Run Vbs Module Not Completing
VoiceGuide creates the vbs file the temp directory but unless I manually click on the file VoiceGuide does not proceed to the next step. I attached the vgs file and two trace files. The first trace is in a case where I manually ran the vbscript which caused voice guide to go down the success path and anounce the balance on the PIN. The second trace is of a call where the vbscript was not manually run. The call timed out after 10 seconds.
0818_1623_vgEngine.txt
0819_1042_vgEngine.txt
test1.vgs
Do you have any anti-virus software installed on this system? Some anti-virus software prevent automatic running of VBScripts on system.
Also recommned you use Admin_TraceLogAdd COM commands to trace VBScript execution progress. See: http://www.voiceguide.com/vghelp/source/ht...tracelogadd.htm
Admin_TraceLogAdd will add log entries to the vgEngine trace log.
This will let you see to which points of the VBScript the VBScript is progressing, and in what time.
