Time Evaluation
Hi there!
We are using VG for 3-4 weeks now, qiute satissfied I must say, and encountered this problem now. We would like to make script that will play different messages for working/ non working hours. I have red VG help file regarding this issue, tried to adopt example script, but result is not what I was expected. I attached files and corresponding event logs. System is Win 98, VG 4.9. With script "centrala_2", VG is detecting hours correctly and corresponding message is played. If I load script "centrala_1", VG replies ERR 1002 and takes the same path all the time. The script "centrala_1" is a bit extended version of example given in help file. Can you please check what I did wrong because I can't figure it out?
Thanks in advance.
Livio
vgs_and_log.zip
In centrala_1 starting module (Vrijeme) the brackets are not balancing in the time/day expression..
I think adding a single "(" at the very beginning of the expression should fix the problem...
