ASCII or binary SDM, MDM message content
