Running Program
I try to convert recorded call as wav convert to mp3 format.
I use "RUN PROGRAM" MODULE in call termination script with command line: "callrecord\ffmpeg.exe -i $RV[session_id].wav $RV[session_id].mp3"
but nothing happens
this command working properly
C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe -i 11012811591454.wav 11012811591454.mp3
Suggest specifying the full path to ffmpeg.exe, as you have specified in the working example.
Please post the vgEngine trace capturing the call.
Please .ZIP up traces before posting.
Have you tried providing the full file path specification for the filenames passed in as arguments?
ffmpeg.exe may need full paths specified so that it knows where to find/put the files.
113813.338 6 4 2 state [konwersja] Run Program
113813.338 6 4 2 rv replace start [C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe $RV[session_id].wav $RV[session_id].mp3]
113813.338 6 4 2 rv replace end [C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe 11012811373254.wav 11012811373254.mp3]
113813.338 6 4 2 File.Exists(C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe) is true
113813.338 6 4 2 running program=[C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe], arguments=[11012811373254.wav 11012811373254.mp3], windowStyle=NormalFocus, timeout=1
113813.338 6 4 2 ShellExe start [C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe][11012811373254.wav 11012811373254.mp3]
113813.353 6 4 2 Run Program waiting... (processHandle=39392, pid=4652)
113813.353 6 4 2 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE
113814.322 22 4 2 timer EV_TIMEOUT_CHECKONSTATE
113814.322 22 4 2 qScr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE
113814.322 6 4 2 qScr run evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0[0|0|0|0|0][|||||]
113814.322 6 4 2 scriptevent EV_TIMEOUT_CHECKONSTATE 0|0|0 ||
113814.322 6 4 2 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE
113814.353 6 4 2 Process.HasExited error when test (Proces zakoñczy³ siê, wiêc ¿¹dane informacje nie s¹ dostêpne.). Assume completed.
113814.353 6 4 2 task completed. vgm=92, iRunWait=1, iRunWait_ExeResult_NextVgm=0=[]
113814.353 6 4 2 ExeResult_NextVgm has not been set. check for Result file.
113814.353 6 4 2 no result file returned from program (VGRUNRESULT_4.TXT).C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe $RV[session_id].wav $RV[session_id].mp3
113814.353 6 4 2 FindNextVgmTitleInPathList: next module title is=[Hangup the Call 1]
115959.791 6 4 2 state [konwersja] Run Program
115959.791 6 4 2 rv replace start [callrecord\ffmpeg.exe -i $RV[session_id].wav $RV[session_id].mp3]
115959.791 6 4 2 rv replace end [callrecord\ffmpeg.exe -i 11012811591454.wav 11012811591454.mp3]
115959.791 6 4 2 File.Exists(C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe) is true (orignal relative path was: callrecord\ffmpeg.exe)
115959.791 6 4 2 running program=[C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe], arguments=[-i 11012811591454.wav 11012811591454.mp3], windowStyle=NormalFocus, timeout=1
115959.791 6 4 2 ShellExe start [C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe][-i 11012811591454.wav 11012811591454.mp3]
115959.791 6 4 2 Run Program waiting... (processHandle=39460, pid=5708)
115959.791 6 4 2 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE
115959.806 22 4 2 db odbc query completed.
120000.619 4 4 2 timer EV_TIMEOUT_CHECKONSTATE
120000.619 4 4 2 qScr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE
120000.619 6 4 2 qScr run evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0[0|0|0|0|0][|||||]
120000.619 6 4 2 scriptevent EV_TIMEOUT_CHECKONSTATE 0|0|0 ||
120000.619 6 4 2 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE
120000.619 6 4 2 Process.HasExited error when test (Proces zakoñczy³ siê, wiêc ¿¹dane informacje nie s¹ dostêpne.). Assume completed.
120000.619 6 4 2 task completed. vgm=86, iRunWait=1, iRunWait_ExeResult_NextVgm=0=[]
120000.619 6 4 2 ExeResult_NextVgm has not been set. check for Result file.
120000.619 6 4 2 no result file returned from program (VGRUNRESULT_4.TXT).callrecord\ffmpeg.exe -i $RV[session_id].wav $RV[session_id].mp3
120000.619 6 4 2 FindNextVgmTitleInPathList: next module title is=[Hangup the Call 1]
I tried many options.
Can You to test by yourself?
[konwersja]
Type=Run Program
DispSize=69
Txt=Run the program, and read in the results file created. The results supplied can then be used in other parts of the script (see Result Variables).
ProgramToRun="C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\ffmpeg.exe" -i "C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\$RV[session_id].wav" "C:\Program Files\VoiceGuide7\Scripts\Maciej\callrecord\$RV[session_id].mp3"
RunHoldPlay=
RunMode=1
RunWait=1
on {success} goto [Hangup the Call 1]
on {fail} goto [Hangup the Call 1]
http://www.ffmpeg.org/
ffmpeg.exe (freeware) convert wav to mp3
Kopia 0130_1828_vgEngine.zip
Worked fine when we tried it here. See attached output file and trace.
Maybe try with simpler paths first? eg:
c:\ffmpeg.exe -i c:\0.wav c:\0.mp3
ffmpegTest.zip
Works fine on our test systems.
Are you sure the .WAV file that you use as input to the program exists?
Please see out attached test with $RVs used as part of filenames in Run Program command line:
runprogtestwithRV.zip
