Text To Speech
Hi ...
I want to know if the voice guide software can make arabic translator ?? Mean to translate English data to Arabic ( text to speech ) ...
If it can't ... can we connect voice guide with another software to translate the text into arabic to speech ??
Thanks ...
Sounds like you want to use an Arabic TTS engine...
If English text is first required to be translated to Arabic and then spoken by the TTS engine you will need to interface to a translation service which can achieve this... I imagine there should be translation services available on the WWW which can do this and then translation should be possible to achieve by writing some VB Script code which would supply the English text to the web site and the retrieve the translated output - which you could then feed to the TTS engine...
Hello friend,
If arebic TTS engine is not available, you may write a visual script which will
convert your number to voice file. I'm using it with Indian number system. For
further help you may contact me at rajendrarajsri@yahoo.co.in
Rajendra Prasad
Mirzapur
plez help i nead Arabic TTS where can i download it plz conatct me at distro911@hotmail.com
