Hmp Line Open Failed
Hello,
I am not sure why all the sudden the HMP or VG7 drop the line.
I have done all I know to fix this problem:
disable the firewall.
remove and install .net3.5 ( how can I test .net to insure it works properly for v7?)
disable the wireless network connection.
update Local Area Connection driver.
first installed HMP driver and run it.
then install VG7.1.1
the port opens for while but it will close after some time or if I am stopping and starting the VG7 the port fail to open again.
I am about to setup the HMP and v7 on my production system. I need to find out if I face such a problem during the production how can I quickly fix it. before it heart my business.
Please advice
thanks
the log files are attached for your review.
log.zip
hello,
I need your help on this issue, you can VPN into my computer to exams the VG condition.
please let me know if you would VPN to my computer?
please help to prevent this problem drags for a log time.
thanks
Attached traces show that HMP is not working correctly on this system. VoiceGuide cannot even open any HMP ports on the system.
You will need to get HMP working first and confirm that the demo HMP sample apps work, before installing VoiceGuide.
