Incoming Fax - Unique Filenames
I would like the incomming faxes to have unique file names so that I can store them for long term.
I tried naming it something like "c:\$RV_CIDNUMBER.tif" and other combinations, but it seems to only record a fax if I use a static file name.
Please advise.
u4910: Could you please post a copy of VoiceGuide's Debug Printout which captures the ]call, this will allow us to see what happened.
We have just ran some tests using $RVs in the filename for the received fax and it worked fine. If you have any problems please post trace capturing the call and we can then see what is happening on your system.
I have it working now. Sorry, I must have had a typo on the $RV. I have it recording and saving to a file with date/time/cid/name in the filename.
Thanks!
