Can't Get Voiceguide Working With Any Modems
Hi
I have been completely unable to get VoiceGuide working with any modems. I have tried 4 modems so far and all have had the same problem in the event log:
181614.39 0 lineOpen(0) => 0
181614.39 0 Waiting for a call...
181614.40 0 lineOpen(0)LineHandle=66082
181628.63 0 callstate OFFERING 66047 0 4
181628.64 0 ring 1
181634.58 0 ring 2
181634.59 0 Answer the call at 10/10/2003 6:16:34 PM
181634.61 0 lineAnswer(66047) => 66030
181634.63 0 callstate ACCEPTED 66047 0 0
181635.37 0 tapi Reply 66030 0
181635.39 0 callstate CONNECTED 66047,0,0
181635.41 0 WorkingModeTAPI=
181635.43 0 WorkingModeScript=
181635.45 0 Inband detection not enabled
181635.47 0 StartLoadedVgs at 10/10/2003 6:16:35 PM
181635.48 0 [Get Client ID] Number Input
181635.50 0 [Get Client ID] Playing (PayGetId.wav)
181635.53 0 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>4] file[C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav]
181635.55 0 PlaySoundStart line[0] err=[0 tr 5 waveOutOpen MMSYSERR_ALLOCATED but hWaveOut = NULL] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
181635.57 0 Hanging up call... [srlib PlaySoundStart]
181635.59 0 RecSoundStop ok
181635.61 0 PlaySoundStop ok
181635.63 0 fnHangupCall end
181635.65 0 tapie PlayEnd old line=0 0 991129
181635.67 0 tapie PlayEnd old line=0 0 991129
181636.63 0 callstate DISCONNECTED 66047,1,0
181636.65 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
181636.67 0 Hanging up call...
181636.69 0 RecSoundStop ok
181636.71 0 PlaySoundStop ok
181636.73 0 fnHangupCall end
181636.75 0 callstate IDLE 66047 0 0
181636.77 0 WorkingMode@Idle=
181636.82 0 tapi Reply 66013 0
181636.84 0 tapi Reply 65996 0
181637.76 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
181637.78 0 ReinitTelephony due to IDLE start
181637.80 0 tapic lineDeallocateCall(MainCall:66047) 0
181637.90 0 lineOpen(0) => 0
181637.92 0 Waiting for a call...
181637.95 0 lineOpen(0)LineHandle=65979
From the caller's perspective, it answers, but they do not hear anything
and then it proceeds to hang up on them.
Where should I start looking for this problem?
Adam
Just wanted to add, this is under Windows XP, with the following modems:
Dynalink 56VQE (or similar.. dont' know exact model number)
D-Link DFM-560E
D-Link DFM-560E+
Another generic brand...
all are Voice capable and install a driver called "Uni-modem half duplex" or something similar.
Have tried under both the latest versions of VG from the website.
This error is usually returned when some other program is using the modem's Wave device... if there are not other programs using the modem at the same time then I'm not sure what could be casing the problem...
As it is the modem's wave drivers which are the returning the error the only thing I can suggest is to try re-installing them ... - although I'm not too sure if this will resolve the issue on this system... :
Try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first.
You may have to disable the sound card altogether as well to stop Windows from automatically loading it's drivers - to do this just select "Disable" and then select "Uninstall" from the Device Manager.
The only possibility I have been able to come up with so far is that
all the drivers I have installed for these modems are not WinXP certified.
However, I think the modem voice driver is the stock one that comes with
Windows XP.
I also intermittently get another error MMSYSERR_NODRIVER or something similar. However, this happens when a driver is clearly installed.
Adam
... not much else we can suggest at this stage short of trying other modems, or switching to Win2000...
To alleviate the problem I've gone ahead and purchased a Dialogic D/4 PCI card from Bottom Line Telecommunications in the US.
I am just wondering, will this card work in Australia, out of the box with all features?
Adam
