Extensions
If you are using ISDN lines then just place a call to 18187776666, then when the call is answered have the script dial the 4567 as DTMF tones (the Play module can be used to dial the DTMF tones).
On the outbound call have the Answerng Machihne Script entry set to either ignore or disable
