Arabic Letter
dear Sir,
i want Voice Guide Program to support arabic letter,
i need to insert letter "م" in a variable
Can you give us some more information on what you need to achieve? Do you need to have TTS speak Arabic text? Or something else?
i ask the caller to enter his ID number (ID number = 1111م)
so i asked the caller if his ID number containing a letter "م " to press "*" instead
So the caller will enter "ex: 1111*", then i will make a vb script to get this number and to change "*" to "م"
the a problem is that when i change the keyboard to write arabic thats the result "ã"
dear sir,
i asked the caller to enter his ID number (ex:111م) and if it is containing a letter to press * instead, so the ID number will entered as (111*), then i made VB script to change the * to be م
the problem is when i cahnge the keyboard to write arabic it written as "ã"
What is the 111م used for afterwards? Is it just saved in file? or something else?
it's an ID number for the caller,
i want to searh in database with this id inorder to get his data
