Problem With Xcopy Or Move Files In Run Module
I convert recorded call from wav to mp3 file and want to copy (or move) mp3 file to mapped folder on other computer.
conversion working properly but copying to mapped network drive doesn't work.
RUN module:
[konwersja_Z]
Type=Run Program
DispSize=69
Txt=Run the program, and read in the results file created. The results supplied can then be used in other parts of the script (see Result Variables).
ProgramToRun=C:\WINDOWS\system32\xcopy.exe /Y c:\callrecord\mp3\*.mp3 p:\test
RunHoldPlay=
RunMode=1
RunWait=1
on {success} goto [nagrania]
on {fail} goto [nagrania]
log file shows:
081835.517 6 4 2 FindNextVgmTitleInPathList: next module title is=[konwersja_Z]
081835.517 6 4 2 qTel add cmd_PlayStop [0,0,0,0,0][||||]
081835.517 6 4 2 play PlaySoundStop ok
081835.517 7 4 2 qTel run cmd_PlayStop
081835.517 6 4 2 task completed LsRunWaitChooseNext iNextVgm=25
081835.517 6 4 2 t timer clear (force=False)
081835.517 6 4 2 RunModule start Run Program, [konwersja_Z], iModuleIdx=25, previous: vgm=23, vgs=5:5
081835.517 6 4 2 state [konwersja_Z] Run Program
081835.517 6 4 2 File.Exists(C:\WINDOWS\system32\xcopy.exe) is true
081835.533 6 4 2 running program=[C:\WINDOWS\system32\xcopy.exe], arguments=[/Y c:\callrecord\mp3\*.mp3 p:\test], windowStyle=NormalFocus, timeout=1
081835.533 6 4 2 ShellExe start [C:\WINDOWS\system32\xcopy.exe][/Y c:\callrecord\mp3\*.mp3 p:\test]
081835.533 6 4 2 Run Program waiting... (processHandle=1456, pid=2084)
081835.533 6 4 2 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE
081836.267 13 7 3 timer EV_TIMEOUT_AFTERIDLE_ALLOWOUT
081836.267 13 7 3 qScr add evScriptEvent 9013 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
081836.267 6 7 3 qScr run evScriptEvent sCode=[EV_TIMEOUT_AFTERIDLE_ALLOWOUT] iActionID=0, crn=0[0|0|0|0|0][|||||]
081836.267 6 7 3 scriptevent EV_TIMEOUT_AFTERIDLE_ALLOWOUT 0|0|0 ||
081836.267 6 7 3 ls set Null (scriptstate=LS_NULL_AWAITINGCALLS)
081836.517 4 4 2 timer EV_TIMEOUT_CHECKONSTATE
081836.517 4 4 2 qScr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE
081836.517 6 4 2 qScr run evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0[0|0|0|0|0][|||||]
081836.517 6 4 2 scriptevent EV_TIMEOUT_CHECKONSTATE 0|0|0 ||
081836.517 6 4 2 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE
081836.533 6 4 2 Process.HasExited error when test (Proces zakończył się, więc żądane informacje nie są dostępne.). Assume completed.
081836.533 6 4 2 task completed. vgm=25, iRunWait=1, iRunWait_ExeResult_NextVgm=0=[]
081836.533 6 4 2 ExeResult_NextVgm has not been set. check for Result file.
081836.533 6 4 2 no result file returned from program (VGRUNRESULT_4.TXT).C:\WINDOWS\system32\xcopy.exe /Y c:\callrecord\mp3\*.mp3 p:\test
081836.533 6 4 2 FindNextVgmTitleInPathList: next module title is=[nagrania]
081836.533 6 4 2 qTel add cmd_PlayStop [0,0,0,0,0][||||]
081836.533 6 4 2 play PlaySoundStop ok
081836.533 6 4 2 task completed LsRunWaitChooseNext iNextVgm=22
081836.533 6 4 2 t timer clear (force=False)
This same command:
"C:\WINDOWS\system32\xcopy.exe /Y c:\callrecord\mp3\*.mp3 p:\test"
in .bat file working properly.
This same command:
Can you then just try running the .bat file from the Run Program module?
