Tts
I am trying to play a few files at once... When i play the wav files everything works but as soon as i add the TEXT TO SPEECH text file it tells me there was an error playing the file.. If i play the TTS file on it's own it works ok. Please help with this thanks Matt
141143.08 0 dial callque update id=1006 next call time 0309231611
141143.09 0 dial callque DB update returned
141143.09 7 dial found entry: tel[1051661180060] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\recruitment\new.vgs] am[NONE]
141143.09 7 Calling MakeCallEx(1051661180060)
141143.09 7 Dialing: 1051661180060
141143.09 7 MakeCall => 66122
141143.09 7 TapiCbTrigSet 66122 7002
141143.84 7 tapi Reply (LineEvReply) ok 66122 0
141143.84 7 TapiCbTrigClear
141143.84 7 linedevstate 2048 0 0
141143.84 7 callstate DIALTONE 65575 0 0
141143.84 7 callstate DIALING 65575 0 0
141143.84 7 callstate PROCEEDING 65575 0 0
141143.84 7 callinfo CALLEDID
141143.85 7 callinfo REASON
141143.85 7 Lev_CallerID [01423325554,]
141143.85 7 callinfo ORIGIN
141153.63 7 callstate CONNECTED 65575,1,0
141153.63 7 WorkingModeTAPI@Connected=
141153.63 7 WorkingModeScript@Connected=
141153.65 0 dial callque delete id=1006
141153.65 7 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\recruitment\new.vgs
141153.65 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\recruitment\new.vgs,,,,,0
141153.66 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\recruitment\new.vgs at idx=6
141153.66 7 cl NewVgsVgm_RunModule module not found:
141153.66 2 tr NewVgsVgm_Goto 1
141153.66 2 tr NewVgsVgm_Goto 2
141153.66 7 [GetClientRecord] DB Query
141153.66 7 Jet mode used (To use ODBC mode specify ODBC Connect string)
141153.67 7 RVreplace start (strlen>100)
141153.67 7 About to execute Retrieve Operation [sELECT Title, Name, Surname, UKPhoneNumber, CallersName, CallStatus, LeadSource, CallSubject, Address1, Address2, Address3, City, County, Postcode, CallersEmail FROM NamesList WHERE PhoneNumber=1051661180060]
141153.77 7 [GetClientRecord] row count=1
141153.78 7 [intro] Playing
141153.78 7 [intro] Playing (recruitment\tts-name.txt, recruitment\rec- live-call-filter-message1.wav, recruitment\rec- live-call-filter-message2-info.wav)
141153.78 7 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2] file[C:\Program Files\VoiceGuide\Scripts\recruitment\tts-name.txt,C:\Program Files\VoiceGuide\Scripts\recruitment\rec- live-call-filter-message1.wav,C:\Program Files\VoiceGuide\Scripts\recruitment\rec- live-call-filter-message2-info.wav]
141153.81 7 RunModule PLAY end
141153.82 2 tr NewVgsVgm_Goto end
141153.82 7 tapie PlayEnd old line=7 0 978458
141158.31 7 wb(97845800)
141159.32 7 Play End line[7] (id=978458)
141159.32 7 LsPlayMsg EV_PLAY_FINISHED
141159.32 7 Hanging up call... [No Paths leaving Play module [intro]]
141159.32 7 RecSoundStop ok
141159.32 7 PlaySoundStop ok
141159.32 7 fnHangupCall end
141159.37 7 linedevstate 2048 0 0
141159.37 7 callstate IDLE 65575 0 0
141159.37 7 WorkingMode@Idle=
141159.39 7 tapi Reply (LineEvReply) ok 66156 0
141200.33 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
141200.33 7 ReinitTelephony due to IDLE start
141200.33 7 tapic lineDeallocateCall(MainCall:65575) 0
141200.49 7 lineOpen(7) => 0
141200.49 7 Waiting for a call...
141200.50 7 lineOpen(7)LineHandle=66276
This trace does not show VoiceGuide doing any real-time TTS - it looks like all the supplied files have been pre-recorded...
Are all the sound files in correct format?
Will the 3 files play OK from 3 successive Play modules?
If all sound files are in the same format and play separately OK - just not play when they are all together could you please zip up the 3 files and post them here and we can have a look at them.
Also please place the attached file in "C:\" and include in the .zip the trace file C:\TapiWrapLogMMDD.txt which captures more debug information. The file TapiWrapLogMMDD.txt will be created in "C:\"
TapiWrapLogSelect.txt
