Vb Script Module
hi
i just want to know how to generate an error in VB Script so that it goes to the failure path
tks - Hitesh
Use the VoiceGuide's COM interface to return the result back to VoiceGuide. If you just want to return "fail" you can use:
vg.Run_ResultReturn $RV_LINEID, "fail"
set vg = Nothing
i tried it but its giving me an error
"ActiveX can't create object "Voiceguide.Commandlink"
tks - hitesh
Only v5.0 onwards supports COM interface. Before that you needed to use a "Result File" to return information to VoiceGuide. Please read the VG Help file's sections on "VB Script module" and "Run Program module" for more information on Result Files..
the help file is not explaining this concept properly
could u pls do that for me
tks - Hitesh
The Result File needs to be called VGRUNRESULT_LineNumber.TXT
The syntax for the Result File can be:
SUCCESS|FAIL
Result Variable
There is sample code provided in the "Run VB Script Module" section of VG Help file:
Function WriteResultFile(strResult)
  Const ForReading=1, ForWriting=2, ForAppending=8
  filename = "VGRUNRESULT_$RV_DEVICEID.TXT"
  Set fso = CreateObject("Scripting.FileSystemObject")
  Set ts = fso.OpenTextFile(filename, ForWriting, True)
  ts.WriteLine(strResult)
  ts.Close
  WriteResultFile=0
  'always deallocate after use...
  set ts = Nothing
  set fso = Nothing
end function
where should i place these result files b'coz when i put this function in my script, it gives an error "file not found"
and where should i use this function in my script and what value to be passed for the function (value of strResult)
tks - Hitesh
The result files should be placed in the same directory where the script (.VGS file) is located.
strResult should be assigned whatever the result file should contain. most of the time that's just "success" or "fail"
