Disconnect_Tone1
Hello,
Please find attach my Log fine for few calls that my VG processed. Recently most of the calls will be disconnected for path {DISCONNECT_Tone1} not found, HangupCall start (Default Handler 20: DISCONNECT_Tone1).
I don’t know why all the sudden this happening. My customers are frustrated for keep call and disconnected.
I also attached my ConfigLine for your review too.
I really appreciate if you can give me some hint, how can I stop VG to disconnect because path {DISCONNECT_Tone1} not found.
your quick response would help my business.
Farzad
Log.zip
Trace shows that in module [WaitForMinuteCard] during which the DISCONNECT_Tone1 is detected there is no DISCONNECT_Tone1 path defined.
The only path defined is:
on {timeout $RV[Mint]} goto [LiveReportVGScript]
You should add the DISCONNECT_Tone1 path to the [WaitForMinuteCard] module.
If you still have problems please post the script that you use.
004043.28 1 state [WaitForMinuteCard] Playing (none)
004049.94 1 event DISCONNECT_Tone1, iCode=134 state=1101
004049.94 1 rv replace start: [on {timeout $RV[Mint]} goto [LiveReportVGScript]
004049.94 1 rv replace end: [on {timeout 55} goto [LiveReportVGScript]
004049.94 1 path {DISCONNECT_Tone1} not found
