Porttouse Row Order
Hi I'm having a question regarding the order or rows in porttouse table.
I have the following callque example (3 numbers in this table)
CallQue
ID1 Phonenumer1
ID2 Phonenumer2
ID3 Phonenumer3
Let assume that I want the campaign to be played on 3 lines, in porttouse I would have:
CallID Portnumber
ID1 1
ID1 2
ID1 3
ID2 1
ID2 2
ID2 3
ID3 1
ID3 2
ID3 3
But due to how i populate the table I have the following order in porttouse
CallID Portnumber
ID1 1
ID2 1
ID3 1
ID1 2
ID2 2
ID3 2
ID1 3
ID2 3
ID3 3
What is the correct one. I though there was no difference but it seems that there is when called by VG.
This is a database question, not a VoiceGuide related one. Suggest you post this question on MySQL forums. (as I understand that you are using MySQL as the DB engine)
The order in which a relational database such as MySQL chooses to report rows in a data set or table is not defined and can be anything it wants.
The order does not affect VoiceGuide operation as VoiceGuide uses the LIMIT/TOP/ORDER BY/etc clauses in it's SQL queries to have the database return only the single specific row that VoiceGuide requires.
If you have any questions regarding VoiceGuide operation then please post traces (.ZIPed) capturing the time during which your question arises, and indicate the specific time that you want us to look at and we can then advise why VoiceGuide acted the way that it did.
is it possible to have an exmaple of sql query made by VG when using mysql db and when using porttouse table .
It is difficult to point a time where the probleme occurs that's why I'm trying to understand how the porttouse table is applyed and used by VG to make sure that there is nothing wrong when uploading my rows in that table.
Tkx
Mh
You would be able to see all the actual SQL queries made by VoiceGuide if you turn on the SQL tracing on the MySQL server side. This way all the queries can be seen and the responses sent by the database can be seen.
What is the actual problem?
Why do you think there is a problem of any kind if you are even unable to determine at what time the supposed problem occurs?
From http://www.voiceguide.com/vghelp/source/ht...rnal_config.htm :
It's recommended to use the Dial List Loader application to load some calls into the database and then examine the database tables to see how the information is placed in the tables.
Hi Here isstrange behaviour that I have just experienced (not neccessarly linkted with porttouse question) :
The lines 1,2 and 9 are not dialing and the call length is about to 358.
on line 14 there is I see a script run but the call length is also at 350 (I can hang up manualy)
I have just stopped the machine while I was experiencing tht so the log are really on the right period.
I have restarted VG and seems ok. I wanted to understand what happens to fix it
tkx
Mh
0702_1708_vgEngine.zip
There is something strange about the way in which calls are returned from the database. This begins at the very first call retrieval.
Could you please set in vg.ini the vgEngine log level to be 20 and then restart system and just capture the first 2 minutes or so of system operation. Please have a similar amount of calls is in your database as during the test you have just done.
BTW. How many calls are in the database? Is the database on the same system as VG? How fast are the PCs/Servers that are used here?
