Monitoring The E1
Hello,
I will start to test a new solution using the VG and the dialogic board dmv300btepeq.
In my old solution I use the avaya to receive the E1 and send to the VG. With avaya I can stay monitoring the E1 to know about problems and to know if the E1 is down.
is there some software to see this If I use VG with the Dialogic board?
If the E1 is down the channels will be placed by Dialogic drivers in a "BLOCKED" state, and VoiceGuide's Line Status Monitor will show that the channels are in Blocked state. Is this what you require?
There are also Dialogic utilities installed with the Dialogic drivers that let you monitor the D channel state etc.
