Using Webservice In Voiceguid Through Run Vbscript Module
Calling WebService method which accept three parameters and return one value.
this is the code i am using in VBScript module.
Set soapClient = CreateObject("MSSOAP.SoapClient30")
soapClient.MSSoapInit "http://10.10.40.10/mescoreservice/webservice.asmx?WSDL"
Dim sText
Set sText = soapClient.Loginuser(Ahmed,6648220,#1,#1)
vg.Run_ResultReturn $RV_LINEID, sText
set vg = Nothing
----Thanks for always replying the post.
0530_1050_vgEngine.txt
VBScript_Demo.vgs
i am getting an error..
please check the code and reply for the solution.
Dim sText
Set sText = soapClient.Loginuser(Ahmed,6648220,#1#)
set vg = Nothing
--check the trace file which i have attached in my previous post.
Trace shows that script was started and then VG waits for script to complete.
Would recommend that you add some Admin_TraceLogAdd entries to your script to be able to see what stages the script are taking a long to execute.
(see http://www.voiceguide.com/vghelp/source/html/com_admin_tracelogadd.htm )
Most likely it's the web service interaction.
105049.622  6   7   4 state [Run VB Webservice] type: Script_VBScript, iRunWait=1
105049.625  6   7   4       rv    replace start
Dim sText
set vg = Nothing
105049.627  6   7   4       rv    replace end   [set soapClient = CreateObject("MSSOAP.SoapClient30")
Dim sText
vg.Run_ResultReturn 7, sText
set vg = Nothing]
105049.627  6   7   4       script will be ran from file: C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs
105049.627  6   7   4       delete existing: C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs
105049.631  6   7   4       current objVbsOrExeProcess=
105049.631  6   7   4       RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs][] timeout=60 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
105049.631  6   7   4       objVbsOrExeProcess.Start call
105049.685  6   7   4       RunVBScriptFile just started. Handle=12076, Id=5872, StartTime=5/30/2011 10:50:49 AM, HasExited=False
105049.686  6   7   4       VBScript started [C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs], ProcessHandle=[12076], VbsOrExeProcess.WorkingSet=[86016]
105049.687  6   7   4       RunModule_Script_AfterScriptStarted start
105049.687  6   7   4       waiting. iRunWait=1 (process:12076)
105049.687  6   7   4 t     timer set   1 sec : EV_TIMEOUT_CHECKONSTATE
105050.665 22   7   4 timer EV_TIMEOUT_CHECKONSTATE
vg.Admin_TraceLogAdd 0, 0, "This trace was printed from an external VB Script"
set vg = Nothing
i have used this code but stilll the run VBScript module is waits to complete.... script wait for a result from the running webservice and stuck there.
here i am attaching the script and the trace file.
the webservice method will accepts three string parameters and it return one string parameter.
is the VBScript code which i am using is correct?
and i am storing the returned value in run_result variable...
I got succeeded why i tried to run the webservice through a .exe application and that .exe application will write the data in .txt file which will read by VG in the later module.
-- but this process of creating a .exe application and executing at the run time .. is becoming a big process so we decided to go for direct execution through VBScript.
kindly consider my case and reply as soon as possible, waitng.
0601_1555_vgEngine.txt
Script_WebService_Demo.vgs
Reply as soon as possible because the company were i am working they are testing all the modules of VOICE GUIDE... if we succeeded in them then only we will be going for VOICEGUIDE.. and the organization may take a decision in this month to go for the software or not..
To debug VBScripts you should place Run_ResultReturn calls throughout the VBScript.
Your current VBScript is:
Set node_list = soapClient.GLoginuser(Ahmed,6648220,#1#)
set soapClient = Nothing
vg.Run_ResultReturn $RV_LINEID, node_list
vg.Admin_TraceLogAdd 0, 0, "This trace was printed from an VB Script"
set vg = Nothing
Suggest adding more Admin_TraceLogAdd calls, like this:
vg.Admin_TraceLogAdd 0, 0, "1"
vg.Admin_TraceLogAdd 0, 0, "2"
vg.Admin_TraceLogAdd 0, 0, "3"
vg.Admin_TraceLogAdd 0, 0, "4"
vg.Admin_TraceLogAdd 0, 0, "5"
vg.Admin_TraceLogAdd 0, 0, "6"
set vg = Nothing
And post the trace again.
Please .ZIP up any traces before posting them.