170909.046 10 dial FindCallQueryCompleted some calls found (any lineid search), ID/GUID=111858/00000000-0000-0000-0000-000000000000, sTaskTimestamp=170906.906, diff=00:00:02.1406250
170909.062 10 dial FindCallQueryCompleted some calls found (any lineid search), ID/GUID=111858/00000000-0000-0000-0000-000000000000, sTaskTimestamp=170906.906, diff=00:00:02.1562500
170909.718 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.Read() returned True
170909.718 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.iFieldCount=18, sTaskTimestamp=170909.046, diff=00:00:00.6718750
170909.718 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.iID=120533
170909.718 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.guid is not used LinkField=[iD]
170909.718 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumber=[0474110582]
170909.718 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumberPrefix=[0]
170909.718 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.datetimeActivation=[02/07/2009 16:56:51]
170909.718 10 dial live=C:\Program Files\VoiceGuide\Scripts\coriolis.vgs, am=C:\Program Files\VoiceGuide\Scripts\MV_coriolis.vgs, fax=, onNotAnswer=, onRetriesExhausted=
170909.718 10 dial iRetriesDelay_Seconds=10800
170910.015 10 dial callque update id/guid=120533/00000000-0000-0000-0000-000000000000 nextActivateTime=02/07/2009 20:09:09, retriesLeft=0, iRelatedPortNumber=1 : completed ok
170910.015 10 dial FindCallQueryCompleted a call was found. Port= 1, sTaskTimestamp=170909.046, diff=00:00:00.9687500
170910.015 10 1 dial StartOutgoingCall start tel[0474110582] live[C:\Program Files\VoiceGuide\Scripts\coriolis.vgs] am[C:\Program Files\VoiceGuide\Scripts\MV_coriolis.vgs] fax[] onNotAnswered[] onRetriesEnd[] rv[[CampaignName]{2009-07-02 13:06:24}[clientid]{1001}[clientlogin]{coriolis}[Nom]{BRUN STEPHANE}[prenom]{}[Adresse]{19 RUE FERNAND LEGER}[Zip]{38150}[Ville]{ROUSSILLON}] CampaignName[2009-07-02 13:06:24] options[] ID=120533
170910.015 10 1 ls set Dialing
170910.015 10 1 dial making call LineState settings: tel[00474110582] live[C:\Program Files\VoiceGuide\Scripts\coriolis.vgs] am[C:\Program Files\VoiceGuide\Scripts\MV_coriolis.vgs] fax[] noAnswer[] retriesEnd[] OnHangup[] rv[] options=[]
170910.031 10 1 answering machine detection enabled. sCallProgressOption = [DX_PAMDOPTEN]
170910.031 10 1 rv clear all
170910.031 10 1 rv add [CampaignName]{2009-07-02 13:06:24}
170910.031 10 1 rv add [clientid]{1001}
170910.031 10 1 rv add [clientlogin]{coriolis}
170910.031 10 1 rv add [Nom]{BRUN STEPHANE}
170910.031 10 1 rv add [prenom]{}
170910.031 10 1 rv add [Adresse]{19 RUE FERNAND LEGER}
170910.031 10 1 rv add [Zip]{38150}
170910.031 10 1 rv add [Ville]{ROUSSILLON}
170910.031 10 1 rv add [OutDial_RetriesLeft]{1}
170910.031 10 1 state Dialing 00474110582
170910.031 10 1 t timer set 30 sec : EV_TIMEOUT_MAKECALL_NORESPONSE
170910.031 10 1 ls set Dialing
170910.031 10 1 rvns add [OutDial_Result]{NOTCONTACTED}
170910.031 10 1 rvns add [OutDial_Result]{NOANSWER}
170910.031 10 1 ktTel_MakeCall_Enqueue([00474110582],DX_PAMDOPTEN, 30,0,0,,) call
170910.031 10 1 qTel add cmd_MakeCall [0,0,30,0,0][||00474110582|DX_PAMDOPTEN|]
170910.031 7 1 qTel run cmd_MakeCall
170910.046 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.Read() returned True
170910.046 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.iFieldCount=18, sTaskTimestamp=170909.062, diff=00:00:00.9843750
170910.046 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.iID=120536
170910.046 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.guid is not used LinkField=[iD]
170910.046 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumber=[0474860601]
