Disconnect Transfered Call
I connected call with Dialout and Conference - monitored transfer module.
next is play module (waiting for a maximum duration time in prepaid solution)
I need to terminate connection with target number (outside) and back to next element in my script.
If maximum conversation time is known at connection time then you can just use a Timeout path in the Play module. (You can use a Result Variable for the timeout seconds value).
Otherwise you can have an external program call a Bridge_Disconnect and Line_Hangup API functions.
http://www.voiceguide.com/vghelp/source/html/com_bridge_disconnect.htm
http://www.voiceguide.com/vghelp/source/html/com_line_hangup.htm
and have the 'other_line_disconnect" path in the play module, which is taken when the other side of conference call hangs up.
Result Variables ($RVs) are created on the fist channel which advise you of the ID/Port of the second line used. The vgEngine trace shows the $RVs created.
I found var: $RV[Conf_LineId_2] but doesen't work this command
vg.Bridge_Disconnect $RV[Conf_LineId_2]
set vg = Nothing
Bridge_Disconnect require both of line to disconnect
vg.Bridge_Disconnect $RV_LINEID, $RV[Conf_LineId_2]
set vg = Nothing
How to disconnect only $RV[Conf_LineId_2]?
Note that if you want to hangup just the outgoing leg of the tromboned connection then you need to handle some of the OTHER_LEG_ events that are sent to the original leg of call.
These OTHER_LEG events usually result in the original line being hung up as well, unless there is a path in the current module that handles that event.
Just have a path like this in your "just wait" Play module:
on {OTHER_LEG_Disconnected} goto [2nd leg hung up]
(you will need a module titled "2nd leg hung up" in order fro this path to work).
112754.056  6  16   6       qScr  add   evScriptEvent 0 OTHER_LEG_Disconnected
112754.056  6  16   6       qScr  run   evScriptEvent sCode=[OTHER_LEG_Disconnected] iActionID=0, crn=0[16384|0|64|0|0][|||||]
112754.056  6  16   6       path {OTHER_LEG_Disconnected} not found
112754.056  6  16   6       hanging up 1st leg of call (other leg cause)
