Starts Playing Before Answer + Hang Off Phone
Hi
1. Problem
I am using a Voicemodem to dial up with Voiceguide dialer.
The problem is that if the person who receives the call answer fast “under 1 Seconds “ the dialer do not recognize that the phone is answered and then the voiceguide dialer hangs up the phone. If the person I slow “ over 1 S “ the dialer works fine and the script starts running.
What can I do to solve this problem???
We are trying to find a dialogic card, but in the meantime before we acquire a dialogic card we must use a standard Voice modem.
2. Problem
when the person receiving the call is slow “ over 2 seconds “ the script starts running and the wav file starts playing before the person has answered the phone.
Best regards
Dennis Udengaard
Brewerygroup Denmark
Dju@bryggerigruppen.dk
Are you referring to the "Please press 1 to accept this call.." message? That message will play in a loop when a Voice modem is used - but if you have specified "none" for welcoming message then the script will start immediately.
this log is when tho phone is answered fast and voiceguide hangs op the phone..
110302.61 0 dial callque update id=158 next call time 0310311108
110302.61 0 dial callque DB update returned
110302.61 0 dial found entry: tel[66851] ann[NONE] vgs[C:\Program Files\VoiceGuide\Ceres\BREWHOUSE\URTNEDSVALING\URTNEDSVALING.vgs] am[NONE]
110302.63 0 Calling MakeCallEx(66851)
110302.63 0 Dialing: 66851
110302.63 0 MakeCall => 66032
110302.63 0 TapiCbTrigSet 66032 7002
110302.63 0 tapi Reply (LineEvReply) ok 66032 0
110302.63 0 TapiCbTrigClear
110302.63 0 callstate DIALING 65980 0 0
110302.63 0 callstate PROCEEDING 65980 0 0
110313.52 0 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE
110313.52 0 dial callque update id=158 next call time 0310311108
110313.52 0 dial callque DB update returned
110313.52 0 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE]
110313.52 0 RecSoundStop ok
110313.52 0 PlaySoundStop ok
110313.52 0 Waiting for a call...
110313.52 0 fnHangupCall end
110315.71 0 Hanging up call...(2)
110315.71 0 RecSoundStop ok
110315.71 0 PlaySoundStop ok
110315.71 0 Waiting for a call...
110315.71 0 fnHangupCall end
110315.71 0 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
110315.71 0 tapi Reply (LineEvReply) ok 66014 0
110330.02 0 callstate DISCONNECTED 65980,1,0
110330.02 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
110330.02 0 Hanging up call...
110330.02 0 RecSoundStop ok
110330.04 0 PlaySoundStop ok
110330.04 0 Waiting for a call...
110330.04 0 fnHangupCall end
110330.04 0 callstate IDLE 65980 0 0
110330.04 0 WorkingMode@Idle=
110330.04 0 LineState(iLineId).iVgsIdx = 0
110330.04 0 tapi Reply (LineEvReply) ok 66031 0
110330.05 0 tapi Reply (LineEvReply) ok 66049 0
110331.04 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
110331.04 0 ReinitTelephony due to IDLE start
110331.04 0 tapic lineDeallocateCall(MainCall:65980) 0
110331.05 0 lineOpen(0) => 0
110331.05 0 Waiting for a call...
110331.05 0 lineOpen(0)LineHandle=66066
Looks like the system is hanging up at the same time as it is trying to dial - how was this outbound call queued? The Answer timeout should be reasonable number (15 seconds at least) and it is now being set to 0.