170910.046 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumberPrefix=[0]
170910.046 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.datetimeActivation=[02/07/2009 16:57:19]
170910.046 10 dial live=C:\Program Files\VoiceGuide\Scripts\coriolis.vgs, am=C:\Program Files\VoiceGuide\Scripts\MV_coriolis.vgs, fax=, onNotAnswer=, onRetriesExhausted=
170910.046 10 dial iRetriesDelay_Seconds=10800
170910.171 10 dial callque update id/guid=120536/00000000-0000-0000-0000-000000000000 nextActivateTime=02/07/2009 20:09:10, retriesLeft=0, iRelatedPortNumber=1 : completed ok
170910.171 10 dial FindCallQueryCompleted a call was found. Port= 1, sTaskTimestamp=170909.062, diff=00:00:01.1093750
170910.171 10 1 dial StartOutgoingCall start tel[0474860601] live[C:\Program Files\VoiceGuide\Scripts\coriolis.vgs] am[C:\Program Files\VoiceGuide\Scripts\MV_coriolis.vgs] fax[] onNotAnswered[] onRetriesEnd[] rv[[CampaignName]{2009-07-02 13:06:24}[clientid]{1001}[clientlogin]{coriolis}[Nom]{BRUNEL ROGER}[prenom]{}[Adresse]{RUE JEAN MOULIN}[Zip]{38150}[Ville]{ROUSSILLON}] CampaignName[2009-07-02 13:06:24] options[] ID=120536
170910.171 10 1 ls set Dialing
170910.171 10 1 dial making call LineState settings: tel[00474860601] live[C:\Program Files\VoiceGuide\Scripts\coriolis.vgs] am[C:\Program Files\VoiceGuide\Scripts\MV_coriolis.vgs] fax[] noAnswer[] retriesEnd[] OnHangup[] rv[[CampaignName]{2009-07-02 13:06:24}[clientid]{1001}[clientlogin]{coriolis}[Nom]{BRUN STEPHANE}[prenom]{}[Adresse]{19 RUE FERNAND LEGER}[Zip]{38150}[Ville]{ROUSSILLON}[OutDial_RetriesLeft]{1}] options=[]
170910.171 10 1 answering machine detection enabled. sCallProgressOption = [DX_PAMDOPTEN]
170910.171 10 1 rv clear all
170910.171 10 1 rv add [CampaignName]{2009-07-02 13:06:24}
170910.171 10 1 rv add [clientid]{1001}
170910.171 10 1 rv add [clientlogin]{coriolis}
170910.171 10 1 rv add [Nom]{BRUNEL ROGER}
170910.171 10 1 rv add [prenom]{}
170910.171 10 1 rv add [Adresse]{RUE JEAN MOULIN}
170910.171 10 1 rv add [Zip]{38150}
170910.171 10 1 rv add [Ville]{ROUSSILLON}
170910.171 10 1 rv add [OutDial_RetriesLeft]{1}
170910.171 10 1 state Dialing 00474860601
170910.171 10 1 t timer set 30 sec : EV_TIMEOUT_MAKECALL_NORESPONSE
170910.171 10 1 rvns add [OutDial_Result]{NOTCONTACTED}
170910.171 10 1 rvns add [OutDial_Result]{NOANSWER}
170910.171 10 1 ktTel_MakeCall_Enqueue([00474860601],DX_PAMDOPTEN, 30,0,0,,) call
170910.171 10 1 qTel add cmd_MakeCall [0,0,30,0,0][||00474860601|DX_PAMDOPTEN|]
>> you understand better my fist post :-)
>> this is done see attachements
>> in the callQue table I have about 13000 entries but only 3000 with a ActivateTime whitch allows to be dialed.
>> I'm running VG and Mysql on the same server
>> pc is a intel pentium dual CPU, 2.40Ghz, 3Go RAM
>> I have experienced that since I have changed the order in which I store entries in porttouse table ( have explained in the first post)
Thank you
0703_1241_vgEngine.zip
Can you please tell us more about the system setup. Is this just a normal install of Windows with just Windows +Dialogic+VoiceGuide+MySQL or is there something else running on this system?
The trace shows some strange behavior.
Could you update the VoiceGuide to the latest version available from our WWW to see if this behavior still exists when the latest release version is used?
124200.359 4 0 dial timerStartDueDials_Tick entry
124200.359 21 0 dial timerStartDueDials_Tick entry
124200.359 4 0 dial DbProcessQueue_QueueForWork call from timerStartDueDials_Tick entry
124200.359 21 0 dial DbProcessQueue_QueueForWork call from timerStartDueDials_Tick entry
