Problem With Dtmf
Hi all,
we have a script which is working quite well, but we have auser who is calling from a moblie (a samsung sch-n181) and voiceguide is not picking up on the tones. we have tried both long and short tones and nither are working ? any ideas ?
further tests indicate that this is not the only phone which we are having this problem with.
this is the output from the event log of voiceguide.
180322.20 0 callstate OFFERING 65557 0 4
180322.20 0 ring 1
180322.20 0 Could not obtain handle to kill process. (new call) 2800, 0
180322.20 0 Answer the call at 22/10/2003 6:03:22 PM
180322.20 0 lineAnswer(65557) => 65727
180322.20 0 callstate ACCEPTED 65557 0 0
180325.49 0 tapi Reply 65727 0
180325.49 0 callstate CONNECTED 65557,0,0
180325.49 0 WorkingModeTAPI=
180325.49 0 WorkingModeScript=
180325.49 0 Inband detection not enabled
180325.49 0 StartLoadedVgs at 22/10/2003 6:03:25 PM
180325.50 0 [Thanks for calling] Playing
180325.50 0 [Thanks for calling] Playing (C:\Documents and Settings\jeremyn\Desktop\thankyouforcalling.wav)
180325.55 0 PlaySoundStart ok [C:\Documents and Settings\jeremyn\Desktop\thankyouforcalling.wav]
180325.55 0 RunModule PLAY end
180329.78 0 dtmf 7 (55,2)
180329.78 0 LsPlayMsg 7
180329.78 0 path {7} not found
180331.20 0 Play End line[0] (id=828784)
180331.20 0 LsPlayMsg EV_PLAY_FINISHED
180332.20 0 dtmf 1 (49,2)
180332.20 0 LsPlayMsgFinished 1
180332.20 0 [get_propid] Number Input
180332.20 0 [get_propid] Playing (C:\Documents and Settings\jeremyn\Desktop\propertyid.wav)
180332.25 0 PlaySoundStart ok [C:\Documents and Settings\jeremyn\Desktop\propertyid.wav]
180332.40 0 dtmf 1 (49,2)
180332.40 0 LsGetNbrsPlayWelcMsg 1
180332.41 0 PlaySoundStop ok
180332.41 0 [get_propid] Number Input 1
180338.41 0 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
180338.41 0 path {1} not found
180338.41 0 [get_address] DB Query
180338.41 0 ODBC mode used
180338.75 0 RVreplace start (strlen>100)
180338.76 0 About to execute Retrieve Operation [sELECT bp.propertyID, bp.propLotNo, bp.propunitNo, bp.propstreetNo, bp.propstreetName, bp.propsuburb, bp.agentid, pr.agentName FROM baseproperty bp INNER JOIN primaryAgent pr ON bp.agentID = pr.agentID WHERE propertyID = 1]
180338.95 0 [get_address] movelast err : No current record.
180339.04 0 Hanging up call... [srlib 282]
180339.04 0 RecSoundStop ok
180339.04 0 PlaySoundStop ok
180339.04 0 fnHangupCall end
180340.23 0 callstate DISCONNECTED 65557,1,0
180340.23 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
180340.23 0 Hanging up call...
180340.23 0 RecSoundStop ok
180340.24 0 PlaySoundStop ok
180340.24 0 fnHangupCall end
180340.24 0 callstate IDLE 65557 0 0
180340.26 0 WorkingMode@Idle=
180340.27 0 After Hangup script:[C:\Documents and Settings\jeremyn\Desktop\ftp.vgs]
180340.28 0 LoadedVgs_Find C:\Documents and Settings\jeremyn\Desktop\ftp.vgs at idx=2
180340.30 0 tapi Reply 65779 0
180340.31 0 [ftp file] Run Program
180340.32 0 RVreplace start (strlen>100)
180340.35 0 Run Program continuing...
180340.41 0 On Success path not defined.
180340.42 0 Hanging up call... [Run module 2392]
180340.53 0 HangupCall_Common Mode=AfterHangupRun
180340.54 0 ReinitTelephony due to IDLE start
180340.57 0 tapi Reply 66497 0
180340.60 0 tapic lineDeallocateCall(MainCall:65557) 0
180340.64 0 lineOpen(0) => 0
180340.65 0 Waiting for a call...
