Tts Speaking From Database
i am querying a database for name, surname and title and want to play it with TTS but just cannot work out why it does not work.. Can you take a look at the bug printout as i just don't get it... the record exists in the database, the 3 fileds have the data so i cannot work out why TTS is not finding -- Bet i have done something silly.. please let me know as i am totally stumped!
104302.90 0 dial callque update id=25 next call time 0310091243
104302.90 0 dial callque DB update returned
104302.90 7 dial found entry: tel[1051661180060] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\recruitment\IncomingCalls\test.vgs] am[NONE]
104302.90 7 Calling MakeCallEx(1051661180060)
104302.91 7 Dialing: 1051661180060
104302.91 7 MakeCall => 66101
104302.91 7 TapiCbTrigSet 66101 7002
104303.65 7 tapi Reply (LineEvReply) ok 66101 0
104303.65 7 TapiCbTrigClear
104303.65 7 linedevstate 2048 0 0
104303.65 7 callstate DIALTONE 66152 0 0
104303.66 7 callstate DIALING 66152 0 0
104303.66 7 callstate PROCEEDING 66152 0 0
104303.66 7 callinfo CALLEDID
104303.66 7 callinfo REASON
104303.66 7 Lev_CallerID [01423325554,]
104303.66 7 callinfo ORIGIN
104311.76 7 callstate CONNECTED 66152,1,0
104311.76 7 WorkingModeTAPI@Connected=
104311.77 7 WorkingModeScript@Connected=
104311.79 0 dial callque delete id=25
104311.79 7 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\recruitment\IncomingCalls\test.vgs
104311.79 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\recruitment\IncomingCalls\test.vgs,,,,,0
104311.80 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\recruitment\IncomingCalls\test.vgs at idx=6
104311.80 7 cl NewVgsVgm_RunModule module not found:
104311.80 2 tr NewVgsVgm_Goto 1
104311.80 2 tr NewVgsVgm_Goto 2
104311.80 7 [Database Query 39] DB Query
104311.80 7 Jet mode used (To use ODBC mode specify ODBC Connect string)
104311.81 7 RVreplace start: [sELECT Title, Name, Surname FROM nameslist WHERE PhoneNumber=$RV_CALLEDNUMBER]
104311.81 7 RVreplace end: [sELECT Title, Name, Surname FROM nameslist WHERE PhoneNumber=1051661180060]
104311.81 7 About to execute Retrieve Operation [sELECT Title, Name, Surname FROM nameslist WHERE PhoneNumber=1051661180060]
104311.81 7 [Database Query 39] row count=1
104311.82 7 [Play 40] Playing
104311.82 7 RVreplace start: [Welcome $RV[GetClientRecord_1_1] $RV[GetClientRecord_2_1] $RV[GetClientRecord_3_1]]
104311.82 7 RVreplace end: [Welcome ]
104311.82 7 tts generate start[Welcome ]
104311.85 7 tts generate end
104311.85 7 [Play 40] Playing (C:\Program Files\VoiceGuide\system\tts7.wav)
104311.90 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\tts7.wav]
104311.91 7 RunModule PLAY end
104311.91 2 tr NewVgsVgm_Goto end
104313.07 7 wb(38854200)
104314.07 7 Play End line[7] (id=388542)
104314.07 7 LsPlayMsg EV_PLAY_FINISHED
104314.07 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
104314.09 7 Hanging up call... [Hangup Module]
104314.09 7 RecSoundStop ok
104314.09 7 PlaySoundStop ok
104314.09 7 fnHangupCall end
104314.13 7 linedevstate 2048 0 0
104314.13 7 callstate IDLE 66152 0 0
104314.13 7 WorkingMode@Idle=
104314.16 7 tapi Reply (LineEvReply) ok 66237 0
104315.07 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
104315.07 7 ReinitTelephony due to IDLE start
104315.07 7 tapic lineDeallocateCall(MainCall:66152) 0
104315.24 7 lineOpen(7) => 0
104315.24 7 Waiting for a call...
104315.24 7 lineOpen(7)LineHandle=66084
The title of the module in which the DB query is made is Database Query 39 and the "Play 40" module TTS has RV's defined which would be created by a module titled GetClientRecord.
Change the DB Query module's title from Database Query 39 to GetClientRecord and it should all work...
