Script not working
Hi! i have a Dialogic card D/600SC-2E1 running in Windows 2000 server then i installed the Voiceguide 5.1.3 and follow the instructions from the website. However, i am having problems using the script designer it seems that my voicemail design is not working.. can you give me a sample for a voicemail script and what else should i do to make it work. Or can you give a sample script just to test if it is working or not.
Thanks,
Bon
Have you had a look at the "Voicemail Server" sample script?
If you can post the script which you are using along with a description of what you are trying to achieve we can have a look at it and advise how the script should be set up...
I tried using the voicemail sample script same problem occur. I'll show you the event log.....
45031 5 tapie linedevstate 2048 0 0
45109 5 tapie callstate OFFERING 66220 0 4
45140 5 Lev_CallerID [8421,]
45140 5 tapie callinfo CALLEDID
45140 5 tapie callinfo ORIGIN
45140 5 tapie ring 0
51031 5 tapie ring 2
51046 5 Answer the call
51062 5 lineAnswer(66220) => 66203
56765 5 tapie callstate DISCONNECTED 66220,0,0
56781 5 ERROR 4.9.0 Unknown State [0]
56796 5 PlaySoundStop ok
56812 5 HangupCall called from []
56812 5 Hanging up call...
56812 5 PlaySoundStop ok
56843 5 Waiting for a call...
56859 5 fnHangupCall end
56859 5 tapi Reply 66203 0
56859 5 tapie linedevstate 2048 0 0
56875 5 tapie callstate IDLE 66220 0 0
56875 5 WorkingMode@Idle=
56890 5 LineState(iLineId).iVgsIdx = 0
56906 5 set EV_TIMEOUT_TIMETOREINITLINE 1
56937 5 set EV_TIMEOUT_TIMETOREINITLINE 2
56937 5 tapi Reply 66186 0
57953 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
57953 5 ReinitTelephony due to IDLE start
58000 5 tapic lineDeallocateCall(MainCall:66220) 0
58203 5 lineOpen(5) => 0
58218 5 Waiting for a call...
58218 5 lineOpen(5)LineHandle=66169
Script.doc
By the way im using Dialogic ph_r2_i protocol and our Pabx is Nortel Option 61 release 23.
Thanks,
Bon
Dialogic_TSP.doc
Edited by bon420ph
Can you answer calls on this system using Dialogic’s TALKER32 Sample App?
Can you use any other (non-TAPI) Dialogic app to answer calls on this system?
I tried using Dialogic’s TALKER32 Sample App...
LINE INFO
Total calls = 1,
dwNumOpens = 1,
dwOpenMediaModes = 12,
dwNumActiveCalls = 1
dwNumOnHoldCalls = 0,
dwNumOnHoldPendCalls = 0,
dwLineFeatures = 17
, dwDevStatusFlags = INSERVICE
LCD DISPLAY -- message length = 80
69 61 6c 6f 67 69 63 20 44 34 31 20 53 65 72 76 69 63 65 20 50 72 6f 76 69 64 65 72 0 0 34 0 31 0 20 0 53 0 65 0 72 0 76 0 69 0 63 0 65 0 20 0 50 0 72 0 6f 0 76 0 69 0 64 0 65 0 72 0 0 0 0 0 74 61 70 69 2f 6c 69 6e
LED INDICATOR -- message length = 111
6f 6c 3d 70 68 5f 72 32 5f 69 0 0 42 0 31 0 54 0 32 0 39 0 29 0 2c 0 20 0 70 0 72 0 6f 0 74 0 6f 0 63 0 6f 0 6c 0 3d 0 70 0 68 0 5f 0 72 0 32 0 5f 0 69 0 0 0 0 0 3a 0 0 0 ff ff ff ff 30 0 0 0 ff ff ff ff ff 49 3e 32 67 be cd d3 45 38 3c 38 d3 c1 c9 97 92 5b 20 25 1c 19 19 28 e7 30 26 ff af b8 e7
Do i need to have a sound card installed on my server?
Thanks,
Bon
Can you receive calls on this system when using any of the other Dialogic sample apps (or any other apps).
If yes then which app did you test with?
How do i know that i can receive calls from Dialogic’s TALKER32 Sample App? i can only see that the line is being hit but i do not hear any sounds. Do i need a sound card?... We test other app like Axxium by Voxtron its working but we would like to test your software to have another option..