You may add some echo statements in the batch file that echo to a log file of your choice when the batch file starts and when it finishes - just to confirm that the batch file was started by VoiceGuide
.bat in RUN module file doesn't work too.
I solve this problem by task in windows witch every minute call .bat file.
But it isn't no effect I need.
Witch kind of echo statements should I add?
As the destination folder seems to be some folder over the network then access permiossions can come into play.
The VoiceGuide service runs by default under a 'Local System' type accunt, and permissions of that account may be different then the permissions of the User account under which you run the batch file.
Sugget you first test with destination folder being on same hard disk.
We tested with the Run Progam module executing the following command line:
C:\WINDOWS\system32\xcopy.exe /Y c:\temp1\*.mp3 c:\temp2
and it worked fine for copying *.mp3 to another folder on same hard disk.
Suggest you confirm first that you can get this simple case working and then move onto setting the permissions to let you access the directory on the remote network hard disk.
163129.953 6 1 1 state [Run Program 2] Run Program
163129.953 6 1 1 File.Exists(C:\WINDOWS\system32\xcopy.exe) is true
163129.953 6 1 1 running program=[C:\WINDOWS\system32\xcopy.exe], arguments=[/Y c:\temp1\*.mp3 c:\temp2], windowStyle=NormalFocus, timeout=1
163129.953 6 1 1 ShellExe start [C:\WINDOWS\system32\xcopy.exe][/Y c:\temp1\*.mp3 c:\temp2]
163129.953 6 1 1 Run Program waiting... (processHandle=11828, pid=4292)
I have tried to move files with
"move /Y c:\callrecord\mp3\*.mp3 \\network_comp\pg_m2\test"
with success, but not in VG RUN script.
170927.407 6 2 1 RunModule start Run Program, [konwersja_Z], iModuleIdx=39, previous: vgm=37, vgs=6:6
170927.407 6 2 1 state [konwersja_Z] Run Program
170927.407 6 2 1 File.Exists(C:\callrecord\TEST.bat) is true
170927.407 6 2 1 running program=[C:\callrecord\TEST.bat], arguments=[], windowStyle=NormalFocus, timeout=1
170927.407 6 2 1 ShellExe start [C:\callrecord\TEST.bat][]
170927.407 6 2 1 Run Program waiting... (processHandle=832, pid=3024)
170927.407 6 2 1 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE
170928.407 23 2 1 timer EV_TIMEOUT_CHECKONSTATE
170928.407 23 2 1 qScr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE
170928.407 6 2 1 qScr run evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0[0|0|0|0|0][|||||]
170928.407 6 2 1 scriptevent EV_TIMEOUT_CHECKONSTATE 0|0|0 ||
170928.407 6 2 1 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE
170928.407 6 2 1 Process.HasExited error when test (Proces zakończył się, więc żądane informacje nie są dostępne.). Assume completed.
170928.407 6 2 1 task completed. vgm=39, iRunWait=1, iRunWait_ExeResult_NextVgm=0=[]
170928.407 6 2 1 ExeResult_NextVgm has not been set. check for Result file.
170928.407 6 2 1 no result file returned from program (VGRUNRESULT_2.TXT).C:\callrecord\TEST.bat
Have you tried copying files to another folder on same hard disk?
Someting like this:
Suggest you confirm first that you can get this simple case working and then move onto setting the permissions to let you access the directory on the remote network hard disk for apps that run under a 'Local System' type account.
(or change the account under which the VoiceGuide service starts?)
So this looks like a permissions issue when accessing remote drive.
There is some information online about configuring systems to ensure Windows Services can access networked drives.
(VoiceGuide runs as a Windows Service)
Eg: http://serverfault.com/questions/177139/windows-service-cant-access-network-share
Searching Google for "Windows service cannot access network drive" or similar should yield further results.
When I call .bat file directly it's working. VG call this .bat file in RUN module without success.
.bat file include:
xcopy /Y c:\callrecord\mp3\*.wav p:\
When you call the .BAT file directly you are doing so using a different user account with different privileges then the account that the Windows Service is using.
maybe try setting the Windows service to run under the same account that you are using when logged into the machine?
Which version of Windows is used on this system?
Which version of Windows is used on system on which the "p:\" drive/directory is located?
