Bad Wave Sound
How the sound of played wave is bad?
Please tell me how to make it clear to listen.
I'm using 8000 khz 16 bit Mono recording.
But this is the log:
173953,35 2 callstate OFFERING 65872 0 4
173953,37 2 ring 1
173953,37 2 Answer the call at 29/08/2003 17:39:53
173953,38 2 lineAnswer(65872) => 66146
173953,38 2 callstate ACCEPTED 65872 0 0
173957,21 2 tapi Reply 66146 LINEERR_OPERATIONFAILED [80000048]
173957,21 2 callstate DISCONNECTED 65872,16384,0
173957,21 2 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
173957,23 2 Hanging up call...
173957,23 2 RecSoundStop ok
173957,23 2 PlaySoundStop ok
173957,23 2 Waiting for a call...
173957,23 2 fnHangupCall end
173957,23 2 callstate IDLE 65872 0 0
173957,23 2 WorkingMode@Idle=
173957,23 2 LineState(iLineId).iVgsIdx = 0
173957,25 2 tapi Reply 65564 0
173958,22 2 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
173958,22 2 ReinitTelephony due to IDLE start
173958,22 2 tapic lineDeallocateCall(MainCall:65872) 0
173958,25 2 lineOpen(2) => 0
173958,26 2 Waiting for a call...
173958,26 2 lineOpen(2)LineHandle=66402
173959,36 2 callstate OFFERING 66214 0 4
173959,37 2 ring 1
173959,37 2 Answer the call at 29/08/2003 17:39:59
173959,38 2 lineAnswer(66214) => 65889
173959,39 2 callstate ACCEPTED 66214 0 0
174002,68 2 tapi Reply 65889 0
174002,69 2 callstate CONNECTED 66214,0,0
174002,70 2 WorkingModeTAPI=
174002,70 2 WorkingModeScript=
174002,71 2 Inband detection not enabled
174002,71 2 StartLoadedVgs at 29/08/2003 17:40:02
174002,72 2 [main] Playing
174002,72 2 tts generate start[hi]
174002,74 2 tts generate end
174002,75 2 [main] Playing (F:\Program Files\VoiceGuide\d.wav, F:\Program Files\VoiceGuide\system\tts2.wav)
174003,04 2 PlaySoundStart ok [F:\Program Files\VoiceGuide\d.wav,F:\Program Files\VoiceGuide\system\tts2.wav]
174003,04 2 RunModule PLAY end
174019,93 2 wb(29532801)
174020,02 2 Play End line[2] (id=295328)
174020,02 2 LsPlayMsg EV_PLAY_FINISHED
174024,93 2 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
174024,93 2 tts generate reuse
174024,95 2 [main] Playing (F:\Program Files\VoiceGuide\d.wav, F:\Program Files\VoiceGuide\system\tts2.wav)
174025,23 2 PlaySoundStart ok [F:\Program Files\VoiceGuide\d.wav,F:\Program Files\VoiceGuide\system\tts2.wav]
Please help me to get the best quality
What TTS engine is used on your system? Are you using a Voice modem?
Sound quality of Voice modems is generally pretty poor, and this combined with a poor quality TTS will not sound good.
for a Good Quality TTS please see AT&T's Natural Voices:
AT&T's Natural Voices TTS engine can be heard at:
http://www.naturalvoices.att.com/demos/
and can be purchased (for US$35+shipping) from:
https://www.regsoft.net/regsoft/vieworderpa...productid=56116
for a good quality TTS system you'll need AT&T + Dialogic card
