Sub Value In Var
In my database I'm using "SUB" value.
When I get "SUB" value, VG have an problem:
131207.484 6 2 1 state [AKCJA menu 1] Evaluate [$RV[get_menu_1_settings_1_1]]
131207.484 6 2 1 rv replace start [$RV[get_menu_1_settings_1_1]]
131207.484 6 2 1 rv replace end
131207.484 6 2 1 eval
131207.500 6 2 1 CreateInstance ScriptControl objSC is: [system.__ComObject]
131207.500 6 2 1 ERROR v7.2.4160.36381 (2011-05-23 19:12:42.09) VGMTYPE_EVALEXPR InvokeMember Eval : Obiekt docelowy wywołania zgłosił wyjątek.
System.Runtime.InteropServices.COMException (0x800A03EA): Błąd składni
w System.RuntimeType.InvokeDispMethod(String name, BindingFlags invokeAttr, Object target, Object[] args, Boolean[] byrefModifiers, Int32 culture, String[] namedParameters)
w System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
w vgEngine.ScriptRunsStateMachine.(Int32 iLineId, Int32 iModuleIdx)
131207.500 6 2 1 rv add [AKCJA menu 1_Input]{SUB}
131207.500 6 d added AKCJA menu 1_Input | SUB | ( 41 4b 43 4a 41 20 6d 65 6e 75 20 31 5f 49 6e 70 75 74 | 53 55 42 | 79) id=2
131207.500 6 d added AKCJA menu 1_Input | SUB | ( 41 4b 43 4a 41 20 6d 65 6e 75 20 31 5f 49 6e 70 75 74 | 53 55 42 | 103) id=2
131207.500 6 2 1 Eval Expr result:[] stored in RV[akcja_menu_1]
131207.500 6 2 1 path {} not found
131207.500 6 2 1 matching path not found [], try boolean paths.
131207.500 6 2 1 matching path not found (Boolean False)
131207.500 6 2 1 HangupCall, source=Path {Fail} not defined., WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0
131207.500 6 2 1 moduleTitle=[AKCJA menu 1]
131207.500 6 2 1 ScriptWorkingMode set Stopping, (called from HangupCall)
after changing value on "SUBA", VG working right.
130910.359 6 2 1 state [AKCJA menu 1] Evaluate [$RV[get_menu_1_settings_1_1]]
130910.359 6 2 1 rv replace start [$RV[get_menu_1_settings_1_1]]
130910.359 6 2 1 rv replace end [sUBA]
130910.359 6 2 1 eval[sUBA]
130910.359 6 2 1 CreateInstance ScriptControl objSC is: [system.__ComObject]
130910.359 6 2 1 objReturn is NULL for input=[sUBA], try with Cstr
130910.359 6 2 1 rv add [AKCJA menu 1_Input]{SUBA}
130910.359 6 d added AKCJA menu 1_Input | SUBA | ( 41 4b 43 4a 41 20 6d 65 6e 75 20 31 5f 49 6e 70 75 74 | 53 55 42 41 | 79) id=2
130910.359 6 d added AKCJA menu 1_Input | SUBA | ( 41 4b 43 4a 41 20 6d 65 6e 75 20 31 5f 49 6e 70 75 74 | 53 55 42 41 | 103) id=2
130910.359 6 2 1 rv add [AKCJA menu 1]{SUBA}
130910.359 6 d added AKCJA menu 1 | SUBA | ( 41 4b 43 4a 41 20 6d 65 6e 75 20 31 | 53 55 42 41 | 80) id=2
130910.359 6 d added AKCJA menu 1 | SUBA | ( 41 4b 43 4a 41 20 6d 65 6e 75 20 31 | 53 55 42 41 | 104) id=2
130910.359 6 2 1 rv add [akcja_menu_1]{SUBA}
130910.359 6 d added akcja_menu_1 | SUBA | ( 61 6b 63 6a 61 5f 6d 65 6e 75 5f 31 | 53 55 42 41 | 81) id=2
130910.359 6 d added akcja_menu_1 | SUBA | ( 61 6b 63 6a 61 5f 6d 65 6e 75 5f 31 | 53 55 42 41 | 105) id=2
130910.359 6 2 1 Eval Expr result:[sUBA] stored in RV[akcja_menu_1]
130910.359 6 2 1 path {SUBA} found (at offset 89)
130910.359 6 2 1 FindNextVgmTitleInPathList: next module title is=[iD_menu_2]
I'm using "SUB" value in other part of my System, so i can't change this value. Can You help me?
SUB is a reserved word.
In your evaluate expression module [AKCJA menu 1] change the expression:
to be:
"$RV[get_menu_1_settings_1_1]"
(just add quotes)
This should force the evaluate expression module to treat the value as a string, rather then interpret it as a reserved word.
