Error Chasing
Hi I'm chasing any error on my system.
I have checked the logs and would like to know if the content is normal ?
Thank you.
Mh
150134.625 6 52 27 play start ok, playId=95343
150134.625 7 52 27 qTel run cmd_PlayStart
150134.656 11 dial Db_Delete_Entry end id=238093 guid=00000000-0000-0000-0000-000000000000
150135.031 11 dial some calls found (autodialer) any line, ID/GUID=238094/00000000-0000-0000-0000-000000000000, tel=, sTaskTimestamp=150134.968, diff=00:00:00.0625000
150135.031 11 dial state 1:Null,2:Null,3:Null,4:Null,5:Null,6:Null,7:Null,8:Null,9:Null,10:Null,11:Null,12:Null,13:Null,14:Null,15:Null,16:Null,17:Null,18:Null,19:Null,20:Null,21:Null,22:Null,23:Null,24:Null,25:Null,26:Null,27:Connected,28:Connected,
150135.078 11 1 1 dial no call found (autodialer)
150135.140 11 3 2 dial no call found (autodialer)
150135.187 11 5 3 dial no call found (autodialer)
150135.250 11 7 4 dial no call found (autodialer)
150135.296 11 9 5 dial no call found (autodialer)
150135.359 11 10 6 dial no call found (autodialer)
150135.406 11 12 7 dial no call found (autodialer)
150135.453 11 14 8 dial no call found (autodialer)
150135.484 11 16 9 dial no call found (autodialer)
150135.546 11 18 10 dial no call found (autodialer)
150135.593 11 20 11 dial no call found (autodialer)
150135.640 11 22 12 dial no call found (autodialer)
150135.687 11 24 13 dial no call found (autodialer)
150135.734 11 26 14 dial no call found (autodialer)
150135.781 11 28 15 dial no call found (autodialer)
150135.812 11 30 16 dial no call found (autodialer)
150135.859 11 32 17 dial no call found (autodialer)
150135.906 11 34 18 dial no call found (autodialer)
150135.937 11 36 19 dial no call found (autodialer)
150135.984 11 38 20 dial no call found (autodialer)
150136.031 11 40 21 dial no call found (autodialer)
150136.062 11 42 22 dial no call found (autodialer)
150136.109 11 44 23 dial no call found (autodialer)
There are no errors visible in the quoted trace snippet.
You may want to check whether call ID 238094 was scheduled to only be dialed on certain lines, and whether that call was made once any of those lines became available.
