Voiceguide Log Viewer
How do I view ALL CALLS in Log viewer.
I can only find VM calls in the "System" folder.
I found the CDR files, but that only shows the call up to Answer.
I want to see what a caller does between Answer and Voicemail.
The .vgl files that are viewed using the Log Viewer application are per-script. The .vgl files log the progress of the call through the particular script.
So to see what the caller did 'between Answer and Voicemail' have a look a the .vgl log of the script that is ran on call answer.
Also, the RVs created during the call can be saved in the CDR logs, if the entry CDR_LastData_SaveRv is set to 1 in the [Log] section of the vg.ini file:
[Log]
CDR_LastData_SaveRv=1
The .vgl files are basically just a collection of RVs created during each call - so you should get same data in the CDR if you enable the above vg.ini setting.