Have you ran your VBScript outside of VoiceGuide to see it it correctly connects with your Web Service?
The Admin_TraceLogAdd traces did not appear in the vgEngine trace. not sure why they did not. Can you please change the VBScript to:
vg.Admin_TraceLogAdd $RV_LINEID, 5, "1"
vg.Admin_TraceLogAdd $RV_LINEID, 5, "2"
vg.Admin_TraceLogAdd $RV_LINEID, 5, "3"
vg.Admin_TraceLogAdd $RV_LINEID, 5, "4"
vg.Admin_TraceLogAdd $RV_LINEID, 5, "5"
vg.Admin_TraceLogAdd $RV_LINEID, 5, "6"
set vg = Nothing
and post traces capturing the call again.
132704.870 6 7 4 scriptevent * 0|0|0 ||
132704.871 6 7 4 LsPlayMsgFinished *,*, [ ], [ ], []
132704.872 6 7 4 path {*} found (at offset 3)
132704.875 6 7 4 FindNextVgmTitleInPathList: next module title is=[Run VB Webservice]
132704.875 6 7 4 rv add [Play Welcome]{*}
132704.875 6 d added Play Welcome | * | ( 50 6c 61 79 20 57 65 6c 63 6f 6d 65 | 2a | 5) id=7
132704.875 6 d added Play Welcome | * | ( 50 6c 61 79 20 57 65 6c 63 6f 6d 65 | 2a | 13) id=7
132704.875 6 7 4 t timer clear (force=False)
132704.875 6 7 4 RunModule start Run VB Script, [Run VB Webservice], iModuleIdx=2, previous: vgm=1, vgs=1
132704.875 6 7 4 state [Run VB Webservice] type: Script_VBScript, iRunWait=1
132704.878 6 7 4 rv replace start
set soapClient = Nothingvg.Admin_TraceLogAdd $RV_LINEID, 5, "5"
set vg = Nothing
132704.880 6 7 4 script will be ran from file: C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs
132704.880 6 7 4 delete existing: C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs
132704.884 6 7 4 current objVbsOrExeProcess=
132704.884 6 7 4 RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs][] timeout=40 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
132704.884 6 7 4 objVbsOrExeProcess.Start call
132704.893 6 7 4 RunVBScriptFile just started. Handle=12260, Id=4888, StartTime=6/2/2011 1:27:04 PM, HasExited=False
132704.894 6 7 4 VBScript started [C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs], ProcessHandle=[12260], VbsOrExeProcess.WorkingSet=[81920]
132704.895 6 7 4 RunModule_Script_AfterScriptStarted start
132704.895 6 7 4 waiting. iRunWait=1 (process:12260)
132704.895 6 7 4 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE
132705.704 22 7 4 timer EV_TIMEOUT_CHECKONSTATE
132705.704 22 7 4 qScr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE
132705.704 6 7 4 qScr run evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0[0|0|0|0|0][|||||]
132705.704 6 7 4 scriptevent EV_TIMEOUT_CHECKONSTATE 0|0|0 ||
132705.709 6 7 4 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE
132705.710 6 7 4 Process.HasExited is false (awaiting process end or COM function call) handle=12260, id=4888, StartTime=6/2/2011 1:27:04 PM
132705.710 6 7 4 .ExitTime returned error.
132705.710 6 7 4 LsRunWaitTillFinished: process still running
132705.711 6 7 4 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE
and also check the attached documents
log.zip
discard my previous post.. this is a minor erro..
use this one
----------- here is the trace file snapshot
110236.556 6 7 4 state [Run VB Webservice] type: Script_VBScript, iRunWait=1
110236.559 6 7 4 rv replace start
soapClient.MSSoapInit "http://10.10.40.10/mescoreservice/webservice.asmx?WSDL"'>http://10.10.40.10/mescoreservice/webservice.asmx?WSDL"
"Set node_list = soapClient.GLoginuser(Ahmed,6648220,#1#)
set vg = Nothing
110236.561 6 7 4 script will be ran from file: C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs
110236.561 6 7 4 delete existing: C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs
110236.565 6 7 4 current objVbsOrExeProcess=
110236.565 6 7 4 RunVBScriptFile [wscript][C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs][] timeout=40 (vbsPath=C:\Program Files\VoiceGuide\temp), start (new Process)
110236.565 6 7 4 objVbsOrExeProcess.Start call
110236.574 6 7 4 RunVBScriptFile just started. Handle=12272, Id=5096, StartTime=6/4/2011 11:02:36 AM, HasExited=False
110236.575 6 7 4 VBScript started [C:\Program Files\VoiceGuide\temp\vbs_7_1.vbs], ProcessHandle=[12272], VbsOrExeProcess.WorkingSet=[86016]
110236.576 6 7 4 RunModule_Script_AfterScriptStarted start
110236.576 6 7 4 waiting. iRunWait=1 (process:12272)
110236.576 6 7 4 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE
here is my .vgs file script
Version=5.0
DefaultModuleDisplayHeight=
StartModule=Play Welcome
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[Play Welcome]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
PlayFile1=C:\Program Files\VoiceGuide\Scripts\Motabei\wave files\welcome.wav
Replay=2,5
strTtsText=press star to continue
on {*} goto [Run VB Webservice]
Position=392,89
[Run VB Webservice]
Type=Run VB Script
DispSize=69
Txt=Run a VB Script.
