Vg6 Phone Number Maximum
Hi Support Team
On our voice guide 6 machine we can dial local numbers fine e.g 0788053469 but we can't dial 00256788053469, the number does not even show up on the status monitor so its not dialing what setting should i change in voice guide.\
Tare
Could you please post a copy of VoiceGuide's Debug Printout which captures the loading of the outgoing call, this will allow us to see what happened.
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Please post the traces.
Hi Support Team
The E1 line i am using requires 3 zeros not two. i have found the answer.
Thank you for your help.
Tare