180340.66 0 lineOpen(0)LineHandle=65540
180449.10 0 callstate OFFERING 66479 0 4
180449.11 0 ring 1
180449.12 0 Could not obtain handle to kill process. (new call) 2100, 0
180449.14 0 Answer the call at 22/10/2003 6:04:49 PM
180449.15 0 lineAnswer(66479) => 66411
180449.16 0 callstate ACCEPTED 66479 0 0
180452.33 0 tapi Reply 66411 0
180452.34 0 callstate CONNECTED 66479,0,0
180452.35 0 WorkingModeTAPI=
180452.36 0 WorkingModeScript=
180452.37 0 Inband detection not enabled
180452.39 0 StartLoadedVgs at 22/10/2003 6:04:52 PM
180452.40 0 [Thanks for calling] Playing
180452.41 0 [Thanks for calling] Playing (C:\Documents and Settings\jeremyn\Desktop\thankyouforcalling.wav)
180452.47 0 PlaySoundStart ok [C:\Documents and Settings\jeremyn\Desktop\thankyouforcalling.wav]
180452.48 0 RunModule PLAY end
180458.13 0 Play End line[0] (id=915699)
180458.13 0 LsPlayMsg EV_PLAY_FINISHED
180459.71 0 dtmf 1 (49,2)
180459.71 0 LsPlayMsgFinished 1
180459.73 0 [get_propid] Number Input
180459.74 0 [get_propid] Playing (C:\Documents and Settings\jeremyn\Desktop\propertyid.wav)
180459.80 0 PlaySoundStart ok [C:\Documents and Settings\jeremyn\Desktop\propertyid.wav]
180459.95 0 dtmf 1 (49,2)
180459.95 0 LsGetNbrsPlayWelcMsg 1
180459.97 0 PlaySoundStop ok
180459.98 0 [get_propid] Number Input 1
180505.92 0 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
180505.92 0 path {1} not found
180505.93 0 [get_address] DB Query
180505.95 0 ODBC mode used
180506.28 0 RVreplace start (strlen>100)
180506.29 0 About to execute Retrieve Operation [sELECT bp.propertyID, bp.propLotNo, bp.propunitNo, bp.propstreetNo, bp.propstreetName, bp.propsuburb, bp.agentid, pr.agentName FROM baseproperty bp INNER JOIN primaryAgent pr ON bp.agentID = pr.agentID WHERE propertyID = 1]
180506.49 0 [get_address] movelast err : No current record.
180506.59 0 Hanging up call... [srlib 282]
180506.59 0 RecSoundStop ok
180506.61 0 PlaySoundStop ok
180506.63 0 fnHangupCall end
180507.82 0 callstate DISCONNECTED 66479,1,0
180507.82 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
180507.84 0 Hanging up call...
180507.85 0 RecSoundStop ok
180507.86 0 PlaySoundStop ok
180507.87 0 fnHangupCall end
180507.89 0 callstate IDLE 66479 0 0
180507.89 0 WorkingMode@Idle=
180507.91 0 After Hangup script:[C:\Documents and Settings\jeremyn\Desktop\ftp.vgs]
180507.91 0 LoadedVgs_Find C:\Documents and Settings\jeremyn\Desktop\ftp.vgs at idx=2
180507.93 0 tapi Reply 65625 0
180507.95 0 [ftp file] Run Program
180507.96 0 RVreplace start (strlen>100)
180507.98 0 Run Program continuing...
180508.04 0 On Success path not defined.
180508.05 0 Hanging up call... [Run module 2392]
180508.14 0 HangupCall_Common Mode=AfterHangupRun
180508.16 0 ReinitTelephony due to IDLE start
180508.19 0 tapi Reply 65608 0
180508.21 0 tapic lineDeallocateCall(MainCall:66479) 0
180508.23 0 lineOpen(0) => 0
180508.23 0 Waiting for a call...
