Using Ftp In Voice Mail Section
Team,
I am using Version 4.9.0 Enterprise.
I am want to use the FTP portion in the Voice Mail area. Mailbox 20 is checked to upload to the FTP server. On the FTP tab I have entered the info for server, user and password. It is not working. Can you assist me?
Here is the event log.
Thanks,
-Brandon
98462 7 tapie linedevstate 2048 0 0
98472 7 tapie callstate OFFERING 65743 0 4
98502 7 Lev_CallerID [6186679930,CROCKETT,BRANDO]
98592 7 tapie callinfo CALLEDID
98592 7 tapie callinfo ORIGIN
98602 7 tapie ring 0
98602 7 Answer the call
98602 7 lineAnswer(65743) => 65744
99143 7 tapie callstate CONNECTED 65743,1,0
99153 7 WorkingModeTAPI=
99153 7 WorkingModeScript=
99183 7 Inband detection not enabled
99193 7 tapi Reply 65744 0
99193 7 [Opening] Playing
99193 7 [Opening] Playing (C:\Documents and Settings\Brandon Crockett\My Documents\VoiceGuide\139wwickliffe\opening.wav)
99273 7 PlaySoundStart ok [C:\Documents and Settings\Brandon Crockett\My Documents\VoiceGuide\139wwickliffe\opening.wav]
99273 7 RunModule PLAY end
00094 7 tapie monitordigits 57 2
00104 7 LsPlayMsg [9]
00165 7 PlaySoundStop ok
00185 7 [Menu] Ask for Vmb Id
00235 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voicedlgc\VmbAccessGetVmbId.wav]
00765 7 tapie monitordigits 50 2
00775 7 LsVmMenu_GetIdPlay [2]
00836 7 PlaySoundStop ok
00856 7 Get Vmb Id: 2
00916 7 tapie monitordigits 48 2
00926 7 LsVmMenu_GetId [0]
00936 7 Get Vmb Id: 20
01166 7 tapie monitordigits 35 2
01176 7 LsVmMenu_GetId [#]
01196 7 [20] Playing Welcome Message
01256 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\VmWelc\20.wav]
01266 7 [20] Play welcome message
04801 7 wb(40120600)
04861 7 Play End line[7] (id=401206)
04881 7 LsVmLm_PlayWelc EV_PLAY_FINISHED
04931 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voicedlgc\beep1.wav]
05142 7 wb(40489100)
05212 7 Play End line[7] (id=404891)
05222 7 LsVmLm_PlayWelc_Beep EV_PLAY_FINISHED
05252 7 RecSoundStart file[C:\Program Files\VoiceGuide\data\VmSave\20_1005232045_1_7_6186679930.wav] ok
05262 7 [20] Recording Message
11421 7 tapie callstate DISCONNECTED 65743,0,0
11431 7 LsVmLm_Rec EV_REMOTEPARTY_DISCONNECT
11491 7 RecSoundStopTruncBytes ok
11511 7 LsVmLm_Rec EV_REC_FINISHED
11521 7 HangupCall called from [srvm]
11531 7 Hanging up call...
11541 7 PlaySoundStop ok
11561 7 fnHangupCall end
11591 7 tapie linedevstate 2048 0 0
11611 7 tapie callstate IDLE 65743 0 0
11621 7 WorkingMode@Idle=
11741 7 set EV_TIMEOUT_TIMETOREINITLINE 2
11751 7 tapi Reply 65778 0
12663 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
12673 7 ReinitTelephony due to IDLE start
12683 7 tapic lineDeallocateCall(MainCall:65743) 0
12863 7 lineOpen(7) => 0
12873 7 Waiting for a call...
12883 7 lineOpen(7)LineHandle=65761
This is beeing looked into, please wait a couple of days - we will email you a response.
Can confirm that FTP uploading of Voicemail messages has been tested and will be included in the upcoming 5.0Beta3 (and onwards).
FTP Uploading of voicemail messages will only be enabled in the Evaluation and Enterprise versions of VoiceGuide.
Are you talking about 5.3 Enterprise Version or 4.9 Enterprise version, which I have.
I am assuming that you have it in the 4.9 Enterprise Version that it should work correct?
Thanks,
-Brandon
