Password
Hello i want to have for special guest when they press the number 9
that they hear type your 4 number password (Password for all members the same exemple 5273) and when the password is right then go futher in the menu.
can somebody help me,
thanks Joost
On user pressing '9' send the call to a 'Get Numbers' module, and in that module just specify a path like this:
on {5273} goto [Next Module]
where 'Next Module' is the name of the module to go to if the password is correct (ie: 5273 was entered)
the Get number module should be probably set up to 'accept exactly 4 digits'.
thanks for the information.
but it din't work.
i have a softmodem is that probely the problem.
thanks
joost
Which part did not work?
Could you please post a the script used and a copy of VoiceGuide's Debug Printout which captures an incoming call, this will allow us to see what is going wrong.
I now now what i did wrong.
i forget the " If the 'Success' path is not defined then the caller will be asked to enter the number again."
module access
On {5724} goto [product1]
on {success} goto [????]
on {fail} goto [access]
when is voiceguide usesing the command success.
thanks,
Joost
