Delete Message Error
When I listen my messages, if I am at the last message and I press 2, 3 or 6 to go to next message, I listen a beep. Normal, but if I press 3 to delete this message (after the last message) vbs scrpt popup an error message 'Error vbs_0.vbs File not exist in line 95 caract 3'
I correct this problem in the script with an if Fso.FileExist but I have 5.0.2000 PRO version and my modification is overwrited if I run VoiceGuide.
Thank you
Please update to v5.1 (current release is 5.2.1) and see if this fixes the problem - many changes and fixes to voicemail scripts were made in v5.1
Just uninstall v5.0 and then install v5.1 (preferably in a different directory)
