Can't Record Prompt
I am unable to record a prompt on this combination of software, Win7 Voiceguide 7.2.3 dialogic R6 build 250. The identical vg version is working fine on Win2003, running the same application.
The log reports 'silence detected'.
What happens is that when I am about to record the prompt, the line hangs up.
I have tried the Dialogic Demo, voice Ansrmt - this records fine.
not_rec_prompt.zip
Have you used the Dialogic drivers that are intended for use on Win7, or did you use the same ones as were used on Win2003?
Could you please post Dialogic's RTF logs as well as VoiceGuide's ktTel logs that capture system startup and the call.
The problem was my side, I did not create the prompt folder, causing the problem - the confusing message was that (silence was presumably detected).
Thanks as always for excellent support