180508.26 0 lineOpen(0)LineHandle=65591
180532.40 0 callstate OFFERING 66326 0 4
180532.42 0 ring 1
180532.43 0 Could not obtain handle to kill process. (new call) 2180, 0
180532.44 0 Answer the call at 22/10/2003 6:05:32 PM
180532.46 0 lineAnswer(66326) => 66514
180532.47 0 callstate ACCEPTED 66326 0 0
180535.69 0 tapi Reply 66514 0
180535.71 0 callstate CONNECTED 66326,0,0
180535.72 0 WorkingModeTAPI=
180535.73 0 WorkingModeScript=
180535.74 0 Inband detection not enabled
180535.75 0 StartLoadedVgs at 22/10/2003 6:05:35 PM
180535.77 0 [Thanks for calling] Playing
180535.78 0 [Thanks for calling] Playing (C:\Documents and Settings\jeremyn\Desktop\thankyouforcalling.wav)
180535.84 0 PlaySoundStart ok [C:\Documents and Settings\jeremyn\Desktop\thankyouforcalling.wav]
180535.85 0 RunModule PLAY end
180541.50 0 Play End line[0] (id=959062)
180541.50 0 LsPlayMsg EV_PLAY_FINISHED
180542.42 0 dtmf 1 (49,2)
180542.42 0 LsPlayMsgFinished 1
180542.44 0 [get_propid] Number Input
180542.45 0 [get_propid] Playing (C:\Documents and Settings\jeremyn\Desktop\propertyid.wav)
180542.51 0 PlaySoundStart ok [C:\Documents and Settings\jeremyn\Desktop\propertyid.wav]
180545.96 0 Play End line[0] (id=965731)
180545.96 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
180549.64 0 dtmf 1 (49,2)
180549.64 0 LsGetNbrsRxDigits 1
180549.66 0 [get_propid] Number Input 1
180550.08 0 dtmf 2 (50,2)
180550.08 0 LsGetNbrsRxDigits 2
180550.10 0 [get_propid] Number Input 12
180550.52 0 dtmf 5 (53,2)
180550.52 0 LsGetNbrsRxDigits 5
180550.54 0 [get_propid] Number Input 125
180551.02 0 dtmf 6 (54,2)
180551.02 0 LsGetNbrsRxDigits 6
180551.03 0 [get_propid] Number Input 1256
180551.50 0 dtmf 3 (51,2)
180551.50 0 LsGetNbrsRxDigits 3
180551.51 0 [get_propid] Number Input 12563
180552.73 0 dtmf # (35,2)
180552.74 0 LsGetNbrsRxDigits #
180552.75 0 path {12563} not found
180552.77 0 [get_address] DB Query
180552.79 0 ODBC mode used
180553.18 0 RVreplace start (strlen>100)
180553.18 0 About to execute Retrieve Operation [sELECT bp.propertyID, bp.propLotNo, bp.propunitNo, bp.propstreetNo, bp.propstreetName, bp.propsuburb, bp.agentid, pr.agentName FROM baseproperty bp INNER JOIN primaryAgent pr ON bp.agentID = pr.agentID WHERE propertyID = 12563]
180553.41 0 [get_address] movelast err : No current record.
180553.55 0 Hanging up call... [srlib 282]
180553.57 0 RecSoundStop ok
180553.57 0 PlaySoundStop ok
180553.59 0 fnHangupCall end
180554.79 0 callstate DISCONNECTED 66326,1,0
180554.80 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
180554.81 0 Hanging up call...
180554.82 0 RecSoundStop ok
180554.83 0 PlaySoundStop ok
180554.85 0 fnHangupCall end
180554.86 0 callstate IDLE 66326 0 0
180554.87 0 WorkingMode@Idle=
180554.89 0 After Hangup script:[C:\Documents and Settings\jeremyn\Desktop\ftp.vgs]
180554.90 0 LoadedVgs_Find C:\Documents and Settings\jeremyn\Desktop\ftp.vgs at idx=2
180554.91 0 tapi Reply 66309 0
180554.92 0 [ftp file] Run Program
180554.93 0 RVreplace start (strlen>100)
180554.96 0 Run Program continuing...
180554.98 0 On Success path not defined.
180554.99 0 Hanging up call... [Run module 2392]
180554.00 0 HangupCall_Common Mode=AfterHangupRun
180555.01 0 ReinitTelephony due to IDLE start
180555.03 0 tapi Reply 66462 0
180555.13 0 tapic lineDeallocateCall(MainCall:66326) 0
180555.21 0 lineOpen(0) => 0
180555.22 0 Waiting for a call...
180555.23 0 lineOpen(0)LineHandle=66377
Are you using a Dialogic card or a Voice Modem?
Can you set up a script with a "Record" module and have that user call in and press the keys so that the Record module will record all his keypresses and then zip up the file and post it in this forum - this will allow us to see if this phone generates the DTMF tones properly...
I can see from a file format the it was recorded using Voice modem.
Some voice modems cannot detect DTMF tones reliably - the only solution is to try using another modem or (better option) buy a Dialogic card...
