Mobile Adaptor For Dialogic
Hello,
I am using VG to dial out on PSTN. But I need to use Dial out on mobile as well too.
I was wondering if there is any adaptor to dial on mobile.
thanks for your response,
I think I didn't explain my question clearly. the PSTN line in some of the countries like Malaysia is expansive but mobile is much chipper.
we try to use mobile to make outbound call instead of PSTN lines.
the GSM Gateway is a device that help to dial from PSTN or PBX to mobile. the problem is, to make a outbound call to PSTN we need to connect the GSM Gateway to PSTN line again. We don't want to use PSTN line at all.
I believe, I can use USB modem device. I can connect USB mobile from one side to Dialogic and the other side to a mobile. this way when VG make outbound call, Dialogic will make outbound call on mobile instead of PSTN line. I have not test this design, What do you think would it work?
thanks for your help.
The GSM gateway woudld attach to the ports on the Dialogic card. No PSTN lines would be involved.