VbsFileToRun=
VbsWait=1
VbScript=
set vg = Nothing
VbsHoldPlay=
on {success} goto [Play Success]
on {fail} goto [Play Fail]
on {timeout 40} goto [Play TimeOut]
Position=396,199
[Play Success]
Type=Play
DispSize=69
Replay=2,5
strTtsText=success, press star to get the number
on {*} goto [say Numbers Result]
Position=397,300
[Play Fail]
Type=Play
DispSize=69
Replay=2,5
strTtsText=fail, press * to re try
on {*} goto [Play Welcome]
Position=224,309
[Hangup]
Type=Hangup the Call
DispSize=69
Txt=Hangup the call.
Position=407,505
Type=Say Numbers
DispSize=69
Txt=Say the number, amount, date or the digits. See the list o options to see how the number supplied can be interpreted and spoken out...
PlayFile2=$RV_LINEID
Replay=2,5
SayNbrType=Number
on {*} goto [Hangup]
Position=404,398
[Play TimeOut]
Type=Play
DispSize=69
Replay=2,5
strTtsText=Time out, press * to continue
Position=605,307
check for the attached documents
Support team,
you know the address of the webservice that you can access.
you know the method to call and what are the parameter it will accept.
if the passed parameteres matches in the database it will return 3 or else it will return 1.
So know i request the support team to run the Webservice using VBScript module in VOICE GUIDE and then post the solutions.
because this will better it will solve the problem in one single post.. rather than support team suggestin me then i will make the nesseccary changes and again postback in forum..
thanks for your support.. you can acces on the webservice as it is deployed on our server.
-----waiting for the reply.
log.zip
It appears that the web service is on your own local network (IP address 10.10.40.10), so outside users would not be able to immediately access it:
Do simple VBScripts work when ran from VoiceGuide's Run VBScript module?
Have you tried running the Web Service script yourself? ie. not through VoiceGuide but just double clicking on a .VBS file yourself, or running it from command lin using wscript or cscript etc?
yes i have used that webservice .. several times in my projects.
Even i have used the same service in which i have called the same GLoginuser(Ahmed,6648220,#1#)function In VGS.
but there i have created a .exe file which will call to webservice and returns data in .txt file
again RUN Module will read the data from .exe file. but thiss process is very log ..
but when i am trying to use the Service and the same method. it raises in VGS using VBS Script module it waits.
Company is designing a compute system to interact with there customers. nearly they have 10 thousand customers for many several reasons,
bill payment,online problems, call center, help desk, etc ..
so it will be problem if we start the project using .exe files.. because every time we have to follow that big proceedure to interact with webservice.
thats why they tooked a decision to directly communicate with webservices using vbscript which is supported in VOICE GUIDe. but here we are facing the problem..... that you know...
So what should i do further to solve this problem.
-After working for a long time on VBScript module to call a webservice, I got the success.
I will post my script here so that will be helpful for others.
and also the trace files.
Here is the code to run a webservice in VBScript module
soapClient.MSSoapInit("http://localhost/mescoreservice/webservice.asmx?WSDL")
id=$RV[Get UserID]
password=$RV[Get password]
hash="#3#"
value = soapClient.IVR_LoginUser(id,password,hash)
vg.RvSet $RV_LINEID, "value", value
If value = 1 Then
vg.Run_ResultReturn $RV_LINEID, "Success"
Else
vg.Run_ResultReturn $RV_LINEID, "fail"
End If
set vg = Nothing
