Vbs Module With Playing Sound File
I have this vbs module with a sound file to play specified using the "sound file to play" text box.
'START---------------------------------------
Set Conn = CreateObject("ADODB.Connection")
Set vg = CreateObject("vgServices.CommandLink")
Sucursales = 0
Path = Trim("$RV[PathApp]")
Data = ("File Name=" + Path + "Conn.udl")
Conn.Open = Data
Lenght = InStr(Conn,";Use Procedure for")
SQLConnSTR = Trim(Left(Conn,(Lenght-1)))
DB = Split(Split(SQLConnSTR,";")(4),"=")(1)
Server = Split(Split(SQLConnSTR,";")(5),"=")(1)
vg.RvSet $RV_LINEID,"SQLConnStr",SQLConnSTR
vg.RvSet $RV_LINEID,"Server",Server
vg.RvSet $RV_LINEID,"DB",DB
If Sucursales = 0 Then
vg.Script_Goto $RV_LINEID,"TeleCoopMain.vgp","GetCustID",""
Else
vg.Script_Goto $RV_LINEID,"TeleCoopMain.vgp","Sucursal",""
End If
vg.Admin_TraceLogAdd $RV_LINEID,0,"Main.vbs Succeded"
Conn.Close
Set Conn = Nothing
Set vg = Nothing
'END--------------------------------------------------------------------
The script works correctly, but the sound file not completes.
When the VBscript ends, the sound file be stopped.
NOTE: I selected the "Wait until VBScript and sound file completes" option in the combo box.
Can you please post the VoiceGuide trace capturing the call.
Please .ZIP up any files before posting them.
I try using the Run_ResultReturn variables and I have the same problem. (the sound file not completes the play, when the VBscript ends, the sound file be stopped)
I'm sending to you a .zip file with both versions of vbs scripts and the logs file.
Logs.zip
The sound file not completes the play, when the VBscript ends, the sound file be stopped.
I have two versions of VBscript, one using RunResultReturn variable and one not using this variable.
Logs.zip
When the Script_Goto and vg.Script_Gosub commands are used the scripts will immediately jump to the specified script/module.
When using the Run_ResultReturn command then VoiceGuide should wait for the sound file to complete (if "Wait until VBScript and sound file completes" option is selected).
Is this what you are seeing on your system?
Yes, I'm using the Run_ResultReturn command with the option "Wait until VBScript and sound file completes" selected and the sound file stopped too.
This is my initial script and module. It's a VBS module with a sound file to be play.
The module runs ok but the sound file will be stopped when the vbs module ends.
I do not more to do.
Init.zip
We ran a test on a system in our labs which is running the current v7.1 of VoiceGuide and confirmed that system will wait for sound file to complete when "Wait until VBScript and sound file completes" option is chosen.
Looking at your traces it looks like an older verion of VoiceGuide is installed on your system. Please update VoiceGuide software to the current release.
Relevant trace excerpt from our sytem:
154039.928 3 1 1 state [save Data to File VBS] Playing wav (11.wav,12.wav,13.wav,14.wav,15.wav,16.wav,17.wav,18.wav,19.wav,20.wav)
154040.225 7 remoting link constructor activated: vgServices_CommandLink
154040.225 7 1 1 rem Run_ResultReturn [success]
154040.225 3 1 1 rv add [save Data to File VBS_ResultReturn]{success}
154040.225 3 1 1 path {success} found (at offset 3)
154040.225 3 1 1 FindNextVgmTitleInPathList: next module title is=[say Thanks...]
154040.225 3 1 1 module's runwait=2, WavPlayHasNowFinished=0, iRunWait_ExeResult_NextVgm=44
154040.225 3 1 1 wait till WAV finished then goto [say Thanks...] (idx=44)
154040.757 3 1 1 task completed. vgm=48, iRunWait=2, iRunWait_ExeResult_NextVgm=44=[say Thanks...]
154040.757 3 1 1 next module already set. no need to check for Result file
154040.757 3 1 1 RunWait option requires us to wait till after wav finishes playing
154050.257 15 1 1 ev PlayEnd 1 731156
154050.257 3 1 1 [say Thanks...] VGMTYPE_PLAY run start
Now i have installed the VoiceGuide v7.1.1 (vgEngine version : 7.1.3868.40484 (RELEASE Build) in the log file)
and the system works ok. Thank you very much, Diego Bellini
