Will This Board Work?
We have VG 6.0.3310... Will the D4PCIUFEQ board work with this version? (We're currently running with 2 D4PCIUFW and need to add more lines)
The "E" in the card name indicates that it is a PCI-Express card.
And your current cards are 'traditional' PCI cards.
Not sure if you can run PCI and PCI-Express cards in same system.
Probably best for you to get more PCI cards to match your existing ones.
(the "Q" just means that this card has 6/6 RoHS Compliance)
I actually have one more PCI card but I only had 2 PCI slots so no room for the last one I have. That's why we have to move up to the PCIe version (this is an upgraded server)... So not sure if they'll work together huh?
We never tried PCIe and PCI cards in same system. You may need to ask your Dialogic supplier for advice on this.
If you want to move up to 12+ lines you may want to look at using D/120JCT or DMV160 cards.
