Getting Started With Autodialer
Hi there.
I've downloaded the beta version 5.1.2301 (on trial), and am trying to get it to run on a machine with XP and a voice modem. My intention was to dial a set of predefined numbers at predefined times, each time playing a different wav file as a message. I though I'd try to achieve this through creating a suitable OutDial_New.txt file, but I haven't managed to get much to work, including the examples in the help file.
Here's a sample OutDial_New.txt file I'm using:
01:23 AM 31/10/03, "07974357087", 0, 2, none, C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav, C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav,
The entries seem to load, and the modem dials but then something goes wrong. In the log there's often a bit that looks like this:
Dialing: Playing introduction message
013007.44 0 Script Load C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav
013007.44 -1 ERROR 5.1.2301 VgsScriptLoad [C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav]:0
013007.44 0 Not loaded: C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav
013007.45 0 ERROR 5.1.2301 Loading Script err=-1, C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav
013007.45 0 StartLoadedVgs at 31/10/2003 01:30:07
013007.45 0 ERROR 5.1.2301 StartLoadedVgs: Script not initialised for this line
What's wierd too is that to start with the phone I was calling would ring, but now this doesn't always happen either. Note that I'm using the WAV files from the system folder provided with the programme so they should be in the right format.
WHere am I going wrong?
Many Thx
R
Full Log Below
012919.91 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.txt
012919.92 0 dial callque insert tel:"07974357087" scr:C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav time:310310130 esc:
012919.92 0 Loaded 1 entries.
013000.97 0 dial callque update id=18 next call time 0310310132
013000.97 0 dial callque DB update returned
013000.98 0 dial found entry: tel["07974357087"] ann[none] vgs[C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav] am[C:\Program Files\VoiceGuide\system\voice\MaxRecTime.wav]
013000.98 0 Calling MakeCallEx(07974357087)
013001.00 0 Dialing: 07974357087
013001.00 0 MakeCall => 66000
013001.00 0 TapiCbTrigSet 66000 7002
013001.02 0 tapi Reply (LineEvReply) ok 66000 0
013001.02 0 TapiCbTrigClear
013001.02 0 callstate DIALING 66154 0 0
013001.03 0 callstate PROCEEDING 66154 0 0
013007.42 0 callstate CONNECTED 66154,0,0
013007.42 0 WorkingModeTAPI@Connected=
013007.42 0 WorkingModeScript@Connected=
013007.42 0 Dialing: Playing introduction message
013007.47 0 dial callque delete id=18
013007.58 0 callstate DISCONNECTED 66154,1,0
013007.58 0 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
013007.58 0 dial callque delete id=18
013007.59 0 dial no escalation info
013007.59 0 Hanging up call... [Disconnect in LsWaitAfterDialingOut]
013007.61 0 RecSoundStop ok
013007.61 0 PlaySoundStop ok
013007.61 0 Waiting for a call...
013007.61 0 fnHangupCall end
013007.63 0 callstate IDLE 66154 0 0
013007.63 0 WorkingMode@Idle=
013007.63 0 LineState(iLineId).iVgsIdx = 0
013007.64 0 tapi Reply (LineEvReply) ok 66035 0
013007.64 0 tapi Reply (LineEvReply) ok 66137 0
013008.64 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
013008.64 0 ReinitTelephony due to IDLE start
013008.64 0 tapic lineDeallocateCall(MainCall:66154) 0
013008.69 0 lineOpen(0) => 0
013008.70 0 Waiting for a call...
013008.70 0 lineOpen(0)LineHandle=66086
