Pass Information From One Call To Another
Nira wrote:
I'm trying to count the calls' number (to define a variable -n - that its
value shows how much calls have been done until the current call), because I
want each caller to hear a different message according to the call's number.
Here is the vb code I wrote:
Dim cond, strResultVariables
n=n+1
If n/4= int(n/4) then
 cond = "music"
ElseIf n/3= int(n/3) then
 cond = "apology_cond"
ElseIf n/2= int(n/2) then
 cond = "no_4"
Else
 cond = "active"
End If
strResultVariables = "[condition]{" & cond & "}"
iRet = WriteResultFile(strResultVariables)
Function WriteResultFile(strResult)
Const ForReading = 1, ForWriting = 2, ForAppending = 8
Dim filename, fso, ts, outdata, outdata2, outdata3
filename = "VGRUNRESULT_$RV_DEVICEID.TXT"
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.OpenTextFile(filename, ForWriting, True)
ts.WriteLine (strResult)
ts.Close
WriteResultFile = 0
End Function
The problem is that n becomes equal to zero with every call. How can I make
n "remember" its value, so in the next call its value will grow by 1?
To be able to pass the value of 'n' from one call to another you must save it somewhere, and then each call will read the current value of 'n' from that place, then update the value of 'n', and then the next call can read it etc etc...
you can save information in :
- Text file (can use VB Script module to read/write text file)
- Database (can use DB Query module to read/write Database file)
- Excel Spreadsheet (can use VB Script module to read/write Excel file)
But in your case where you want to mix up the message played to caller it's probably best to determine which message should be played based on the value of the $RV_SECOND Result Variable...
Thanks!
As you can see in the code below, I'm saving n's value in a text file.
Now the problem is that while the code runs on a regular visual basic (version 6), it ISN'T runs as a part of interactive voice guide script. I mean, an error message eppears when the code reaches the vbs module.
Any idea why? Thanks in advance!
Dim cond, n, strResultVariables
open "D:\nira\n.txt" for input as 1
input #1, n
close 1
cond = "music"
cond = "no_4"
Else
cond = "active"
End If
n=n+1
open "D:\nira\n.txt" for output as 1
write #1, n
close 1
ts.Close
WriteResultFile = 0
End Function
one thing I found is that you can add msgbox's in your code, and they will popup on the server. a very useful way to debug.
stick plenty of msgbox's in your code to display variables and you'll soon find the problem.
it probably is asking a bit much of the voiceguide support people to get them to debug your own code.
Tim
Another thing to keep in mind is that VBScript is a cut down version of Visual Basic - so not all Visual Basic functions will work in VB Script.
Also when an error pos up in VB Script quite often it has the line number and the character number in it, so you can tell exactly where the error occurs..
Just looking at the script quickly, I'd recommend using a different method of reading the text file.
There is an example in VoiceGuide's Help file - section on VB Script module:
set fileVmBoxList = fso.OpenTextFile("D:\nira\n.txt")
sEntireFile = fileVmBoxList.ReadAll
set fileVmBoxList = Nothing
sEntireFile will then contain the information read from the file...
