Play Module Variable Path
I'm playing wav file in a play module. The path to the wav file is made of substring of a value that I read from a database.
ex: the string I read is like aa = "09-06-14 14:00" I would like to play the wav file that is called 14.wav.
I was wondering how I can build the path using directly the aa var by using the mid(string,start, end) function.
It seems that I cant put directly in the wave file path like this :
c:\..\mid(aa,7,).wav
How can I manage that?
tkx
Mh
The mid function etc. cannot be used as part of the filename expression. Only $RVs can be used as part of the filename expression.
You can use the mid function in an Evaluate Expression module, assign the result of that module to an $RV, and then use that $RV as part of the filename expression.
