Script Help
I have a simple task but can not get it to work. I have a user enter a time i.e. 1130, then i have them enter a "1" for AM or "2" for PM. I am trying rake the value from the Capture Enterend Module and if they entered a "2" add 12 to the number and pass it to a Say Numbers so I can have them verify their entry 1130 PM or if the enter a 1 - just pass the value ant wil will say 1130 AM
Jeff
Please post your current script and an excerpt from vgEngine trace capturing the call.
attached. The script is a subset of the larger working script. It is this portion that I can not get to work.
what i need is the ability to accept input and if less than 12, the add 12 to the number.
jwtest1.vgs
0803_ktTel.zip
Please see attached script.
The module [ArrivalTime] can also be removed if the TTS text is saved to a .txt file and that .txt file is played from the [GetArrival] module.
add1200.vgs
Thanks! works great - one issue maybe you can help with. If they enter three digits, how can I prepend a zero "0" to the RV
Jeff
You would need to use either a VBScript or two Evaluate expression modules to do this.
In a VBScript module something like the below would be used:
if len("$RV[timein]") = 3 then
sDay = "0" & "$RV[timein]"
else
sDay = "$RV[timein]"
end if
vg.Run_ResultReturn $RV_LINEID, "[time4digits]{" + sDay + "}"
set vg = Nothing
If using two evaluate expression modules the fist module would have this expression:
len("$RV[timein]")
then you would have a path like this:
on {3} goto [addo0tofront]
and addo0tofront would be another Evaluate Expression module which does this:
"0" + "$RV[timein]"
and saves the result to new RV, eg: time4digits
