Problem Getting Text To Speech Working
I am having a problem getting voice guide to speak what is written. I have installed the MS speech sdk, but get the following in the logs
174145.01 3 tts generate start[this is a test of the text to speech]
174148.03 3 tts generate end
174148.04 3 [Thanks for calling] Playing (C:\Program Files\VoiceGuide\system\tts3.wav)
174148.04 3 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7] file[C:\Program Files\VoiceGuide\system\tts3.wav]
174148.09 3 RunModule PLAY end
174148.10 3 tapie PlayEnd old line=3 0 742639
174152.71 3 Play End line[3] (id=742639)
the user on the phone get's a message saying "that there has been an error playing the file please check the file format"
attached is the script we are trying to use any help would be great
thanks
Jeremy
getproperty.vgs
Is this system using a Voice modem or a Dialogic card?
Which version of Windows is installed on this system and which version of SAPI is installed?
Is the file "C:\Program Files\VoiceGuide\system\tts3.wav" actually created by the TTS system? If yes could you please ZIP it up and post it here.
Can you please also post the trace capturing an entire call.
this is the output from the log file, also I have attached the tts3.wav file. we are using a netcomm roadster v.92 voice modem
114149.24 3 About to execute Retrieve Operation [sELECT propertyID, propLotNo, propunitNo, propstreetNo, propstreetName, propsuburb FROM baseproperty WHERE propertyID = 502]
114149.43 3 [get_address] row count=1
114149.59 3 [play_address] Playing
114149.59 3 RVreplace start (strlen>100)
114149.59 3 RVreplace end: [the address you entered was 49 NORTH STREET ASCOT VALE]
114149.59 3 tts generate start[the address you entered was 49 NORTH STREET ASCOT VALE]
114149.97 3 tts generate end
114149.97 3 [play_address] Playing (C:\Program Files\VoiceGuide\system\tts3.wav)
114149.98 3 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7] file[C:\Program Files\VoiceGuide\system\tts3.wav]
114150.04 3 RunModule PLAY end
114150.04 3 tapie PlayEnd old line=3 0 554329
114154.65 3 Play End line[3] (id=554329)
114154.65 3 LsPlayMsg EV_PLAY_FINISHED
114157.11 3 callstate DISCONNECTED 65982,32,0
114157.11 3 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
114157.11 3 Hanging up call...
114157.11 3 RecSoundStop ok
114157.11 3 PlaySoundStop ok
114157.11 3 fnHangupCall end
114158.30 3 callstate IDLE 65982 0 0
114158.30 3 WorkingMode@Idle=
114158.31 3 tapi Reply 65539 0
114159.26 3 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
114159.26 3 ReinitTelephony due to IDLE start
114159.26 3 tapic lineDeallocateCall(MainCall:65982) 0
114159.29 3 lineOpen(3) => 0
114159.29 3 Waiting for a call...
114159.30 3 lineOpen(3)LineHandle=65726
tts3.zip
The WAV file does not have any sound data in it.
I'd suspect that SAPI is not install correctly on your system, can you use the Speech applet in the Control Panel to generate Text-to-Speech?
Is one of the standard voices (Microsoft Mary or Microsoft Mike) selected as the default voice? Keep in mind that both Microsoft TTS voices are pretty poor - much better TTS quality will be achieved with AT&T TTS engine.
