Xml As Datasource
I need to read data from xml or php file.
Any suggestions how simple do it?
I tried with your internet portal scenario but without success.
Is the XML file is accessible from a remote web server over http ?
The approach demonstrated in the "Internet Portal" demo script should be used in this case (after modifying to read in the right site/file).
Can you post the script that you are using?
I need to reed xml data from web server.
VG Internet Portal script working after changing data identifier.
