No Set And Run Script Icon On Menu
I instaled new card DIALOGIC D/120 jct and voiceguide 7.1. (my old test configuration d/41 and VG 6)
After opening scrip designer I don't see "set and run" icon on menu to start test script.
editing of CONFIG.XML is possible only with text editor, no other tool?
Yes. Config.xml is a text file and intends to be edited with a text editor such as Notepad etc.
Config.xml is read in at service start time only.
"Set and Run Current Script" is not used in v7 and hence has been removed form the script designer distributed with v7.
