Out Dailing
Hello,I am using VG 6.0 and when i make out dail calls, after getting few rings automatically it goes to dail stage to wating for a call mode.
if i dail manually,i able to hear dailing rings 50 seconds if the caller does't receive the call.
Log files attached.Looking forward for the solution.
0304vgm.zip
Trace shows the outgoing call was ended as the Dialogic card reported hearing the "Operator Intercept" tri-tone.
113401.30 2 dial making call tel[9848048384] ann[] vgs[C:\Program Files\VoiceGuide\Scripts\Call Recorders\Dial and Record\AutoDial\Scripts\SW_WakeUp_Play.vgs] am[C:\Program Files\VoiceGuide\Scripts\Call Recorders\Dial and Record\AutoDial\Scripts\SW_WakeUp_Play_AM.vgs] OnHangup[] rv[[OutDial_ID]{503}[OutDial_OnNotConnected]{none}[OutDial_AnswerTimeout]{60}[OutDial_RetriesLeft]{0}[OutDial_PauseBetweenRetries]{5}]
113401.30 2 script interpretor: VgMulti v6.0.3391
113401.30 2 state Dialing 9848048384
113404.39 2 tw DialogicEvent 133,TDX_CALLP,11,0,0,CR_CEPT,,
113404.39 2 event OPERATOR, iCode=133 state=5200
113404.39 2 LsWaitAfterDialingOut : 133,OPERATOR,11,0,0,CR_CEPT,,
113404.39 2 event CR_CEPT, iCode=133 state=5200
113404.39 2 LsWaitAfterDialingOut : 133,CR_CEPT,11,0,0,,,
Do you maybe need to dial some sort of a prefix before dialing the number?
I have noticed that some times only getting this problem.not allways.
If i am able to dial this hour and i am not sure for next hour.
I am using VG 6.0
You should ask the Telco about what happens on the calls on which you have the 'operator tone' problem - and why are they playing the operator tone to you.
