Result Variables
I need to obtain the path to the location where the VoiceGuide application is located.
At the help file (http://www.voiceguide.com/vghelp/source/html/resultvariables.htm), the information say that's using this variables
$RV_PathScript
$RV_PathVoiceGuide
I try with booth, but not function. The temporary .vbs show a null value.
How is the correct mode to write in a vbs module ?
"$RV[PathScript]"
"$RV[PathVoiceGuide]"
Thanks, Diego Bellini
Are you using VoiceGuide v7?
Can you post traces capturing call start and "$RV_PathScript" being evaluated in an Evaluate Expression module?
Yes, I'm using Voiceguide v7.
I change it to "$RV[PathApp]", and now works correctly.
