Fax Line Doesn't Always Answer
now that i finally have my d/41jct-ls answering faxes, there is a new issue.
the same line, being called from the same place, sometimes answers, and sometimes does not. i was watching the status monitor and it went past the 2 rings when it should have answered and kept ringing until the sender gave up.
in the attached logs, this should be the last call that you see.
regards,
les
4325184_faxreceive_090619.ZIP
Call was not answered as this system does not appear to be licensed, and hence stops answering calls after 1 hour.
At the bottom of the Line Status Monitor this note would have been displayed:
EVALUATION (needs restarting every hour)
In vgEngine trace we can see:
125504.375 6 reg , lines: 30 id: | FW013390 | HK045756
150549.906 6 ****************************************************
150549.906 6 16 AnswerTheCall: Evaluation time expired
If you have tried applying the license then please email your userinfo.lic file (from VG's main directory) to sales@voiceguide.com along with a link to this thread.
sorry, i discovered this myself almost immediately after posting. but then i had to leave before the moderator approved the post.
i will test it again, but i am sure that applying the license was the issue.
les
